BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > 2012-2019 BMW 3 and 4-Series Forums > General F30 Sedan / F32 Coupe / F36 Gran Coupe Forum > F30 328i drivetrain error
      07-21-2018, 02:28 AM   #1
Jongdoo
Drives: F30 328i
Hello. This is Jongdoo in Abu Dhabi.
My car is 2014 328i and I have a big trouble. I tried to change the last spark plug to the cabin yesterday (3 spark plugs already changed) but my tool was touched to the bolt that is connected red line (I think it's + ) I saw the spark between the tool and bolt. After then Drivetrain error is coming. I have OBD and check the diagnostic below.
This is the diagnostic report.
Engine / Motor
Fault Code: 113027
Fault Explanation: Relay ignition and injectors, supply voltage injection: line break
Fault Code: 1F0515
Fault Explanation: Valvetronic, supply voltage: Line break
Fault Code: 1F4A02
Fault Explanation: Relay ignition and injectors, Control: short circuit to ground
Fault Code: 133102
Fault Explanation: Valvetronic relay control: Short circuit to ground
Fault Code: CD9010
Fault Explanation: LIN, communication (engine coolant pump): missing
Fault Code: 1B5202
Fault Explanation: Terminal 15N 1: no voltage
Fault Code: 1B5402
Fault Explanation: Terminal 15N 3: none Power
Fault Code: 1B5302
Fault Explanation: Terminal 15N 2: no voltage
Fault Code: 130002
Fault Explanation: VANOS solenoid valve inlet, control: Short circuit to ground
Fault Code: 130202
Fault Explanation: VANOS solenoid valve outlet Control: short circuit to ground
Fault Code: 122002
Fault Explanation: Diverter valve control: Short circuit to ground
Fault Code: 1C0202
Fault Explanation: Engine oil pressure control valve actuation: Short circuit to ground
Fault Code: 12B102
Fault Explanation: Lambda probe heating before catalyst activation: short circuit to ground
What is the problem and what should I do now?
Thank you.
      03-06-2019, 07:12 PM   #2
jaredprovost
Drives: 2012 335i F30
this happened to me too same exact thing, can someone reply?
      03-06-2019, 07:24 PM   #3
328iX
David
328iX's Avatar
Drives: 2015 328iX F31
Def. something you'll have to take to a professional, looks like the ECU shorted but no definitive answer. My question is, why didn't you have the terminal cover in place?
Start by disconnecting the battery and reconnecting, see if that does anything.
      03-06-2019, 07:26 PM   #4
Brett530
Brett530's Avatar
200
Drives: '17 F30 340i
If you shorted the + battery terminal in the engine bay through the wrench while it was trying to unscrew the spark plug, I can't see why that would do any permanent damage. I don't think there are even any fuses between that terminal and the battery in the trunk. Should have grounded to the engine block. The computer might have seen a high discharge from the battery. Have you tried pulling the positive battery cable from the trunk and letting it site that way for like 15 minutes?
If the wrench was not on the spark plug at the time, it could have done a wide range of damage.
2017 F30 340i RWD // MG Flasher // xHP // CG DS-1 // ZTR ZMP ZCW ZLP
      05-28-2019, 11:20 AM   #5
TweetysBMWF10
Drives: F10
Help Please Battery positive terminal shorted from loosen nut
What should I do can anyone help with this problem please
I have a 2013 535i f10 n55 I have the same issue just like this just a bit differant witch mine was started from a nut being loosen on the battery jumpstart terminaland I have a big trouble. I tried to change the last spark plug to the cabin yesterday (3 spark plugs already changed) but my tool was touched to the bolt that is connected red line (I think it's + ) I saw the spark between the tool and bolt. After then Drivetrain error is coming. I have OBD and check the diagnostic below.
Engine / Motor
Fault Code: 113027
Fault Code: 1F0515
Fault Code: 1F4A02
Fault Code: 133102
Fault Code: CD9010
Fault Code: 1B5202
Fault Code: 1B5402
Fault Code: 1B5302
Fault Code: 130002
Fault Code: 130202
Fault Code: 122002
Fault Code: 1C0202
Fault Code: 12B102
Thank you.
      05-28-2019, 11:24 AM   #6
bimmer456
Drives: 340i
I would disconnect the battery before changing spark plugs in general.
      05-28-2019, 12:04 PM   #7
Mr Podman
Drives: 3 Series GT Stage 0.5
Instead of doing this, I would try disconnecting the negative terminal on the battery for about 15 minutes.
podman
bimmer4562730.50
      04-07-2020, 02:07 PM   #8
Tatts4278
Drives: 2013 f30 328i x drive
[COLOR="Sienna"]Have you tried pulling the positive battery cable from the trunk and letting it site that way for like 15 minutes?[/COLOR]
podman
does anyone know where the dme main relay is ?
stay healthy
      04-07-2020, 08:14 PM   #9
jmaak
Drives: 370z
you probably blew a fuse, check this thing
https://www.ecstuning.com/b-genuine-...i/61149227752/
its located in the trunk behind the passenger side trunk lining. I would pull that out and make sure none of the fuses are blown there first.
      05-08-2021, 03:35 PM   #10
drummajorc
Drives: F82 M4
Yup! Found a similar post, same error codes in the X5 forum, they fixed it with f503 fuse, which appears to be in that box in these cars, pulled the box out and tested the fuses and sure enough the one going to the IVM is blown. Have a new box coming Monday and hoping that will be the end of it. Thanks.
      05-11-2021, 05:14 PM   #11
wolfamongmen
Drives: F30 328i
Can you link the thread? I'm dealing with the same issue atm. Also where did you order the box from? Our local bmw dealers aren't super helpful... and ECS tuning is lacking a lot of information on their page.
EDIT:
After a lot of searching and troubleshooting (because I, too, refuse to let a dealer get one over on me and the bimmer forums were surprising less than helpful on this one) it did end up being the Distributor fuse box Jmaak listed linked above (and I will link below.) I actually started with the IVM; which is also called a Power Distribution Module or an IVM depending on who you order it from. Considering I had just detailed my engine bay a few weeks prior; the chance of detergent or water creeping and causing corrosion or further damage was possible.
(BimmerLink)
All of fault codes of concern:
1B5302: Terminal 15N_2: no voltage
122002: Diverter Valve, Control: Short Circuit to Ground
1C0202: Engine Oil Pressure Control Valve, Control: Short Circuit to Ground
130002: VANOS Solenoid Valve Outlet, Control: Short Circuit to Ground
130202: VANOS Solenoid Valve Inlet, Control: Short Circuit to Ground
120408: Boost Pressure Control: Shutdown as a follow-up reaction
102A01: Air Mass Meter: Signal: Electrical Fault
I did throw a few more codes in other areas but these were the persistent errors. I'll have to reflash the tune to be sure everything is the way is should be. But I don't suspect anything fouled up.
HOWEVER,
Regarding OP,
I would suggest starting with the distributor fuse multi in the trunk. A) it's cheapest and B) it's really quick and simple to replace. Terminal 15N Voltage is BMW's electronic brain's way of saying it's constantly on. Everything run's back to those. The only time i experience Terminal 15N_1 and Terminal 15N_3 no voltage was when i was trouble shooting the IVM and had it entirely disconnected. So bearing that in mind.... it is entirely possible to fry connectors.
https://www.turnermotorsport.com/p-1...uine-bmw-part/
Last edited by wolfamongmen; 05-17-2021 at 09:09 PM.. Reason: Updating with "my" solution
      07-24-2021, 08:21 PM   #12
drummajorc
Drives: F82 M4
Sorry for the late reply, but to help anyone else with this, the X5 thread is here.
https://f15.bimmerpost.com/forums/sh....php?t=1712431
I'm outside atlanta and found the box at a BMW dismantler/used parts place, Bimmer Motor World, you can likely find them on eBay as well, it doesn't have to be new as long as the fuses are good. Search for "rear battery distribution box" or something like that, it is a red plastic box.
      02-15-2023, 03:25 AM   #13
rif75
France
55
Drives: BMW M4 LCI ZCP and BMW M5 f10
Hi all
Got the exact same issue on my m235i from 2014. Any fix here? I have replaced the ISM but will still not start. Finger crossed that not a blown DME...
BMW M5 ZCP and M4 ZCP. BMW 540i G30 stage 2 with KW street confort, Wagner DP, Remus catback, M sport brakes 395mm front and 385mm rear. MHD tune.
      02-15-2023, 12:21 PM   #14
rif75
France
55
I have found the issue in my case, too bad that I sent the DME for repair before checking that but it is one of the fuse in the distributor B+ next to the battery that is down. I checked the ISM and all fuses of the car but forgot about this one...
I have requested the return of my DME asap and found a dstributor B+ unit on ebay for around 20euros.
Copyright ©2000 - 2023, vBulletin Solutions Inc.
