| 11-09-2017, 04:42 PM | #1 |
Rep 29
I live in US. MY car is stop at speed 135mph.. I know the car can go more than 135mph.. but I have been looking and searching. Nobody can able to have this software to delete the speed limiter aka speed governor..
"The only one"
| 11-09-2017, 05:36 PM | #3 |
![]() ![]() ![]() 210
Rep 487
It's part of what comes with bootmod3, and I assume MHD when they release their F series flash in December.
2013 ActiveHybrid 3 (335ih) • N55 PWG • Meisterschaft GT catback • Wagner tuning catless DP and Stage 2 Evo Comp Intercooler • ER chargepipes • CTS intake • io2V3 O2 simulator • Pure Stage 2 turbo with high-flow inlet and DV upgrade • Fuel-It Stage 2 LPFP • JB4 ISO firmware • Fuel-It DIY PI Kit • bootmod3 •
| 11-11-2017, 08:49 AM | #4 |
Rep 1,778
My M Sport 335 can and does surpass 155 mph. I think I bounced the speedo at 160 and the car was still going when I let off at 165 on the HUD
13' 335i M Sport. EBII/Coral Red 6MT. RPI GT exhaust, Resonator delete, PS1, GFB DV , BM3 Stage 2, ER CP, VRSF DP, VRSF 5.5in Stepped FMIC, Dinan Shockware. Carbon M Performance rear diffuser. M4 trunk lip. Conti DWS06 225/40/19 and 255/35/19
| 11-11-2017, 10:55 AM | #5 |
Rep 18,322
It can if it wasn't limited to 135 at the factory. That's done when the car doesn't come equipped with tires rated for more than 135. Per Shawn Sheridan:
If DME has more than 10 hours on it, you cannot remove VMAX via Coding. Adding S840A High speed synchronisation and coding DME won't do anything either. We tried everything, and got no where. |
| 11-11-2017, 10:56 AM | #6 | |
Rep 1,778
| 11-11-2017, 11:41 AM | #7 |
Rep 487
Again, if you want to remove the limiter, you need a DME flash like bootmod3. There are other bench flashes (like the one from Eurocharged https://www.eurocharged.com/products...-series-en/f3x) that do the same, but the only way to do it currently is to flash the DME (meaning you need to pull the DME).
The highest speed I've seen flash across my HUD after bootmod3 was 164MPH, so I know there's no 155MPH limit anymore (as advertised).
| 11-12-2017, 12:23 AM | #8 |
Rep 306
I seem to remember this option to remove when I ordered my car on the build sheet.
Is it listed as an option in a VIN Decoder, such as where they decode no dazzle high beam and variable light distribution? Last edited by kabrichx; 11-12-2017 at 12:29 AM.. |
| 11-13-2017, 02:19 AM | #9 |
Deceased
12491
Rep 1,985
Your average speed limits through the states are 55mls? So whats this all about? Ey?
Citizen of ///M - Town, where too much is just right Some say, that my scrotum has its own small gravity field and when Im slowing down that brake lights come on at my buttox ![]() |
| 11-25-2017, 05:48 PM | #10 | |
Rep 1,093
Instagram: M2_Medusa
| 11-26-2017, 02:07 AM | #11 |
Rep 487
| 11-26-2017, 08:33 AM | #12 | |
![]() ![]() 2029
Rep 7,144
Drives: 23 G42 M240, 22 G01 X3 30i
That said, I'd certainly hate to have a tire failure at 160 MPH on ANY road. Maybe an old airport runway or a closed track would be one way to avoid causing a serious accident involving other vehicles.
2023 G42 ///M240i Coupe 8AT Portimao Blue, 2022 X3 sDrive30i 8AT Brooklyn Grey
| 11-29-2017, 01:49 PM | #13 |
335i F30
68
Rep 252
I have hit 152 and she was still going. It's governed at 155 i believe but i think the tune deletes it.
13' F30 335i Mineral White Metallic
Sport Package | 19" Rotiform SPF | BC Coilovers Coral Red Interior | H/K Package Active Autowerke Flash Tune, FMIC, Exhaust | BMS Intake | VRSF DP | VRSF CP |
| 11-29-2017, 02:58 PM | #14 | |
Rep 45
| 07-22-2022, 01:36 PM | #15 |
Rep 13
limit
hi, I have a 2017 320i Sport GP, in my country a flex car, with stage 1 remap, and filter, with the ECU programming the speed limiter was removed, it was at 245 km/h, now it passes 260 easy.
| Bookmarks |
| Tags |
| speed ., speed limit |
