04-20-2018, 08:51 AM | #1 |
Rep 153
Does N55 have rod bearing problems?
I've read a few threads across the net now about the N55 having engine failures due to a spun rod bearing. I have a 2015 with a stock N55. Is this something I should worry about or is this not really a common issue? Anyone with over 100k on an N55 yet?
04-20-2018, 09:16 AM | #2 |
Rep 1,499
This is news to me. I've read the N55 has the same rod bearings as the S55 in the M3/4.
04-20-2018, 02:15 PM | #4 |
Rep 153
04-20-2018, 02:18 PM | #5 |
Rep 348
IK6SPEED4490.00 Bimmertodd8852.50 |
04-20-2018, 02:29 PM | #6 |
Rep 180
04-20-2018, 02:38 PM | #7 |
Rep 469
According to those I spoke to from the BMW dealership/garage, when my engine blew, there were some N55-engines in the beginning of the F30 life cycle that were bad. From 2014 and forward there should be any issues.
I don't know the source of the failure but in case I had to replace the engine with a used one they advised me to look only at 2014 and forward. Luckely BMW replaced my engine. Mine is one of the very first F30s and the new engine was complete different in "behaviour" compared to the old even though the old was not bad/poor at all.
DD: F48 X1 xDrive25i '20 - https://f48.bimmerpost.com/forums/sh....php?t=1703083
For fun: F22 M240i '19 - https://www.2addicts.com/forums/show....php?t=1644646 Previous BMW: Fully loaded F30, 335i https://f30.bimmerpost.com/forums/sh....php?t=1681247 |
04-20-2018, 03:21 PM | #8 |
Rep 1,541
It's an issue with E9x M3. Well documented and what stopped me from buying one a few years ago. Have not heard of anything about it with the n55.
04-20-2018, 03:24 PM | #10 |
Rep 153
That makes sense. Hopefully I'm in the clear as mine was made in late 2014. I believe BMW changed the rod bearings in the N55 some point after 2013 to the same ones used in the S55. Not sure on specifics though. Sorry you had an engine fail on you.
04-20-2018, 08:58 PM | #11 |
Rep 206
There are several on this site who have experienced this, including myself. My N55 failed with less than 48K miles and was diagnosed rod bearing noise caused by "connecting rod knock, internal engine failure". Thankfully with 2K miles and only a couple of months left on warranty, I received a complete engine replacement at no cost. If you search around for rod bearing you will find others with the same. It's rare but happens. Your best bet would be to have your oil checked every so often and, and in my personal opinion, change your oil sooner than the ridiculous 10K+ mile intervals.
04-21-2018, 08:40 AM | #12 |
Rep 6,990
Zero problems and zero oil consumption/leaks with my 2013 N55 with MPPK installed.
04-21-2018, 10:05 AM | #13 | |
Rep 647
04-21-2018, 01:35 PM | #15 | |
Rep 206
04-21-2018, 01:37 PM | #16 | ||
Rep 647
04-22-2018, 02:08 AM | #17 |
Rep 469
In my case there was no difference in the sound of the engine. At least not before it was way too late at 112.000km. However the old engine used oil and the new one doesn't. It used a litre pr 5-8.000km.
04-23-2018, 03:17 PM | #18 |
Rep 5,372
I've read of a handful of instances of spun rod bearings on N55 equipped 3/4 series cars and also a few instances with M235s. It's definitely not a widespread problem but it has happened in both older and newer N55s and high mileage and low mileage motors as well.
What kills rod bearings in most instances is lack of lubrication. With the N55s, I could see the following spinning a bearing: 1) Running the motor hard on cold oil. Oil needs to be a minimum of 180 degrees before driving hard. That typically means at least 10 minutes of driving (not idling). As oil warms up, the oil chains "thicken" thus increasing protection. I can see this being the #1 issue as most people have not a clue that oil needs to be up to temp, especially on a turbo motor. 2) High G load (typically the result of ultra sticky rubber during racing) which causes the oil to pool to one side of the pan and the oil sump temporarily starves of oil. 3) Power mods. Adding power to these cars often means manupulating boost, timing, and AFR to achieve more power. With more power comes higher combustion chamber temps and an increase in a "super knock" situation which is where the piston is hit so hard with detonation that it hammers the piston and rod so violently that the rod momentarily breaks through rod and rod bearing oil film thus spins the bearing. 4) Money shift with a 6MT. Typically other things break too. 5) Manufacturing detect. 6) Low oil teamed with hard driving.
The forest was shrinking, but the Trees kept voting for the Axe, for the Axe was clever and convinced the Trees that because his handle was made of wood, he was one of them.
04-25-2018, 05:14 PM | #19 |
Rep 351
I just had my oil filter housing gasket replaced this week under CPO warranty, 68k miles on the motor, 2013 n55. Tech said we had caught the leak early enough, but that what happens is the leak drips on the belt and belt tensioner, and can cause the tensioner to eventually fail and/or the belt to slip off the pulleys, and then the motor would lock up.
There are tons of n55's over 100k on the motors. These motors are in every line of car that BMW produced. Just like anything else, some are going to have issues.
2013 335i M-Sport 6MT, MPE, VRSF CP and IC, BM3 Stage 1
2006 330i 6MT, Sport Package - sold |
10-05-2018, 02:57 PM | #20 |
Rep 230
Can someone try to explain why "motor would lock up" if "the belt to slip off the pulleys"? All the belt drives is the A/C pump and alternator, as I understand. Why the hack "motor would lock up" then?
10-06-2018, 10:52 AM | #22 |
Rep 5,372
As a car guy and shadetree mechanic for 25 years, I would never believe such a thing could happen until seeing the pictures.
m3kgt29.00 |
