09-14-2018, 08:39 AM | #1 |
Rep 4,136
New Windows on home Need Advice
Hey everyone, I really love this forum honestly for the vast knowledge people have outside BMW.
So my parents decided to order windows to be replaced.... I believe my current windows are wood. There is rot on the exterior sills on most windows(or just moss). Now i don't know if anyone has used castle windows. But I just found the contract and today the last day to cancel.... my problem is, I don't know enough about it. and cant take the contractor's word on what he defines as repairing the window. We need 22 double hung windows and rot repair. Anderson wanted just north of 20k. Whereas castle window is only charging 12k. Whats the catch? I know different window brands, but 8k-9k must be going somewhere? Ugh last minute things....I appreicate anyone's help. Ill post the contract, and a picture of my window |
09-14-2018, 08:54 AM | #2 |
Rep 2,079
Drives: 2022 X6///M Comp
Google is my friend
https://www.yelp.com/biz/castle-windows-mt-laurel-2
Check out the reviews, they're mixed. I've never heard of Castle windows and their website doesn't show how long they've been in business ( a quick glance anyway). In my opinion, a lifetime warranty/guarantee is only good if the company is still around. I know it's a big difference in dollars but Anderson has been around for a long long time. I just had Anderson Replacement replace sliding patio doors and they were an absolute pleasure to work with. Good luck |
G35POPPEDMYCHERRY5001.00 |
09-14-2018, 09:17 AM | #4 |
Rep 5,582
This is tough." Within existing sills, jambs and header...unless otherwise stated " seems like these parts need to be refurbished and looking at the pics it looks as those those parts may have been covered with either aluminum or vinyl. I'm not sure what kind of windows are in their now and I can't tell if the sill are properly angled.
And then the screens, newer screens or no screens or roll up screens. There is something to be said for wooden windows and the ability to repair. I'd cancel and do more research - you need to go into this with window samples and a full knowledge of exactly what is getting replaced and what is to be carried over. |
2000cs3766.00 |
09-14-2018, 09:46 AM | #6 | |
Rep 5,582
And its really important to see an actual casement window to gauge how much less glass then the old windows. Hopefully you'll get some more responses here. |
09-14-2018, 09:59 AM | #7 | |
Rep 4,136
09-14-2018, 10:15 AM | #8 |
Rep 2,079
For what it's worth, when Anderson wrote my contract they stated that they would repair/replace the frame if any rot was beneath the sill once they removed the old door. I'm assuming this is standard.
09-14-2018, 10:39 AM | #9 | |
Rep 5,582
my mistake with the casement it's worth joining CR to get the info right now https://www.consumerreports.org/cro/...uide/index.htm Last edited by overcoil; 09-14-2018 at 10:50 AM.. |
09-14-2018, 11:14 AM | #10 |
Rep 174
I have replaced my entire house with replacement windows once a few years ago, and am currently shopping for my new house. Anderson is crazy expensive, so unless you have architecturally significant windows you are replacing, it's not worth it. I used softlite in my last house, I was happy with them. As you can imagine, installation is a critical part as a great window poorly installed will be crap.
You could hire a handyman to repair the sills/frames, and whirl he's doing that you can shop for a better deal on windows. Or just confirm that what you have is good. Either way, might be worth taking some more time, and if the company is solid you price shouldn't change. If they say it will , it must not be that good of a deal in the first place. |
09-14-2018, 02:13 PM | #11 | |
Rep 4,136
09-14-2018, 02:16 PM | #12 |
Rep 2,925
Can't see the contract, so this may be answered in the details there.
I'd second the 'cancel and take more time' option. You do not want to just seal up dry-rotted wood underneath nice pretty looking cladding - it is great looking, but then your house will have some real problems. Since that repair is fairly complex, I'd be suspicious of anybody who wrote a bid that did not specify pretty clearly what they were replacing, or had a per-unit price (i.e. any rot is repaired at a cost of x$ per window, etc). 'Flat rate and we fix whatever we find' sounds like an incentive to overlook replacing stuff, and once it is covered over, you won't know until the trouble starts. FWIW, if you want to check yourself: if you can push a nail or pin into the wood more than about 1/4" by hand, it is dry-rotted. This will only get at the surface, and there is more underneath, but if the sills are rotted, likely some of the subframe is too. May want to ask some neighbors (with nice windows) who did theirs and if they were happy. |
2000cs3766.00 |
09-14-2018, 02:27 PM | #13 |
Rep 4,857
We put in impact glass in last year. Prices were all over the board. I concur with cancelling and taking more time to evaluate and understand materials / scope of work for each company. This is not something you want a problem with later.
Current: 2018 SO/SS F83 ZCP
Gone: 2015 SO/SO F82 |
09-14-2018, 02:47 PM | #14 |
Rep 1,003
Lots of good window choices: Pella, Anderson, Marvin and others.
You can do this job yourself if you spend a bit of time researching on the Internet/YouTube. It isn’t hard and you’ll know exactly what you got. But it is time consuming. Maybe buy one window where it won’t be too obvious and give it a try? I agree with those who already said cancel and take more time to evaluate. If Castle gives you grief about that, then you just learned something about Castle! |
09-14-2018, 03:00 PM | #15 | |
Rep 640
Drives: 2008 M3 (E93)
Just for a point of reference I bought 7 Pella double hung wood windows with the sashes last year for my house when I was renovating. It cost me $3700 USD just for the windows, no labor as I did the labor myself. Triple it you're at about 12k (21-22 windows) and about $200-$250 per window is general labor rate so you're right there with the large quote. Maybe should be a bit less
"Hard times create strong men. Strong men create easy times. Easy times create weak men. Weak men create hard times."
09-14-2018, 03:06 PM | #16 | |
Rep 4,136
SMFH why they so many window in my house |
09-14-2018, 04:15 PM | #17 | |
Space Force - 4 Star General
11486
Rep 3,265
We did 17 windows in our house for $21k. Granted NONE of them were standard shape or size, but the installers were super professional. There's a ton that can go wrong with a window install done poorly and since it's on the outside of your house you could never notice it until it's way late you have water damage, rot, insect infestation, etc. Best to stick to a highly rated product and installer. Same holds true for roofs. There's places you can save a buck and places where it's best to cough up the dough. This is not the time to look for a bargain price and discount installer. |
09-15-2018, 03:01 PM | #18 |
Rep 10,545
Full frame or inserts?
Inserts are the cheapest route. In any case you want to look at the attributes of the windows themselves. Not all window glass is the same. The can reflect varying abouts of heat l, UV, light. Local/state building code will tell you what's code min for your area. Frame composition is important as well. Vinyl covered wood, fiberglass, aluminum, wood.
"Drive more, worry less. "
09-19-2018, 06:41 AM | #21 |
Monkey Marshall
637
Rep 218
It can be a more than just window A and window B. No two windows are a like. The build quality, glass quality, and add-ons (argon gas, capillary tubes, etc) can all affect the price. Some companies use different types of film for their Low-E and HP Low-E film they use.
And sometimes you pay the price for the more known name brand because they will give you less hassle if you have to do any type of warranty or replacements that need to be shipped. You get what you pay for, remember that. |
09-19-2018, 07:59 AM | #22 |
Rep 835
Has anyone had any experience with Indow windows? We're remodeling a MCM home and would rather not change the look with replacement casement windows. These attach to the inside of the casement and provide thermal and noise insulation without changing the look, on top of which they are much less expensive. https://indowwindows.com/
