BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > 2012-2019 BMW 3 and 4-Series Forums > Regional Forums > USA - New England > MA Inspection Question
      08-20-2018, 04:26 PM   #1
akf30
Drives: 07' 328i; 14' 335i xDrive
Going to get a VRSF Catless DP in a few weeks along with BM3 or MHD tune (havent decided yet), just wondering will I pass my inspection? Driving a 14' 335 m sport, stock exhaust. Read a lot that the flash tune will get rid of the CEL. Don't really want a CATTED DP, rather go catless. Any info would be great.
Thanks in advance.
      08-20-2018, 09:17 PM   #2
435MSport6Speed
435MSport6Speed's Avatar
432
Drives: 435i M Sport 6 Speed
With the way they are doing inspections now, I doubt it. Read the thread talking about plate frames.
      08-21-2018, 08:03 AM   #3
lyjw88
lyjw88's Avatar
Drives: C63S & X3MC
Thanks in advance.
Are you keeping secondary cats and stock mufflers in?
      08-21-2018, 11:17 AM   #4
akf30
Thanks in advance.
Yes I'm just planning on getting a VSRF DP, and a flash tune either bm3 or mhd, haven't decided which yet. But keeping the rest of the exhaust stock. No muffler/resonator/cat change/cut off.
Haven't done any other mods, only other thing I plan on really changed is the charge pipes and the FMIC and that's it. I enjoy the sound of the DP and stock exhaust, no need for a new intake.
      08-21-2018, 12:09 PM   #5
lyjw88
lyjw88's Avatar
Drives: C63S & X3MC
You should be fine as long as there is no CEL (which should be deleted by your tune). They might catch you cause of the exhaust fume but I highly doubt it.
      08-21-2018, 03:43 PM   #6
F30-XP-DM
Drives: 14 335i xDrive
I think you're getting some bad info here. The CEL may be off on your dash, but the tune won't allow your car to get in the ready state when plugged into the inspection machine. When your inspector plugs into your OBD it'll never get into a state of readiness.
I'm due for inspection this month, so if I'm wrong - someone please correct me!
      09-16-2018, 05:19 AM   #7
TerryGTX
Drives: 2014 Bmw 435xi M-sport
Thanks in advance.
Thanks in advance.
PM me. I recently passed with catless dp with the help from a local bmw expert. He's located in Norwood
      09-18-2018, 11:07 PM   #8
Logicoeur
Logicoeur's Avatar
994
Drives: F30 335i xDrive
Thanks in advance.
Thanks in advance.
It was my understanding that flash tunes like BM3 and MHD avoid CELs by setting that catalyst readiness test to passing. Is this incorrect? How would the inspection station be able to tell the test is invalid, if the DME is indeed saying that test passed, while the above is correct?
      09-21-2018, 01:55 PM   #9
swallace727
Drives: 428i GC xDrive - M Sport (F36)
any news on this? I am also considering buying a catless DP with bootmod3 flash tune. Will this pass the emissions test?
      10-05-2018, 08:59 AM   #10
x3sm
x3sm's Avatar
284
Drives: M3 E93 Porsche
The way Mass inspection works is it allows pass only if 3 out of 4 components show readiness. I forget what the 4 components are, but some are mandatory such as evap system. Catalyst I believe can show not ready and still pass.
      10-18-2018, 08:39 PM   #11
Logicoeur
Logicoeur's Avatar
994
What supporting information do you have for this?
      10-19-2018, 08:38 AM   #12
x3sm
x3sm's Avatar
284
Experience lol.. I had a 335 with no kitties and auto tune suppressed it, showed not ready for one component and passed every year for 3 years that I had the car. This was 2 years ago, so it might be different now.
Logicoeur993.50
      10-19-2018, 08:49 AM   #13
sspade
sspade's Avatar
Drives: F30
2016 BMW 320i  [7.87]
2014 BMW 328i  [6.83]
This is basically same for NY as well... must have 3 out of 4 emissions flags set to pass NYS inspection.
      10-19-2018, 10:49 AM   #14
Logicoeur
Logicoeur's Avatar
994
Thanks. Exactly what I needed to hear
I recently discovered flash tunes were only suppressing the CEL, but not setting readiness, so I wasn't sure how inspection happened without knowing someone.
People would only post that they know someone, or they would swap back to stock and then back to aftermarket. The latter method is just not worth it at all.
      10-19-2018, 11:37 AM   #15
sspade
sspade's Avatar
Drives: F30
The only way to pass emissions is to put the stock cat back on or buy a phony sticker if you know someone or can get someone to risk their inspectors licence.
DL335D582.50
      10-19-2018, 11:51 AM   #16
Logicoeur
Logicoeur's Avatar
994
How is that so, if no visual inspection is done, and the above holds true? "3/4 tests must be ready"
      10-19-2018, 11:53 AM   #17
sspade
sspade's Avatar
Drives: F30
Great question... need to research exactly what the four flags represent but I believe two of them are related to cat. None of the flags are visual... this is all digital.
Anyone know exactly which four parameters are being looked at to pass emissions (in NY) ?
      10-19-2018, 11:57 AM   #18
sspade
sspade's Avatar
Drives: F30
A vehicle will fail the (NYVIP2) OBD II inspection if enough monitors are reported as “Not Ready.” Generally, OBD II vehicles from model year 1996 to model year 2000, inclusive, will fail when more than 2 monitors are set as “Not Ready;” while model year 2001 and newer vehicles will fail when more than 1 monitor is reported as “Not Ready.”
      10-19-2018, 01:35 PM   #19
akf30
Will find out in May for Massachusetts, but based on the info I've gathered from a few inspections stations with the new MA inspection system, a catless DP with a non-ready system will result in a fail/rejection. Therefore you'd have to swap out the catless with the stock when you go for your inspection.
      10-19-2018, 10:46 PM   #20
Logicoeur
Logicoeur's Avatar
994
So it's possible that there's a threshold of 1 or 2 tests showing failed readiness and you are able to pass, but the cat failing readiness is an automatic failure regardless of the count.
      10-21-2018, 09:25 AM   #21
x3sm
x3sm's Avatar
284
If anyone has an OBD scanner it usually has a basic inspection readiness scan. When you scan your car it will show the monitors they look for.
M3 E93
PORSCHE MACAN S: SOLD
BMW X3 F25: SOLD
AUDI S4: SOLD
BMW E92 335: SOLD
      10-22-2018, 03:51 PM   #22
Logicoeur
Logicoeur's Avatar
994
I don't believe those can scan for readiness by state, can they?
