BMW 5-Series (G30) Forum iDrive, Audio, Bluetooth, Phone, Cameras, Electronics + Coding Remote Parking Retrofit
      08-29-2017, 08:04 AM   #1
FlashedVirus0
BMW Lover
Drives: 2019 F16 50i
My 2017 G30 didn't come with remote control parking. Does anyone know if this feature can be retrofitted? I have all three driving assistance packages.
      08-29-2017, 06:30 PM   #2
Ab3_Fr0man
Drives: G30 540i
2017 540i  [0.00]
2011 535xi  [0.00]
If you have 360 view cameras and PDC. You can have it coded but, you will need to purchase a display key.
      08-30-2017, 08:00 AM   #3
FlashedVirus0
BMW Lover
Thank you for the information. I'll contact a local dealer and get a quote.
      09-19-2017, 10:16 AM   #4
wilho
Finland
Drives: BMW X5 45e -20, 225xe -16
2020 BMW X5 45e  [0.00]
2016 BMW 225xe  [0.00]
Hi,
My friend has all the above options including the display key, what is needed on top of that to enable remote parking?
Local dealer had said that not possible.... Which I didn't believe as all the needed hw should be there.
Br, Ville
      09-19-2017, 11:51 AM   #5
mobilejo
mobilejo's Avatar
Drives: G06 X6 40i
The following options are needed for remote parking according to the G30 technical manuals (Driver Assistance Systems manual available in the sticky on the main G30 general chat forum):
• Steptronicsporttransmission(OE*2TB)
• ComfortAccess(OE322)
• BMWdisplaykey(OE3DS)
• ParkingAssistantPlus(OE*5DN)
• Professionalnavigationsystem(OE*609)
Those options contain all of the required hardware, I didn't know comfort access was required but apparently the comfort access antenna is needed for the RC parking
      09-19-2017, 01:17 PM   #6
wilho
Finland
Yes, he has all of that so whats the next step?
      09-19-2017, 01:52 PM   #7
mobilejo
mobilejo's Avatar
Drives: G06 X6 40i
That, I can't help with - sorry. Almaretto is a coding expert - he will probably chime in when he comes online
      09-19-2017, 04:38 PM   #8
mobilejo
mobilejo's Avatar
Drives: G06 X6 40i
I have just noticed - there is another antenna solely for RC parking mounted in the boot/trunk lid.
See part 4 here: http://www.realoem.com/bmw/enUS/show...diagId=65_2644
It appears to only be installed in cars with RC parking based on the wording on RealOEM.
Therefore, you will not be able to simply code the feature -new hardware will be required.
      09-22-2017, 10:25 PM   #9
Almaretto
Almaretto's Avatar
2374
Drives: Test Vehicles
I doubt you can just code it into vehicle, but never looked into it.
      08-30-2019, 07:07 AM   #10
dukabo
Drives: bmw g30 530xd
Hello everyone! I'am struggling with this 5DV option. I just need to order this antenna no.4 part 65209351015 ? or i need something more from hardware..
Thanks!
      09-07-2019, 07:53 AM   #11
roxxor
roxxor's Avatar
1141
Drives: 2024 iX50
Thanks!
Assuming you have all the prerequisites, you would need the antenna, the wiring/connector (61119861132), and of course, the new display key remote with the Remote Parking button.
      09-20-2020, 04:19 PM   #12
jkwhar
Drives: F30 328i Xdrive | F15 x35i
Just bringing up an old thread, so technically, I didnt purchase the g30 yet as the market is a bit low on inventory but just doing some research on the car in the mean time.
With that being said, looks like to do the retrofit, the additional hardware it needs are:
aerial antenna in the rear bumper and remote control receiver. As far as wiring goes, they both go into the BDC. Again, this is just from viewing the document below. There could be more to it that I may have missed.
https://www.newtis.info/tisv2/a/en/g...ems/1VnYq2TVR3
Did my post help? Click "Appreciate!"
FOR SALE! Sport line Steering wheel with heated, paddle shifter, vibration motor, no airbag | EDM Bi-Xenon adaptive headlights (SOLD) | surround view retrofit kit (sold) | KAFAS2 camera and ECU | FLA camera(sold) | 6WB cluster (SOLD)
      09-21-2020, 03:25 PM   #13
roxxor
roxxor's Avatar
1141
Drives: 2024 iX50
You are correct, those 2 are the only additional items needed outside the Display Key. Be aware though, BMW has cracked down on the sale of the Display Keys, so unless you purchase a car that was able to have the feature initially from the dealer, such as a 540i/M550i, you most likely will be very hard pressed to get the display key.
      09-21-2020, 03:27 PM   #14
jkwhar
Really...wow, I wouldn't have thought that getting the digital key was going to be an issue at the dealer. Can a 2nd hand key be reprogrammed?
      09-21-2020, 03:55 PM   #15
mrgicm
mrgicm's Avatar
441
Drives: BMW M
There is no solution to aftermarket programming of a used Display key. Also if your car does not have a option for remote parking BMW will not issue you a Display key with the remote parking option.
      01-30-2021, 01:58 PM   #16
TheRealNo7
Drives: BMW G31 530d xDrive
Hi guys, I was just wondering if anyone has progressed further with this now?
I have just taken delivery of my 2017 G31 530d xDrive today with all the prerequisites and would love to retrofit Remote Parking.
      02-03-2021, 06:24 AM   #17
Danijelb
Drives: BMW 520d xDrive
I hate these digital keys for some reason.
      06-20-2022, 03:15 PM   #18
chris_sd
Drives: 530e
Anyone had any luck with this?
Chris
      06-20-2022, 03:48 PM   #19
The Zimmer
Drives: BMW G31 Touring
New key is £650
      07-08-2022, 01:18 PM   #20
Frans
Drives: 520i G30 2020
My G30 came with a display key but…..
This display key does not have the park button on the right side.
So for people that think they are nearly there cos they have the key, you may need a slightly different one. For images please look here:
https://www.autoblog.com/2017/07/07/...x73EILGugwxDrK
      08-08-2023, 07:56 AM   #21
G30_520D
Drives: BMW 520d (G30)
It seems that I have all the necessrry options preinstalled on my G30:
322-Comfort Access
2TE-Steptronic transmission with shift paddles
5DN-Parking Assistant Plus
3DS-Remote Display Key
VO coding is not a problem for me.
But my display key does not have a Remote Controlled Parking--Button on the side.
What can I do to use it anyway ?
How to activate Remote Controlled Parking-Menu in the display key?
      08-10-2023, 05:25 PM   #22
The Zimmer
I have done this retro fit, you need the display key with parking button to activate cost me £500 for new key
5post
