BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > N55 Turbo Engine / Drivetrain / Exhaust Modifications > Need advise installing M2 muffler on 435
proTUNING Freaks
      09-03-2018, 11:31 AM   #1
danjjacob
danjjacob's Avatar
23
Drives: 435i xdrive Msport 6MT
I pulled the lower grey valance thinking I would just trim it and be all ready to have the muffler swapped out but when I removed the valance there is this white plastic piece with wires attached. Does anyone know what it is? Along the bottom of the white piece there is a flexible black tube with a wire attached running along the very bottom of the white bracket and a flat black strip with a wire attached near the top of the white bracket . On the left side is a terminal block. Can I trim the white piece and just tuck the wires in back? HELP
      09-03-2018, 12:07 PM   #2
danjjacob
danjjacob's Avatar
23
Here is another picture
What do I do with this thing?
      09-03-2018, 05:12 PM   #3
danjjacob
danjjacob's Avatar
23
UPDATE: some more info
I removed the white plastic piece, it snaps into the bumper under the bumper cover and there are two small wire connections. I unplugged both of them and completely removed the white plastic piece. The two black pieces (the black tube along the bottom of the white bracket and the black flat piece along the top of the white bracket) must be for the proximity lock/unlock feature and for the wave your foot under the bumper feature because neither of them work now. I have to use the remote to lock/unlock the doors. So I think I need to figure out how to shorten the white plastic piece and re-engineer the mounting of the black strip and black tube. The problem is they are both too long to fit between the quad exhaust tips. Any suggestions?
Thanks
      09-03-2018, 07:59 PM   #4
danjjacob
danjjacob's Avatar
23
The offending piece
So here is the little rascal. I am thinking re-position the tube from the bottom to the top with zip ties where it won't be in the way of the exhaust tips and re-position the black electric block where the wires clip in to somewhere in the middle. Then trim both sides of the white plastic mounting piece for the tips. Thoughts?
      09-06-2018, 10:03 AM   #5
danjjacob
danjjacob's Avatar
23
Problem resolved
Simple mod, trimmed the lower corners of the white plastic piece to make room for the quad tips and moved both ends of the flexible black tube up underneath the black flat strip and zip tied them in place. Everything fits nicely. Job done.
Sound is much louder, more in character with the car. Stock exhaust is too quiet, Lexus like to my ear.
TF309058.50
      09-06-2018, 10:08 AM   #6
TF3090
TF3090's Avatar
59
Drives: 2014 BMW 435i M Sport
Nice! I've thought about doing this, just haven't had any luck finding an M2 muffler. Thank you for documenting your process!
      09-06-2018, 10:21 AM   #7
HKD126
Drives: 2014 335i, 2009 335xi
Originally Posted by danjjacob View Post
Simple mod, trimmed the lower corners of the white plastic piece to make room for the quad tips and moved both ends of the black tubes up underneath the black flat strip and zip tied them in place. Everything fits nicely. Job done.
Was the exhaust a clamp on job or did you have to weld it/fabricate some piping to make it work? I looked at a local m235 M Performance exhaust, but the axle back looked like the piping needed to be extended to mate up to the factory 335i exhaust.
      09-07-2018, 06:00 PM   #8
danjjacob
danjjacob's Avatar
23
Keep looking for one on the M2 forum items for sale.
I had a local muffler shop install it, they flaired the pipe and welded it in place. 45 minutes and $75 later I was on my way.
      09-08-2018, 12:33 PM   #9
markeys
markeys's Avatar
30
Drives: 2006 325i
Thanks for experimenting and sharing! I'm in the process of doing this to my 335i. This is very helpful.
Former cars: 2005 Pontiac GTO, 2015 Subaru WRX, 2014 BMW 335i M Sport
Current cars: 1985 Pontiac Trans Am (LS swap in progress), 2006 BMW 325i 6speed manual, 2022 Toyota 4Runner
      09-13-2018, 07:48 PM   #10
alexng72
Drives: 2015 F32 435i Black Msport
I just realized that I haven't taken pictures for you. My bad. Here is how my exhaust stay on the car. It's a bit lower than the white part.
Can you post some pictures of your rear end?
      09-13-2018, 07:48 PM   #11
alexng72
Here is mine.
      09-15-2018, 06:38 PM   #12
danjjacob
danjjacob's Avatar
23
Here is mine. It's tucked up higher than yours. It was installed using the stock muffler hangers. It turned out great.
      09-15-2018, 11:26 PM   #13
alexng72
Looks great man. I'll need sth done to get fitment a little better since I'm getting a different diffuser.
      09-17-2018, 03:11 PM   #14
MunchiM40i
MunchiM40i's Avatar
492
Drives: 2023 Brooklyn Grey X3 M40i
Looks great!!!
If i didnt have the M-performance diffuser i would of went through with the M2 muffler!!
      09-18-2018, 02:00 PM   #15
lfepro.g
Drives: 428i
Any videos of the sound?!
BMW F32 428i BSM | KW V2 Coilovers | VRSF Catlesss Downpipe | Evolution Racewerks Chargepipe | Bootmod3 Stage 1 | Custom Borla Atak Exhaust w/ Quadtips
      11-06-2018, 02:30 AM   #16
markeys
markeys's Avatar
30
Drives: 2006 325i
Worked on 335i
This was a big help when I installed an M2 muffler on my 335i. I bought a 328 aftermarket diffuser and went to town on it. Not a perfect cut, but I'm happy with how everything turned out.
      04-29-2019, 04:40 AM   #17
robban87
Sweden
Drives: BMW 335i -12
Bump! Any pics on where you mated the pipes together?
      05-02-2019, 02:20 PM   #18
danjjacob
danjjacob's Avatar
23
For me the cut was about 4" back from the muffler and I had a muffler shop weld in on. Cost $50 to have it installed.
