BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > F30 DIYs and Coding Discussions > CIC to NBT touch - What is needed for touch function?
      04-19-2018, 06:02 PM   #1
rezadue
Two turbos are better than one!
rezadue's Avatar
Drives: 2017 BMW M4 ZCP
Hi,
I am about to do a CIC (with Combox) to NBT touch retrofit. As I understand it:
1) NBT idrive controller is not lug and play
2) If I want the controller and touch functionality, I will need to either splice into some cables or build/buy an adapter cable.
Is there a DIY to get the touch function and NBT idrive knob retrofit?
Is there a place to buy the appropriate cable or do I have to build one, if I don't want to splice wires?
Thanks
Black Sapphire Metallic M40i
      04-19-2018, 06:14 PM   #2
IK6SPEED
Drives: BMW M3 / AH3
Originally Posted by rezadue View Post
Hi,
Thanks
There is another forum user that made and sold a Y connector for a very cheap price.
Search in the electronics section for touch controller about 2 years ago.
You do need to code into the car to work.
Codes are also in that thread.
But key thing is I do not believe touch system will work with CIC. Pretty sure you need a NBT System.
Again, I am speaking of the touch function, not a touch idrive controller.
And the itouch idrive controller is on KCAN2, not KCAN as the CIC is.
As thus, wiring is needed to connect to KCAN2 bus.
rezadue146.00
      04-19-2018, 06:32 PM   #3
rezadue
rezadue's Avatar
Thanks for the reply. I am going full NBT and have the headunit. Just looking at what I might need to get the touch idrive wheel and functionality working without splicing. I have looked and found nothing yet.
I will keep looking.
      04-19-2018, 07:13 PM   #4
IK6SPEED
This is not a do it yourself for most people. It has a high degree of difficulty to get correct.
Just search for the myriad of threads and cries for help started by your fellow Canadian Martyn88 over the past 10 days.
      04-19-2018, 07:29 PM   #5
rezadue
rezadue's Avatar
martyn88 is from the UK. are you sure you are not referring to someone else?
Most of the install will be handled by a shop. it is just the touch wheel and function retrofit that is on the table. and I don't want to be splicing wires, so I am trying to find the person who sold a cable , or a DIY for the cable alone.
      04-19-2018, 09:17 PM   #6
rezadue
rezadue's Avatar
Ah! You mean Mariwane1, yes he does seem to be having a lot of trouble.
