BMW 5-Series (G30) Forum iDrive, Audio, Bluetooth, Phone, Cameras, Electronics + Coding 530e Charging Error after BimmerCode! Need Help.
      04-29-2018, 06:13 AM   #1
sanjuvarma
Drives: 2018 BMW 530e / 2017 BMW x1
Hi all,
I have now an issue that I want to solve myself if possible, with your help.
I've had this 2018 BMW 530e iPerformance since Nov 2017 and loving it. I had been using the VGate WiFi adapter and the BimmerCode app to change a few settings here and there. About a month ago I went in again, to change a couple of more settings and right after that, noticed that the car won't charge anymore, gave me a Charging Error message on my BMW app, I have a Juicebox L2 Charger box at home. Tried a few other chargers (110v) and my charging facility (ChargePoint) at work, everything gave the same error.
Took it to the dealer, they kept it for a few days, reset all codes and it's back to normal again. I assumed something I did on BimmerCode that may have upset something.
A month later, last night, I wanted to code a couple of things which I had done when I first leased the car. I thought it was ok to do that so I went in again, just changed the starting animation to M type, changed the warning sounds to bmw i type, that's all!! And got the same charging error!!!
I hate it that I may have to go to the dealer once again. Can anyone please help!!!!
Thanks
      05-12-2018, 08:17 PM   #2
marsb007
marsb007's Avatar
Drives: 2024 iX M60
Did you try Esys? The transmitter app clears codes.
Also, if you restore the changes, does the error go away?
5post
