04-24-2018, 02:01 PM | #1 |
Fnatic
Rep 39
Tow bar and M performance diffuser?
As I understand it the carbon fibre M diffuser is not compatible with cars fitted with a tow bar, but does anyone know if it works with the matte black M performance diffuser?
04-25-2018, 12:45 PM | #2 |
Rep 25
The BMW dealer should be able to tell you if it is compatible. I have the electric folding towbar on a 540iX and fitted the M Performance exhaust and that requires a different diffuser (bigger holes for the tailpipes) but not sure if that is the same as the one you mean?
You can also often determine if parts are compatible or not using RealOEM |
04-25-2018, 01:25 PM | #3 |
Fnatic
Rep 39
Thing is, they don't seem to be able to answer. I also had to inform them a new bumper is needed when installing M perf exhaust (same as you have).
The diffuser I'm talking about is partno 51192412406 Rear diffusor, matt black that goes on the M performance bumper. Concerned the folding towbar will damage the "fins". Searching different sites provides little help as I have seen some state it's not compatible and some indicate it works. But if i understand this spec on RealOEM the matte black diffusor should work (see section 8-10): http://www.realoem.com/bmw/enUS/show...17#51192412406 Correct? |
04-25-2018, 03:35 PM | #5 |
Rep 193
Drives: '18 M550i, '15 Jaguar F-Type R
04-26-2018, 06:23 AM | #6 |
Rep 25
04-27-2018, 12:27 PM | #9 |
Fnatic
Rep 39
Will do Canuck99
Will talk to the dealer on monday so it'll probably take a couple of weeks, will update when done and post a video pre and after for those interested in what the 4-pot G30 530i sounds like with MPE. Have a decent microphone so hope to give you good sound outside and inside. Let me know if there is anything else you'd like details on. |
clee1982797.50 |
05-28-2019, 02:46 PM | #10 | |
Rep 101
Mvh Morten |
08-19-2019, 04:10 AM | #11 | |
Rep 200
It has the lower rear carbon fibre diffuser. I want a boat and really need a tow bar. How did you go? I want to keep the diffuser, but need a tow bar. Also, have you done any performance mods to your 530i?
