BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > F30 DIYs and Coding Discussions > **Confirmed!! Enhanced Bluetooth w/ BIMMERCODE
      03-08-2018, 04:46 PM   #1
Tchao
Boost Addict
Tchao's Avatar
387
Drives: E30, E82, F30, F87
Hey guys I recently used Bimmercode to code Enhanced Bluetooth (music on phone to car).
HUGE thanks to Danny Montes for guiding me though this.
Yes it is possible to use Bimmercode to code EBT.....IF you have the combox.
You need to have a comibox in the truck to do this (see attached pic to verify)
It is SUPER easy.
You will need to go into Expert Mode in two menus.
In HEADUNIT Menu...go into Expert mode then 3003_Telefon_Telematik_Online
Turn these to "Aktiv" :
  • CDMM_Bluetooth_Audio
    CDMM_BT_DATABASE
    AUDIO_PLAYER_ON_OFF
    BT_MODUL_ON_OFF
    A2DP_PROFILE
In COMIBOX Menu....go into Expert mode then 3004_Bluetooth_Parameter and turn this to "Aktiv" :
  • A2DP_AVRCP_EIN_AUS
Its that simple.
Hope this helps!
Again Thanks again to Danny Montes!!! All credit goes to him!
-San
S55 M2C | Three Pedal Club | E30TU
Appreciate 16
      03-18-2018, 01:42 PM   #2
Youngjnr
Drives: BMW E90 + BMW F30
did you get album art too?
      03-20-2018, 11:14 AM   #3
Derebas
Drives: 2013 335 xdrive 6MT
That's great news! Thanks for the write-up.
Will this also work with CIC system? I have a 2013 F30 with combox in the trunk.
      03-20-2018, 02:40 PM   #4
Tchao
Boost Addict
Tchao's Avatar
387
I think it should? I have CIC also unless Im mistaken.
Mines a 2012 HK audio but no EBT.
Negative
      03-20-2018, 03:24 PM   #5
Youngjnr
Negative
you should get album art now if you use usb
      03-21-2018, 08:22 PM   #6
F30Ralph
Drives: Havana Brown 2014 320i Xdrive
It works!! I can finally listen to my music without plugging in a stupid cable!! I’m so happy!!
I followed the instructions and did exactly what Tchao said to do.
Thank you so much!
      04-01-2018, 08:40 AM   #7
F30_2014
Drives: 320d
Can anyone help me in this, I have a COMBOX in the boot and when using BimmerCode comes up CIC. I used the settings listed above and it now appears in the media menu but my phone will no longer connect. Both the audio Bluetooth menu and phone menu state please wait. I deleted the car from Bluetooth to see if it would reconfigure and it won’t connect, I also deleted my user profile to see if the car would forget my phone but that hasn’t made any difference. Any help would be appreciated.
      04-01-2018, 09:54 AM   #8
Tchao
Boost Addict
Tchao's Avatar
387
Did you try connecting in External Device.
Its a little ackward that the connection is not under Bluetooth...but rather in the external device menu.
      04-01-2018, 10:26 AM   #9
F30_2014
Drives: 320d
No I only went into telephone and Bluetooth audio with both stating please wait, Stephan from bimmercode sent me a code to check which is correct but still states please wait -just to update it makes no difference going into external devices. youngjr seemed to have had the same problem - http://f30.bimmerpost.com/forums/sho....php?t=1478925
      04-01-2018, 12:12 PM   #10
F30_2014
Drives: 320d
Just to update it’s now working thanks for the replies, for anyone else having this issue one of the settings from the top of the page was left in. When I reverted to back up and set the settings provided by BimmerCode which as the same as the link as above it worked fine. I’m using and iCar 2 WiFi and had numerous issues with it losing connection and timing out, had to check what was set right as default and quickly change ones required.
      04-18-2018, 09:18 PM   #11
kaiotonussi_2
Drives: 320i F30 Sport GP
Have you coded FA from 6NH to 6NS or it works fine just with the code of the link above? Thanks!
      04-21-2018, 12:57 PM   #12
Salty B.
Drives: 2014 335i MSport, 2001 X5
BCode doesn't work that deep in the ECUs. Use the settings in the original post.
2014 F30 N55 6MT, gray/red, M-sport, VMR 710/Mich PS 4S, MPPK, MPE
2001 E53 M54 5MT green/black, well-optioned
      04-22-2018, 12:59 AM   #13
rak299
Drives: 2025 M3 Base
does this add office functionality?
      04-29-2018, 12:18 AM   #14
JLBMW
Drives: 2015 428ix GC
^^^^^ Looking to program Mobile Office as well. I see several coding lines that include SMS_EIN, TEXT_NOTES that I'm assuming are for Mobile Office.
      04-29-2018, 11:46 AM   #15
JLBMW
Just used Bimmercode in Expert Mode. Followed this post - http://f30.bimmerpost.com/forums/sho....php?t=1478925 only had to change about 10 lines. Hint, although the coding is not listed in alphabetical order, within Bimmercode you can use the search (magnifying glass) to easily get to the line items to confirm and/or change the settings. FWIW, best to delete your BT pairing before starting the coding process, then re-pair after the coding process is complete.
All Mobile Office features seem to work (as does the voice command button on the steering wheel, others have reported that it becomes disabled), although, since I use K9 email for android, looks like I may have to also use the default email app for my emails to populate. Hopefully I find a "fix" or settings change to avoid having another email app...and data on my phone.
      05-23-2018, 01:27 AM   #16
RoopD
Drives: F30 Alpine Weiss
Guys,
Will this really work as in post #1?
I have a combobox as shown in the picture.
CDMM_BT_DATABASE
AUDIO_PLAYER_ON_OFF
BT_MODUL_ON_OFF
A2DP_PROFILE
A2DP_AVRCP_EIN_AUS
I cannot find CDMM_Bluetooth_Audio
I dont see ecu Combibox
What to do?
Greet
RoopD
      07-08-2018, 07:38 PM   #17
R44HXL
Drives: 2016 BMW 535d
Originally Posted by RoopD View Post
Guys,
CDMM_BT_DATABASE
AUDIO_PLAYER_ON_OFF
BT_MODUL_ON_OFF
A2DP_PROFILE
A2DP_AVRCP_EIN_AUS
What to do?
Greet
RoopD
Also having this problem.
      07-08-2018, 10:50 PM   #18
LILRAPOHIO
Drives: BMW 2014 320i X-Drive
Same here. Someone help! Also after EBT, Can I code sport + mode or launch control using BimmerCode?
      08-01-2018, 03:44 PM   #19
Damage Inc
Damage Inc's Avatar
970
Drives: 2017 M2
Did this today and it worked!!!!!!!!!!!!! many thanks
Current: 17 OG M2 / 21 Huracan EVO
Past Performance Cars: 01 M3, 05 M3, 06 M5, 08 M6, 08 M3, 11 M3, 13 M3, 15 M3, 911 C4S, 911 GTS, 17 M2,R8 V8, R8 RWS, 22 R8 Perf, 22 Lambo EVO
      08-01-2018, 03:45 PM   #20
Damage Inc
Damage Inc's Avatar
970
Drives: 2017 M2
Now that I have BT Audio working. Is there a way to play music via the USB cable? I can see it as an option in the idrive, but its grayed out.
      08-02-2018, 02:25 PM   #21
rickynguyen
Drives: Bmw F30 320i sedan
My car not equiped with the combox, what is part number to buy ? Thanks
      08-30-2018, 07:15 AM   #22
robbiox
Drives: f30 330d m-sport + xdrive
a2dp enabled ! Hooray
Hi guys
I've been reading this website for a while now and just wanted to say thanks for your posts, i've just successfully enabled my bluetooth audio and also realised I have an extra 12v power supply (cigarette lighter socket) under my passenger side glove box!
One additional comment to other peoples bluetooth experiences.. After using vgate and Bimmercode to tweak everything in expert mode, I deleted the pairing, repaired and it still didn't show bluetooth audio.. I accidentally stumbled upon another menu in the main idrive area for 'connectivity' which now had a 'bluetooth' checkbox for audio... that wasn't there previously. Once that was ticked, I returned to my bluetooth pairing on the idrive for my handset and the tickbox had appeared for 'audio' under the phones services (where calls was previously the only option). it wasn't ticked, as soon as I ticked it, i was able to stream spotify etc from my handset and control tracks via the steering wheel. I had quite quiet audio on bluetooth until I tweaked the amp settings as they were all nuetral for bluetooth, whilst FM/ DVD / aux in had been customised before.
Hope that maybe helps someone else who nearly gave up with bluetooth.
After that tweak, i went on the tailor the following annoyances out of my vehicle.
1) The car no longer unlocks the drivers door when you turn off the ignition.
2) Door handle lights now activate whilst reversing.
3) 'stop / start' no longer defaults to 'on'
4) lowered the PDC cut out speed (36kmh was too fast)
5) increased the headlight washer operation frequency
6) enabled digital speedo
7) changed the idrive startup animation to m
8) changed the standard warning bong
9) DVD in motion
10) USB video + extra codecs
I loved my car anyway, but now I am even happier as the silly things that (overly) bugged me are gone and I have new toys to play with.
Anyone recommend anything else cool to enable?
thanks and happy driving always !
