BMW 5-Series (G30) Forum iDrive, Audio, Bluetooth, Phone, Cameras, Electronics + Coding G30 Speed Limit Info
      03-13-2018, 05:07 AM   #1
sjak92
sjak92's Avatar
Drives: G05 30d MY24 + G20 M340i MY24
Hi Guys,
Been playing around with Bimmercode App, using lots of resources found online and expert mode, I managed to code some stuff like accoustic lock, tyre temperature and I think I managed to code enhanced bluetooth as I get all the check boxes for email sms etc, just need someone to text me!
Anyway, more to the point,im really interested in SLI
The app finds the KAFAS ecu which I believe is necessary?
I have coded the European signs to active, I also did some coding in Headunit and Instrument cluster that I found for Speed Limit
However, no luck. I do have "- - -" displaying where the sign should be and in Eco Pro, when the speed limit is about to change, instead of showing MPH in a blue circle like id did before, it now actually has the new upcoming limit in a little blue circle.
I also noticed that when I press the Speed Limiter button on my steering wheel, it lights up grey rather than green.
Do i need an FSC code like for Apple Car Play? Can this be done or am I wasting my time?
Many thanks in advance
      03-13-2018, 05:21 AM   #2
babaikram
M6GCComp, Porsche Cayman S PDK, Peug 208 GT1 BPS
Drives: .
I am also interested
      03-13-2018, 09:49 AM   #3
saintalan
England
Drives: G30 520i (2018)
Me too, think you have a following!
Cheers, Alan
      03-16-2018, 05:44 PM   #4
sjak92
sjak92's Avatar
Bump?
      03-16-2018, 06:49 PM   #5
Short540
Short540's Avatar
Drives: X5 50i
2019 BMW X50i  [0.00]
I have the bimmercode app for g30. What can you do in expert mode. Any tips would help.
      03-17-2018, 01:41 AM   #6
Almaretto
Almaretto's Avatar
2374
Drives: Test Vehicles
Head unit functions like removing disclaimers.
E-sys is better choice.
kitster541.00
      04-13-2018, 08:21 AM   #7
BMW2018
Drives: BMW 530D
Hi Folks, I have a M Sport 530D 2017, I'd like to be able to access the speed limit information too. I have adaptive headlights so I believe I have the required hardware. Is it difficult to code these sorts of things? Thanks.
      04-13-2018, 09:17 AM   #8
csm7djs
Drives: G05 X5 3.0d M-Sport
This can be done, but you need an FSC code. These can be obtained from other forum members at a cost.
      04-13-2018, 10:04 AM   #9
BMW2018
Drives: BMW 530D
Thanks, do I need leads etc... Ive never attempted anything like this, is it a tricky task?
      04-13-2018, 11:13 AM   #10
AP
AP's Avatar
2783
Drives: G30 M550
Esys yes you will require a Ethernet to obd cable and a windows laptop
      04-13-2018, 11:24 AM   #11
BMW2018
Drives: BMW 530D
Thanks again, just been looking at you tube about the BimmerCode App and a wireless OBD2 plug. Is this an option anyone knows of or has tried, maybe better to go to a specialist? Thanks
      05-05-2018, 02:35 PM   #12
babaikram
Drives: .
Originally Posted by sjak92 View Post
Hi Guys,
I have reached exact the same point as you in the post above. Have you moved further forward. if you had. what have you done in addition?
      05-05-2018, 02:41 PM   #13
Almaretto
Almaretto's Avatar
2374
Requires KAFAS FSC code or emulator. Without, coding will not work.
      05-05-2018, 02:43 PM   #14
babaikram
Drives: .
I have always wondered how and where is one going to enter an FSC code if one gets it all?
      05-05-2018, 02:53 PM   #15
Almaretto
Almaretto's Avatar
2374
Into ECU using E-sys.
      05-06-2018, 04:50 PM   #16
babaikram
Drives: .
Does this look like FSC code: FSC_VD72321_01200057.fsc
Extracted whilst updating navigation map through USB?
Are FSC codes specific for each function in the car or a code could be used for different functions?
      05-06-2018, 04:53 PM   #17
Almaretto
Almaretto's Avatar
2374
FSC codes are different for each function. Sometimes multiple FDL's are required for functionality.
      05-07-2018, 05:30 PM   #18
babaikram
Drives: .
Thanks
Acceleration is heavenly
      05-08-2018, 11:58 PM   #19
Almaretto
Almaretto's Avatar
2374
Thanks
      05-16-2018, 07:33 PM   #20
valrossi
Drives: F10 523
If using sli emulator, how to code about it for SLI to work?
      05-21-2018, 02:55 PM   #21
hurricane876
Drives: G30
Speed limit info - G30
Hi Guys,
Anybody know that is the "clock" icon next to the speed limit info?
I checked the user manual but no any mention...
Thanks
      05-22-2018, 08:01 AM   #22
matt666
Drives: 330d
Can you pay BMW to enable this? Assuming you have the right hardware of course.
5post
