BMW Garage | BMW Meets | Register | Today's Posts | Search |
BMW 3-Series (E90 E92) Forum
Front f30/f80 brakes into e90 Info
08-11-2017, 08:40 AM | #1 |
Rep 573
Huge Thanks to feuer for going over this and making sure it right and others for answering questions on the two 30+page threads.
I have the front 340 caliper/rotors pads FOR SALE which are direct bolt on if anyone is interested(first pic). I might also sell the rear set. This is an information/diy thread for the Front since both threads i went thru are over 10 pages long. Most questions are answered here if not before sending a pm most of it has been answered. Easiest retrofit for e90/e92 Keep in mind there are only two versions of the brembos calipers 340mm and 370/380mm version. Q & A 1)Whats the most direct bolt on a)f30 340mm calipers with f30 340mm front rotors (no stock e90/e92 rotors will not work) as close to Direct bolt on 2) Can i fit f80 370/380mm with f30 rotors? a) not recommended but will work as the pad will not make full contact as the caliper sits higher for a 370/380 rotor) 3) Can i fit complete m3/m4 370/380 caliper and 370mm rotor? a) yes and no there are a two version of the 370mm rotor performance/f30 370mm rotor will be a direct bolt on m3/m4 370mm rotor will not work for the same reason the stock 335i rotor it will be about 5mm off. Some have made it work by using a spacer and longer bolts for the caliper and knuckle but it will still be off center. 4) Will it fit my wheels? a) Depends on spoke design, offset and barrel some 18's will fit but some 19's will not again depends on the spoke, offset and barrel design. 5) Are calipers directional? a) Yes there is a left and a right make sure bleeding nipples are facing up 6) is Bleeding easy? a) depends if you've done it before and know what you're doing but bleeding with INPA is recommended 7) Any coding required? a) f30's have programmable abs e90's don't but from what i hear some have found a way to program it there is a thread around here you can read into it. 8) Do i need a m3 master cylinder a) from my research for the fronts only you don't but if you do a front a rear conversion the M3 MC does give you a firmer pedal but you might want to make sure you system is bleed correctly before you jump into that upgrade. 9) Do sensors work a)LCI e90 brake sensors work. Pre LCI brake sensors don't Silver/Blue Brembos Caliper from F30 Stamped (340 in the back) p/n Left = 34116850931 Right = 34116850932 Photo Aug 10, 5 43 29 PM by reynaldo reynaldo, on Flickr ________ m3/m4/performance caliper (stamped 370/380) in the back Longer mounting points Photo Aug 10, 5 43 26 PM by reynaldo reynaldo, on Flickr Left = 34116799469 Right = 34116799470 f30 performance bbk 34112221445 Red 34112221446 Yellow 34112221447 Orange __________ From Left to right for reference 1) Blue Rear Calipers 2) F30 Rear Rotors 3) Red f30 340mm front Calipers 4) Front f30 Rotors 5) bottom rotor stock e90 rotor 6) Blue f80/82 380mm Calipers 7) m3/m4 Front rotor. Photo Aug 10, 6 12 58 PM (1) by reynaldo reynaldo, on Flickr Last edited by Supra2k6; 08-11-2017 at 08:47 AM.. |
08-11-2017, 11:16 AM | #2 |
Sua Sponte
1299
Rep 2,850
Drives: 2013 LMB 335is
There is a F30 M Performance 370mm caliper that is plug and play with the M Performance 370 mm rotor on E9x chassis cars too. The M3/M4/F3x caliper fits just fine. It's the M3/M4 rotor that won't work.
335is/DCT-M3 GTS software-M3 drivetrain-M3 GWS-KOMBI-DSC-SZL/MHD/BQ Tuning IG@ClustersandCoding
08-11-2017, 12:15 PM | #3 |
Rep 819
You may want to revise Your answer for 3a
Add some punctuation! Some people may not understand, but I do! And you mentioned the m3/m4 rotors as 370mm not 380mm. I'm not an English major, so just use this as a reference. I also added some additional details. yes and no. there are a two version of the 370mm rotors, 370mm M performance (Dimpled&Slotted) & f30 M brake factory option 370mm rotor (Plain with blue calipers) will be a direct bolt on. m3/m4 380mm rotor will not work for the same reason the stock 335i rotor it will be about 5mm off. Some have made it work by using a spacer and longer bolts for the caliper and knuckle but it will still be off center. But great forsale post, it's very informative! |
KJ335D0.00 |
08-11-2017, 12:30 PM | #4 |
Rep 573
Its Same caliber that are used on the M3/m4 they are just paying at different color and packaged on a performance kit.
08-11-2017, 12:33 PM | #5 | |
Rep 573
Thank you will make corrections and additions
08-11-2017, 01:26 PM | #6 | |
Sua Sponte
1299
Rep 2,850
09-29-2019, 06:44 PM | #7 |
Rep 760
Drives: E92 CT200h Cayman Boxster RC
Bringing this back from the dead. I am going to be doing some test fitting with different rotors. From what I gather the ones I can use are the 370x30 with the F80 performance calipers?
That was the plan. If I can run the 380, I will. Also, do you use the F80 mounting hardware or the existing bolts from the E90 caliper?
Long Beach Blue E92 with Carbon Fiber Roof
Build Thread |
09-30-2019, 10:42 AM | #8 |
Rep 573
380mm are a bit more complicated if you search someone came up with a bracket and pressed in mounting point for $300 bucks which would allow you to bolt up the 380's just search it was recent. I have some f80 rotors if you are looking to buy some. |
10-02-2019, 12:57 AM | #9 | |
Rep 760
Build Thread |
10-31-2019, 08:44 PM | #11 |
Rep 7
What is the correct part number for the 370x30 rotors that fit with M3/M4 calipers on an e90? Is it 34106797606 or 34106797603? And if both what are the differences between them?
11-01-2019, 12:28 AM | #12 |
Rep 760
Still have yet to put them on. Was going to order the calipers soon. I'm painting the car and they will go on at the same time. I just got in the rebuild kit, so I am planning on doing that this weekend.
I will look them up and try to cross reference a few things for you.
Build Thread |
11-16-2019, 07:24 PM | #14 |
Rep 2,099
Got a set of 370 m performance front calipers (the red ones) and I'm looking to rebuild the piston seals. Anyone happen to know the part number or even an aftermarket source kit?
Also, I know this is the part # for the dimpled/slotted rotors (odd that they don't have two part numbers for directional swept slots): 34106797603. But if I wanted to keep my rears stock (e90 328i lci) does anyone know the blank rotor part #? Is it 34106797606? |
06-17-2021, 04:01 AM | #15 | |
Rep 760
Build Thread |
08-25-2021, 01:15 PM | #16 |
Rep 47
I know this is a late response to the thread but does swapping to a E9X M3 rear knuckle/spindle/wheel carrier allow for the 370mm rear F80 disc?
If yes, what else needs to be changed except for the knuckle? |
11-25-2021, 03:55 AM | #17 |
Rep 17
01-21-2022, 09:42 PM | #20 |
Rep 9,209
Same as on any e9x. https://e84.xbimmers.com/forums/show....php?t=1430889
01-23-2022, 10:44 AM | #21 | |
Rep 20
So based on one of your other trends. I assume the following would be what I should buy. M-Performance front calipers for 370mm rotors (same as m3/4 calipers) #34106797606 blank rotors #34106797603 dimples/slotted rotors Thanks again for your help. |
