BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > F30/F32/F33 Classifieds (For Sale / Trade / Wanted) > Members Classifieds > Electronics: Audio / Video / Phone / Alarm / Navigation / Radar > Jl Audio Subwoofer With Everything U Need.....
European Auto Source (EAS)
      09-11-2017, 10:19 PM   #1
ronin_pdx
Drives: m4
BIMMERPOST / Classifieds
Asking Price:
Sold
✓ Will Ship
Item Interest
Hello folk, I have here a JL subwoofer and AMP ready to install today. This kit comes with everything you need to install to your HK system, if you dont have Harman Kardon system the hardware will still work. There is no cutting thanks to a T adapter to the factory Amp. Once it goes to LC2i audio control base filter then to the momoblock JL 600/1 AMP this puppy sound good specialy coming from 2017 10w6v3 sub. With all the wires and bracket you will be ready to go. My lease is coming up in a few months Im slowly parting out my parts. This kit came from Musicar northwest in Portland they are usually on forms thats how I found out about this kit.
$400
JL Audio 10W6V3-D4 10" 1200W Dual 4 Ohm W6 Series Car Subwoofer
Power Handling:
Peak: 1200 watts
RMS: 200 - 600 watts
Mineral-filled polypropylene cone
Nitrile-butylene rubber surround
Elevated Frame Cooling
DMA Optimized Motor structure
Cast Aluminum basket
Push terminals
Terminal Jumper System
Single stacked ferrite magnet
Resonance Frequency (Fs): 30.12 Hz
Top-mount depth: 4-5/8"
Sensitivity: 82.7 dB
Recommended Enclosure Type: Ported / Vented Sealed
Optimum Sealed Box Volume: 0.628 cubic feet
Optimum Ported Box Volume: 0.828 cubic feet
Weight: 26 LBS
JL AMP XD600/1- $280
Rated Continuous RMS Power @ 14.4 V
600x1 @ 2 ohms
500x1 @ 3 ohms
400x1 @ 4 ohms
Rated Continuous RMS Power @ 12.5 V
500x1 @ 2 ohms
400x1 @ 3 ohms
300x1 @ 4 ohms
Frequency Response 7 Hz - 500 Hz (+0, -1dB)
THD+N at Rated Power <1% at 2 Ω per Ch.
S/N Ratio, referred to highest rated power >87 dB below rated power (A-weighted, 20 Hz - 20 kHz noise bandwidth)
S/N Ratio, referred to 1 W >59 dB (A-weighted, 20 Hz - 20 kHz noise bandwidth)
Input Voltage Range at RCA Inputs 200 mV - 8 V RMS
Fuse Rating 50 A (AFS, AGU or MaxiFuse™)
Freq. Response 12 Hz - 22 kHz (+0, -1dB)
Damping Factor at 4 Ω >1000 / 50 Hz
Damping Factor at 2 Ω >500 / 50 Hz
Source Ch. Selection for PreOuts N/A
Remote Level Control Optional (HD-RLC)
Filter Slope (dB/Octave) 12dB or 24dB
Filter Modes Low-Pass only
Filter Freq. Range 50-500 Hz
Infrasonic Filter 30 Hz, defeatable
Width 8.52 in / 216 mm
Height 2.05 in / 52 mm
Depth 7.09 in / 180 mm
PENDING-SALE
Car Audio 2-Channel Line Output Converter (LC2i)
Model: LC2i
12 Volt trigger output
GTO - Signal sensing inputs
Dual amplifier, 9.5 Volt pre-amp outs
AccuBASS processing for correction of bass roll-off
Fixed and variable outputs with discrete level controls
Dimensions: 6-3/8"W x 3-1/8"D x 1-1/2"H
OE-Look Subwoofer enclosure- $280
The Musicar OE-Look for the F32/F82 platform is very similar to the F30/F80 sedan design. Replacing the battery access door, its lines flow into the design of the trunk. It’s easily removable in case access is required. It can accept a wide range of subwoofers, and its impact on the load-floor area is almost nil.
PENDING-SALE
harnesses and interconnection systems are engineered to be 100% PnP and electrically matched to OEM systems. No OEM wires cut, spliced or tapped required. 100% reversible back to OEM. No OEM errors or induced defects to your OEM system.
https://photos.app.goo.gl/7ZdQECgyzkkJkMog2
https://photos.app.goo.gl/nDOxnnKrXqXgSfSG3
https://photos.app.goo.gl/FBfMdPM5cxmWPW4Y2
https://photos.app.goo.gl/PhC6txgqcIZ2uyQl2
https://photos.app.goo.gl/ivdx1LgMDFHPDuK52
https://photos.app.goo.gl/bglz4KKJJsfzQ8A22
https://photos.app.goo.gl/XnKx6rMidOorAZGB2
https://photos.app.goo.gl/89vpbxfBROkdEIun1
https://photos.app.goo.gl/Tqvr0hC8OAcxs8BI3
https://photos.app.goo.gl/7HMToFqSnslrazmE3
https://photos.app.goo.gl/JgvBRLadf7H5jgxJ2
https://photos.app.goo.gl/xBN8dSQeVsgLeUZH2
https://photos.app.goo.gl/ysI8c8p0CLtDHbHh2
Any question fill free to ask...
      09-12-2017, 12:08 PM   #2
ronin_pdx
Drives: m4
bump
      09-12-2017, 02:05 PM   #3
1QuikWS6
No 55mph
1QuikWS6's Avatar
Drives: F32 435ix MSport ->M6
None of your pics show up - Photobucket has had a new rule about 3rd Party Hosting for some time now - for anyone to be able to view the pics the way you posted them they would have to pay hundreds of $$ per year
So basically, no one is gonna see them...
You need to go back & post them the long way using the 'Share' & Direct Link' method while in Insert Image forum icon - or use a different hosting site
F32 435ix//MGM//M Sport-Prem-Tech-Driver Assist-Lighting-Cold Weather-Dyn Handling Pkgs//M4 Black Leather Int w/M4 Alum Blade Trim//HK Sound+Musicar Stg3//763M Wheels//M4 Euro LCI Tails//M4 Mirrors w/CF Covers//AWCarbon CF F/R Spoiler-LED Sills-CF Shift Knob/Surround/IND M4 Alcantara Armrest//PURE S2 Turbo//AA FMIC+DP//ER CP+TIC//3.5bar TMAP/TS DV//AWE Tuning Exh w/Blk Tips//Dinan CF Intake//BM3 Cary Jordan Tune//MPerf Diff//PrecRW Ignition Kit
      09-12-2017, 04:16 PM   #4
ronin_pdx
Drives: m4
thank you its driving me nuts
      09-12-2017, 04:35 PM   #5
ronin_pdx
Drives: m4
I did google photos hope this works guys. let me know if you cant see them
      09-12-2017, 04:42 PM   #6
1QuikWS6
No 55mph
1QuikWS6's Avatar
Yup
      09-12-2017, 08:24 PM   #7
ronin_pdx
Drives: m4
      09-14-2017, 12:49 PM   #8
ronin_pdx
Drives: m4
Hello Folks I can sell the Box by its self or sub an amp together or wiring harness and the LC2i together
      09-14-2017, 03:24 PM   #9
ronin_pdx
Drives: m4
lowered price
      10-01-2017, 08:36 PM   #10
mazy330
Drives: f30 328xi
hey, still selling?
Interested in enclosure.
thx.
      10-01-2017, 08:41 PM   #11
LiquidMercury
Drives: 2012 F30
Originally Posted by mazy330 View Post
hey, still selling?
thx.
+1
What's left (if anything)?
