| 06-16-2018, 02:14 PM | #1 |
![]() ![]() ![]() 241
Rep 448
Hey all,
Simple question, I am hunting down a suspected boost leak and cant remember how the directional O-Ring should be installed for the IC to CP connection, should the lip be pointed down towards the IC or up towards the CP? I installed a new CP about a month ago and have felt a bit down on power and I hear an audible whooshing on throttle. I have removed and re installed the pipe multiple times and it looks basically perfect with the TB basically being flush and the clamps on the coupler very tight so I am a bit stuck at the moment. I am only running BMS Stage 1 and when its installed the whooshing is much louder with a whistle when i let off throttle. |
| 06-16-2018, 04:07 PM | #2 |
Rep 986
I had a whoosh sound shortly after my cp install. Turned out to be one of the connections on the upper portion of the charge pipe that came off. Whoosh was gone and power back
| 06-16-2018, 04:12 PM | #3 |
Rep 448
I reinstalled it a few weekends ago because the TB side wasn't close to flush and last weekend I tightened down the clamps when I installed my new IC, I would be shocked it that was leaking at all. There was quite a bit of oil at the IC connection so I am definitely suspicious of that connection.
I have had the O ring installed where it tapers up towards the throttle body, I am not sure if thats correct though |
sqwinny900.50 |
| 06-16-2018, 07:28 PM | #4 |
Rep 448
UPDATE: Ended up checking the TIC side(completely stock) and the correct orientation of the ring is tapered into the charge pipe, this makes it easier to mate to the intercooler and also doesn't twist the oring which I believe was my issue. I still hear some whooshing, but its so much less and I am basically certain thats due to my MPPK airbox and drop in air filter, the car feels just like it should.
The pic is how it should be installed. |
| 06-18-2018, 08:56 AM | #5 |
Father of Frankenfold
318
Rep 532
Drives: Yo daddy's 2014 X3 M Sport
I usually pack the groove and o-ring with grease to aid installation, sealing and troubleshooting. Packing it with grease eases the installation and minimizes the chances of damaging the o-ring and helps fill voids to reduce the chance of leaking. If it is leaking, it's easy to see the grease getting ejected.
F25 X3 35i M Sport | Frankenfold 6662 | VRSF Race IC | FTP CP | BM3 tuned | XDI-35 HPFP | Stage 2 LPFP | Ethanol mixed | WMI | Oil cooler | xHP | X5/550i brakes
| 06-18-2018, 11:08 AM | #6 |
Rep 448
I used some oil from the old CP(I ended up seeing this accumulate on the c clip which was a sure sign of a leak) when I initially installed the o-ring and it fits in the channel just fine, but when you go to slide it on the intercooler it grabs and twists leading to a boost leak. What was weird was that the connection feels really loose when you install the ring correctly, but I believe that's to allow for the metal CP and FMIC to expand.
| 06-18-2018, 01:28 PM | #7 |
![]() 527
Rep 1,288
if it's a "V" cup oring ... the Open part of the "V" is towards the IC... this allows air to fill the "V" and create a better seal.
sspade2560.50 |
| 06-05-2019, 11:26 AM | #8 |
Rep 448
Bumping this, I noticed the other day I have oil coming out of this connection meaning I have a leak. I have a new o ring coming in today and plan to tear this down once again. Currently thinking my install is still correct, just the o ring must be damaged.
VRSF CP and IC |
| 06-05-2019, 11:32 AM | #9 |
Rep 448
This is my logic, also shows off my immense artistic "capabilities"
| 06-05-2019, 11:34 AM | #10 |
Frau EstorilBlau
443
Rep 957
Oil seeps through the tiniest gaps, it's possible your seepage is normal and not indicative of a leak.
| 06-05-2019, 02:06 PM | #11 | |
Rep 129
Is more evident into sport/sport+ mode... due the "demand" of air and the "re-disgned air box" , probably? |
| 06-05-2019, 02:50 PM | #12 |
Rep 2,501
All I can say is that I carefully inspected the orientation of the o-ring when I uninstalled my stock CP and IC and it was oriented in the opposite direction you think is the correct position. I thought it was strange because I imagined that it would be tapered towards the IC to make installation easier. However it was tapered the opposite way away from the IC. So that's how I installed mine and I haven't noticed any boost leaks.
I ended up having to replace my IC a couple months afterwards and didn't notice any oil at all seeping through the connection. It was completely dry although my stock CP had some pooled oil inside of it. Especially after my tune, I do notice a lot of whistling noises which I assume are from a diverter valve. I noticed them on my completely stock old N54 car as well after tuning (stock CP and IC). EDIT: After thinking about it, I think your diagram is flawed. I believe that the air flowing through the charge pipe actually creates a low pressure area around the o-ring. So it actually pulls the o-ring and that is why it is tapered one way for the hot side and the opposite way for the cold side. If it's oriented the way you drew it, it might actually cause the seal to be pulled open slightly which would then cause the high pressure in the charge pipe to blow out the air. If it was installed the way I'm recommending, the seal would constantly be pulled against the IC port even harder as more air was drawn through. This is just a theory. I have no idea if it's true. But it would explain why the o-ring orientation is reversed for each side of the IC. Last edited by upsidedownfunnel; 06-05-2019 at 03:03 PM.. |
khj24241.00 |
| 06-05-2019, 03:01 PM | #13 | |
Rep 448
| 06-05-2019, 03:35 PM | #14 |
Rep 627
O-Ring direction
335i F31 RWD in SB (2013) || Powertrain: Active Autowerke Flash Tune Stage 1 | AA Charge Pipe | AA FMIC | GFB DV+ | xHD Trans-Flash | Quaife LSD | Cyba 3.5" Carbon tips || Chassis: 20" 405M | Wiechers Strut Bar | Rear M-Diffusor || Brakes: 18" M-Perf Brake orange 370/345 | EBC YellowStuff pads all around
e46m3to335i187.00 |
| 06-05-2019, 03:50 PM | #15 |
Rep 1,425
I stumbled across this thread just curious as to what it was about. I installed a VRSF CP on my car a few weeks ago. Noticed I wasn't hitting target on my pulls by ~1-1.5 psi. Didn't really think much of it and wrote it off because it has been super hot lately and my AIT's were stupid high.
Low and behold, I didn't even know there was an o-ring on the IC side of the CP that needed to be transferred to the new VRSF CP 😂😂. Guess I'll have to take care of that next weekend when I get back home from vacation. |
BMW DIY Guy4197.50 |
| 06-05-2019, 03:57 PM | #16 |
Rep 448
| 06-05-2019, 04:03 PM | #17 |
Rep 2,501
| 06-05-2019, 04:04 PM | #18 | |
Rep 129
I hear it when I'm pressing down the gas pedal or a long run... |
| 06-05-2019, 04:14 PM | #19 |
Rep 448
VRSF, I wonder if I needed to oil the IC as well. That could have made the o ring grab and twist. But looking at your edit, I think you may be on to something because the air flows in two different directions when you think about it. OUT of TIC, IN to CP. Luckily I have my old intercooler so I can test around with the o ring position without having to bolt everything up.
| 06-05-2019, 09:33 PM | #20 | |
Rep 448
upsidedownfunnel1986.00 |
| 06-05-2019, 10:40 PM | #21 |
Frau EstorilBlau
443
Rep 957
You got the part number for that oring by any chance? might swap mine out for the peace of mind.
Edit: 13718596850, found on realoem.
Power mods: Pure500, MAD IC - FTP CP/BP - AFE Cat-back - BM3/XHP - Dorch S2
Handling mods: Koni yellow - Eibach prokit - Millway street - M Performance LSD - M3 brakes - EBC bluestuff Exterior: Euro LCI tail lights - CF spoiler - Chinese M performance diffuser Interior: Bavsound stage 1 and subs - custom trunk sub by Mike1327 |
| 06-06-2019, 06:47 AM | #22 | ||
Rep 627
| Bookmarks |
