12-07-2018, 12:25 AM | #23 |
Rep 391
Drives: F87 M2C
I thought that for a moment too because it said something like "pad" instead of "pads" and the price, but I thought there would be no way to purchase sides separately instead of a full 4 pad set. They just came in and they are complete sets with new wear sensors and grease included. Also with just visual checks they look correct.
Past: 2011 Acqua Minerale Blue Hyundai Genesis Coupe 3.8 Past: 2017 Alpine White 440i F32 Current: 2020 Long Beach Blue M2 Competition PC Build: 5950x/6900xt |
eleven11371.50 |
12-07-2018, 07:16 AM | #24 |
Rep 373
Out of curiosity has anyone tried the m3/4 pads on the m performance brakes. I have them in red and my SA said they will fit as the calipers are the same? (at my cost obviously)
'14 F20 M135i EWG FBO:// INJEN INTAKE // PURE INLET// TURBOSMART BOV DUAL PORT // //CSF INTERCOOLER // ER CP // SNOW S2.5 METH KIT // B58TU HPFP // NGK 97506 // ER DP // TMSS MID PIPE //MPE // MPBBK // UR STRUT BRACE // BM3 CUSTOM JORDAN E85 TUNE // XHP STAGE 3 // |
12-07-2018, 11:08 AM | #25 |
Rep 1,523
12-11-2018, 06:17 PM | #27 |
Rep 373
i dont mind the dust are they better then the stock pads? am i correct in saying msport and mperformance use the same pads[
01-02-2019, 06:24 PM | #28 |
Masterchief
364
Rep 1,018
Any reviews on the akebonos or r1 concept ceramics??
So im assuming based off what everyone is saying the EUR1880 front will fit even the unfinished grey 4 piston brembos but the EUR1656 will not fit for the single piston rears???? is the 1656 does not fit do you know if the 1610 fit the single piston calipers?
AWE Non-Res Touring | TE37 SL PW | Ohlins RT Last edited by yoon_209; 01-02-2019 at 06:55 PM.. |
01-02-2019, 07:00 PM | #29 | |
Masterchief
364
Rep 1,018
So im assuming based off what everyone is saying the EUR1880 front will fit even the unfinished grey 4 piston brembos but the EUR1656 will not fit for the single piston rears???? do you know if the 1610 fit the single piston calipers?
AWE Non-Res Touring | TE37 SL PW | Ohlins RT |
01-03-2019, 05:24 PM | #30 | |
Rep 1,425
I've got the Akebonos sitting in a box, but haven't had a chance to install them, yet.
2017 X5M - Current
2017 F31 Wagon - Current 2014 M5 ZCP - Retired 2011 135i Coupe - Retired 2007 335i Sedan - Retired |
01-03-2019, 05:33 PM | #31 |
Rep 391
Drives: F87 M2C
From solely looking at pictures it LOOKS similar to it.
Akebono site, Tirerack, and Rockauto seem to say it would fit for yours. No mention of "Blue Caliper" in the listings. Mine too, another two weeks until my calipers are done with powdercoat. Then after that no idea when I'll have the time to install them.
01-03-2019, 06:20 PM | #32 | |
Masterchief
364
Rep 1,018
01-04-2019, 08:52 AM | #33 |
Rep 235
I did the install. Every now and then I get squealing under light braking, even though I applied anti-squeal to the recommended areas in the Bentley manual. Will try troubleshooting some more.
01-04-2019, 12:30 PM | #34 |
Rep 1,934
Not sure if this is already a required step, but is everyone changing the retaining clip with their pads as well?
mbanks211267.50 |
01-16-2019, 10:56 AM | #35 | ||
Masterchief
364
Rep 1,018
i've had them for a few days, no squeaking whatsoever, they do have less bite than oem but the brakes feel more linear and consistent and the best of all minimal brake dust.
01-16-2019, 11:04 AM | #36 | |||
Rep 235
01-18-2019, 07:29 PM | #37 | |
Rep 1,523
01-19-2019, 10:17 AM | #38 |
Rep 258
01-19-2019, 11:20 AM | #39 | ||
Rep 235
M4_GTS1152.50 |
01-20-2019, 05:29 PM | #40 | ||||
Masterchief
364
Rep 1,018
I've been hearing a quick oscillating noise when I drive with the windows down and it's definitely coming from the wheels.sounds starts at about 20mpb. It's not a squealing or grinding but a oscillating noise. The noise only occurs when I'm driving and there is no noise while I brake. I'm not sure if it's the akebono pads or the r1 concept rotors. Iv the pads and rotors for about 100 miles so far. Im guessing I need to give the pads and rotors more time
01-20-2019, 07:05 PM | #41 | |||||
Rep 235
01-22-2019, 12:36 PM | #42 |
Masterchief
364
Rep 1,018
i took it back to the shop that installed the pads and rotors and they are saying everything looks fine and to give it some more time. they are saying since the pads and rotors are new the buzzing sound could be a result of the pads making contact with drilled and slotted part of the rotor while driving. i guess we will see what happens in the next few hundred miles
01-23-2019, 10:12 AM | #43 | |
Rep 1,523
01-23-2019, 10:32 AM | #44 |
Masterchief
364
Rep 1,018
well that sucks
