03-15-2018, 06:48 PM | #1 |
Rep 115
Jb4 experts for 335xi
Hey experts, recently I installed a jb4 on my car and it seems slower and more restrictive that when I just had Dinan sport tuner.
Anyone have same or similar experiences, I was running Dinan sport tuner on racing which was 4psi+ Current mods: Intake MPPK MPE I do have Wagner competition intercooler, chargepipe and AR catted downpipe coming. Just curious as to why it was less responsive and slower than the $200 Dinan tuner. I am assuming my other mods will compliment the jb4 better but did I make a mistake not going with a vf engineering flash tune or something different? Thanks Newer to my bmw so I'm trying to learn it all |
03-15-2018, 06:52 PM | #2 |
Rep 115,999
The JB4 has full data logging so record a log and add it to the thread or email it to bms so they can see what's going on for you.
Mike |
03-15-2018, 07:01 PM | #3 |
Rep 2,361
All the experts are at N54tech.com
Only time I would recommend JB4 is if you want to run WMI also
(A Dane in China) |
03-15-2018, 07:14 PM | #4 | |
Rep 115,999
Mike |
03-15-2018, 07:42 PM | #5 |
Rep 2,361
Flash vs JB4 is about so much more than just peak numbers. This must be the most talked about topic on all of BimmerPost..........but for me the numbers and WOT experience is only 20% of it. The rest is response, feel of integration, smoothness, shift quality (on the automatic) - on all of these parameters I feel the JB4 fall short. I have 4 years of experience with the JB4...and it is great at many things!
(A Dane in China) |
03-15-2018, 08:30 PM | #6 |
Rep 262
Drives: 2013 BMW 335i M-Sport
Sounds like something is very wrong. Did you buy the JB4 new or used? Have you attempted to disconnect and reinstall?
With the JB4 installed correctly you should feel a MASSIVE difference in map2 VS the Dinan tune. I highly recommend reaching out to BMS to troubleshoot. Their service is great! |
03-15-2018, 08:42 PM | #7 |
Rep 5,776
You did check to see what map it is on right?
Last car: 2011 335i Msport. JB4. Vrsf CP |
03-15-2018, 08:52 PM | #8 |
Rep 115
Thanks for all the feedback.
I have checked map I have the Bluetooth connected and it has been back and forth from Map 1 and 2. With my Dinan Tuner I typically see the sport cluster gauge go between 340-360 torque and 320 hp at 80-100% throttle. It doesn't seem to be activating full boost as my intake is not as loud nor does my exhuast get the kick it typically has. Ranges have been around 300hp and 320-330 torque on the cluster. I have verified connections and all it good. Question I had during install was the ewg extra cable. I connected it to the sensor connected to intake tube. I'm assuming this was right. All the other connections clicked properly in place. Fuel rail, map sensor and charge pipe. I am not sure what else to check at this point besides log and follow up with bms. It was used when I bought it but no flaw or anything with it. Bluetooth works fine. What all should I do next? |
03-15-2018, 08:54 PM | #9 | ||
Rep 115
I'm in your boat if I want smoothness and shift quality. I don't care as much about pure power. Want to have decent pulls that are slightly stronger than Dinan sport tune but smooth. The sport tune was good and felt fine but I feel a different in the jb4 install |
03-15-2018, 09:02 PM | #10 | |
Rep 115,999
Mike |
03-15-2018, 09:28 PM | #11 | ||
Rep 115
03-15-2018, 09:43 PM | #12 |
Rep 115,999
That add on EWG attaches to the wastegate, but for now I'd leave it tucked out of the way. You may have damaged the JB4 electronics that drive that connector by attaching it to the wrong sensor. May not have. You
can sort that out later when logging. Mike |
03-15-2018, 10:44 PM | #13 | |
Rep 115
03-15-2018, 11:40 PM | #14 |
Rep 115
Well I am currently leaving it unconnected. Absolute pain to even do and I don't have a pick tool or anything to help.
Anyone have suggestions on easiest way from an x drive. There is no room at all. |
03-16-2018, 07:06 AM | #15 | |
Rep 103
It took me 25 minutes the first time, it takes me a few seconds now. Be careful not to damage anything.
2014 335i xDrive F30 auto, Jb4 FF+EWG wires, VRSF DP,CP and FMIC, BMS intake, Remus Axle-back
SOLD - 2011 335i xDrive 6MT e90, JB4 ISO + ff wires, VRSF downpipe and chargepipe, BMS intake, BMS modified clutch valve, ST S1 coilovers. |
03-16-2018, 09:04 AM | #16 | ||||
Rep 115
03-16-2018, 12:40 PM | #17 |
Rep 103
I'll try to get a picture when I get home.
03-17-2018, 03:51 PM | #20 |
Rep 115
03-17-2018, 08:24 PM | #21 | |
Rep 262
I hope you get the JB4 working! |
03-17-2018, 08:27 PM | #22 | ||
Rep 115
