04-01-2018, 04:31 PM | #1 |
Rep 18
[HELP!] Can't Remove Brake Fluid Screen Filter - F30
Year: 2013 (F30)
Model: 316iA So I want to change the brake fluid in my car, and after I have opened the brake fluid cap, I found that there's an orange screen filter in it. I tried using a flat head screwdriver to pry it open. It didn't work. I tried turning the filter, and it still didn't want to come out. I felt like if I used too much force, it was going to break. This is a video I took: I can't change the fluid without getting that out. Could anyone help me? |
04-01-2018, 07:37 PM | #3 |
Rep 18
04-01-2018, 09:18 PM | #4 |
Rep 16,139
Before power bleeding you should use a turkey baster to remove as much fluid as possible from the tank. Then refill it with new fluid of a different color, so when you bleed you'll see the change in color of what comes out of the bleeders and know that the lines have been completely flushed. You can get DOT 4 in at least three different colors.
04-03-2018, 11:37 AM | #6 | |
Rep 3,540
I also recommend putting your hand over the reservoir mouth when popping the filter out as I've had it pop out and fall into the engine bay (thankfully still in an area where I could recover it without too much difficulty). |
04-03-2018, 03:23 PM | #7 | |
Rep 1,573
06-02-2019, 04:14 AM | #10 |
Rep 245
Anyone happen to know the part number for this orange screen filter.. mine got a little bit damaged when removing. Used a pick tool and kind of tear through the screen/filter.
I've checked getbmwparts and realoem websites but no luck finding the exact bmw part# |
