06-26-2018, 04:14 PM | #1 |
![]() ![]() 102
Rep 148
Drives: F30 335i sport line
Garage List 2012 BMW F30 335i S ... [0.00]
2006 BMW 330xi [0.00] 2007 Toyota FJ Cruiser [0.00] 2003 MINI cooper S [0.00] |
Coolant Vent hose crack
So my 335i was running great and as we pulled up to the movie theater and parked the car decided to wet itself.
I was a bit nervous until I found out where the coolant was coming from and it was a small hose on the top that runs from the expansion tank to the top radiator hose. The car spent a couple nights sitting in the theater parking lot while I waited for the part to show up but was an easy fix (did it onsite at the theater) Thought I would share for those interested if it happens to them. I saw somewhere on youtube a guy was charged nearly $300 for the fix. The part (17 12 8 570 061) was less than 50 USD from the dealership (I've even seen it for less online) Took me longer to film it than it did to fix it. An easy DIY. |
06-26-2018, 06:39 PM | #2 |
![]() ![]() 1458
Rep 1,487
Drives: 2108 X3 xDrive30i
I appreciate the clip...it really adds to the DIY knowledge base. Good work. Looks pretty easy. Thank you.
02-21-2020, 01:51 PM | #3 |
Rep 17
Great help
Yeap, happened to my wife's '14 m235i too. She called saying the car is reporting low coolant level in the morning (and she just got to work 50+ miles away). I didn't think much of it since she had low coolant warning before and the dealer just topped off not seeing any leaks. I recently topped off about a month prior to this latest notification from the car.
This time, she got home and reminded me about the 'add coolant' alert. As she pulled in and open the hood, steam was coming out of it. Found that the plastic tube was broken in the same place at that 90' degree elbow! I was mad that this coolant hose was made of brittle plastic? Car had less than 75K on it. Called the dealer but they wanted $75 bucks for it. Online was ranging about $35-40 dollars. I DIY with a 5/16in transmission oil hose (<4 ft) and hose clamps for $10 from AutoZone, based on the the genius idea below. I did order the tube online for $35 bucks as a backup. But looking at the permanent solution, this will occur again in about 50-75K miles again... ![]() After the repair, I had to add 1 gallon of coolant to bring back the level to normal and ran thru the instructions to run the 'electric water' pump to burp out air. Also had to clear the CEL of u1408 / P 0128. I think any longer and the engine could have been damaged. https://f30.bimmerpost.com/forums/sh...1547622&page=2 |
04-22-2020, 12:30 PM | #4 |
![]() ![]() ![]() ![]() ![]() 375
Rep 604
Drives: F87 M2 DCT, F15 X5 M-Sport
Just happened to me while in line for ice cream haha. Left the car in the parking lot and ordered the part from FCP Euro - paid for 1-day shipping. Lets see if I can get it moving again as easily as you did! 95K on my car.
‘18 F87 M2 DCT
'17 F15 X5 xDrive35i M-Sport Other sold cars of interest: E90 335i, S2000, E92 335xi, C6Z, F30 335i, 987.2 S |
08-11-2020, 07:38 PM | #5 |
Rep 24
Thanks for the video. Same exact break with my F30. Googled it and your post came up first. Glad its a quick fix.Now I'll have to check the local dealer to see if it's in stock or not.
08-11-2020, 07:44 PM | #6 |
![]() ![]() ![]() 240
Rep 507
My aftermarket replacement one cracked also after much difficulty trying to install it. Caused overheating and a tow. The second replacement was from a dealer. Went on in two seconds.
01-29-2021, 10:27 PM | #7 |
Rep 13
Is the purge with the pump procedure a must ? This happened to me today and I got a ride to dealer bought the part and swapped it out. Topped off the coolant. And drove it home. It still steamed after but I assumed that was what was splashed around inside and the heat. Should I still do the purge tomorrow morning?
01-30-2021, 03:59 PM | #8 |
No 55mph
1646
Rep 8,498
Thanx for the heads up & the nifty parking lot DIY
![]() I have heard of this being a 'normal' problem so I went ahead & bought the new line & keep it in my trunk for just in case when it happens. What was the mileage on your car when this happened? I have 39K on my 435, just wondering around when I should be expecting this to break ![]()
01-30-2021, 04:27 PM | #9 |
![]() ![]() ![]() ![]() ![]() 648
Rep 985
Drives: 2016 F36 435x MSport
had it happen to me at around 40k. Bought a replacement and a spare just incase
2010 Mazda RX8 - Sold (11/17)
2016 BMW 435xi GC - Current |
flyt1006.00 |
01-30-2021, 06:32 PM | #10 |
![]() ![]() 2165
Rep 2,905
Drives: F33 430 and F39 M35i
mine blew at 66k
02-01-2021, 05:16 PM | #12 |
![]() ![]() 4496
Rep 7,753
335i, coolant leak, coolant vent hose, vent hose |
