BMW X3 Forum
BMW X3 Forum
Welcome to the ultimate BMW X3 community.
      09-15-2017, 01:55 AM   #1
tyranimo
Drives: 228xi
2018 X3 Rim Bolt Pattern
I'm going to be on the hunt for new rims for the incoming X3 winters and I would just like to ask if there would be any way that we could get confirmation for the new rim specs.
Would 5x112 and 35mm offset for 19 inchers be a safe bet?
      12-07-2017, 07:59 AM   #2
vince1288
Drives: F48 Sdrive 20i
It should be very safe if you don't lower down the car.
Mine X1 F48 with KW V3 pretty low and run with 19" 8.5J ET32 wheels. Sometimes scratch rear arch, but its OK.
You should go 20"+, which is much fit on the G01.
      12-07-2017, 09:41 AM   #3
BMWDude2018
BMWDude2018's Avatar
101
Drives: 2014 X5 5.0i
2020 X5 M50i  [0.00]
2018 BMW X3 M40i  [0.00]
2014 BMW X5 5.0ix  [0.00]
19" will be fine as that is the stock size for the M40i, which has larger brake calipers. Your post didn't say whether you're fitting an 3.0 or an M40i. But the 3.0 with MSport may have the same brakes, so you should avoid 18" as some barrels may be too tight for the brake set up.
5x112 is the correct bolt pattern.
I don't know the stock offset, but 32-35mm seems about right. You could buy what you want and test fit them to make sure they clear the brakes and suspension. If they rub, then you would have to buy spacers.
If you were to change the tire size so that you had a larger overall tire diameter than stock, then you may run into rubbing in the wheel housing. However, TireRack and other places have simple calculators to ensure that you are with 1-2% of stock diameter. This will ensure that your wheels won't rub and also keep your speedo closer to stock accuracy.
      12-07-2017, 11:00 AM   #4
tyranimo
Drives: 228xi
Sorry this is a very old thread!
Ive found out that the bolt pattern is indeed 5x112
Also the offset for 8.5J is ET30
      12-23-2017, 03:14 AM   #5
Rudy Fox
Russia
Drives: BMW X3 G01 2.0d M-Sport
May be you have wheel hub diameter? The old one on F25 was 72.6 mm.
      12-23-2017, 03:51 AM   #6
voyagergab
voyagergab's Avatar
Drives: G82 M4 6MT, G01/F97 X3M
Hub diameter is 66.6mm for G01
      12-24-2017, 02:30 PM   #7
Rudy Fox
Russia
Thank you very much for info.
Got mine G01 Phitonic 2.0D M-Sport Launch Package couples days ago with winter 18" disks 688 style/Pirelli (for Summer loaded 19"/698/Bridge Alenza).
Regretfully could not find anythere official releases re full specs of all kinds of disks for G01((
      01-01-2018, 04:18 PM   #8
Ge0rge
Drives: G01 B47
Hello Rudy, do you have pics from your car (sideview) with the 688 rims? I hoped that their design make them look bigger than they are
And what suspension setup do you have and hows the ride?
      01-04-2018, 02:58 AM   #9
Rudy Fox
Russia
Not a sport suspension - regular one. Drives smoothly and noiselessly. I did own F25 I and G01 is on more higher level.
Attached mine Phitonicblau with 688/18".
Here you can find pics of white G01 with 688 onboard - https://www.drive2.ru/r/bmw/489107028451524708/
      01-04-2018, 01:29 PM   #10
Ge0rge
Drives: G01 B47
Thank you very much - looks quite good - congrats to your car.
Does your setup with the 18" feel good and "planted" also in faster corners?
Have fun!
      01-05-2018, 03:40 AM   #11
Rudy Fox
Russia
You must be kidding abt this babe "planted" in faster corners, huh! ! With this set you driving like on the child's slow rocking bed instead!
      01-05-2018, 08:40 AM   #12
Ge0rge
Drives: G01 B47
Hehe I was expecting to hear that it is that unsporty .
Do you have Runflat? Should help on cornering agility a little bit...
Currently I hope that 18" Runflat with M suspension (but no damper control) will be a good comfort/sportyness compromise...
      01-05-2018, 09:13 AM   #13
Rudy Fox
Russia
Will test native summer Runflat set by early spring someday. Winter set above is on the regular tyres.
      04-27-2018, 06:34 PM   #14
barrypan
Drives: X3
I got different bolt pattern 5x120 from 1010tires.com
      04-27-2018, 08:16 PM   #15
arciga18
arciga18's Avatar
1729
Drives: LeMans/ Chestnut E90, RWD
They are wrong. 5 x112
      04-28-2018, 01:25 AM   #16
Rik762
Drives: 2022 X5 M50i
I believe that is the 'old' X3. (series 2)
      04-28-2018, 03:07 PM   #17
Rbrown
Scotland
2763
Drives: X3 M40i
F25 is PCD 5 x 120
G01 is 5 x 112
      04-28-2018, 03:45 PM   #18
arciga18
arciga18's Avatar
1729
F25 is PCD 5 x 120
G01 is 5 x 112
Yea and almost every other Bmw since they did 4x100.
I assume the person that posted read through the thread and was asking about the g01. Otherwise, why post in this subforum.
That 1010 tires website is probably scraping wrong model information.
      05-02-2018, 09:36 AM   #19
barrypan
Drives: X3
does anyone know the stud size? 14x1.25 is the correct one?
      05-02-2018, 09:44 AM   #20
barrypan
Drives: X3
Sorry, I should say 'bolt size'.
      05-02-2018, 10:31 AM   #21
yllwwgn
yllwwgn's Avatar
170
Drives: 2018 X3 M40i
Location: Milky Way, Earth, North America, Arizona more specifically.
That is correct.
      05-02-2018, 10:55 AM   #22
barrypan
Drives: X3
Originally Posted by yllwwgn View Post
That is correct.
Thanks
xbimmers
