Tirerack
Use the following links to go directly to useful tirerack winter items: Tirerack Winter Tires. Gary's Winter Tire FAQ.
Using the links directly supports E90Post with tirerack sales commision!
  E90Post
The Tire Rack
   PLEASE HELP SUPPORT E90POST BY DOING YOUR TIRERACK SHOPPING FROM THIS BANNER, THANKS!
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Technical Forums > Wheels and Tires Forum Sponsored by The Tire Rack > Tire size recommendations for new 20" wheels
Wheels and Tires forum Sponsored by The Tire Rack
Please help to directly support e90post by doing your tirerack shopping from the above link. For every sale made through the link, e90post gets sponsor support to keep the site alive. Disclaimer
Reply
      10-20-2018, 08:23 AM   #1
MineralweissIS
MineralweissIS's Avatar
47
Drives: 2012 Mineral White 335is
2012 BMW 335is  [0.00]
Hello all,
I currently run factory style 313 19" wheels on my 335is.
I custom ordered new 20" wheels with the following specs:
F - 20x8.5 et 38
R - 20x10 et 41
I am thinking 255/30/20 for the front and 295/25/20 for the rear.
Currently lowered on Eibach Pro Kit lowering springs. I would prefer not to roll fenders and minimize any rubbing.
Thanks!
'12 335is Mineral White Metallic / Saddle Brown / DCT / Nav / Cold / Premium / Convenience / H-K
      10-22-2018, 12:27 PM   #2
b92
b92's Avatar
Drives: E92 335is, 6MT
I don't know too much about 20" fitment on our platform but from my knowledge and experiences I don't think you'll be able to fit 295s without any fender modifications.
Also, 335is owners usually have issues with even 245/35/19 in front due to the ducts for the additional cooling; 235/35/19 is usually the 'no issue fitment' size. 255/30/20 would definitely require some shaving of the the fender liner for sure, since there's a 0.8" increase in radius between 255/30/20 and 235/35/19.
Also, do you plan on keeping your 313Ms? I've been looking for a set myself, my 335is came with 225Ms.
2011 E92 335is, Space Grey/Coral Red, 6MT.
RB 2+, Wedge tuned. E85 PI coming soon.
      10-22-2018, 05:53 PM   #3
MineralweissIS
47
Thanks for your feedback. I am taking your input into account because I had not given thought to the ducts for additional cooling.
I think you meant diameter, not radius. I actually got .8" larger going from my current stock size of 225/35/19 to my firstly 255/30/20. That's looking like too much based on the point you made.
If I try a smaller size, say 245/30/20, the diameter increases .6" (from stock) Maybe that's a safer bet? In total, I am calculating .3" more in diameter from the 'no issue fitment' to the newly considered 245/30/20.
I also have a E46 that I daily. I am going to swap the 313 wheels onto it. If that doesn't work, I'll make them available to you. They are in near mint condition.
      10-25-2018, 10:18 PM   #4
BM3Rrrr
Davy Jones, Giant Squid
BM3Rrrr's Avatar
Drives: a Pirate Ship
+1 for the bolded, I had these exact sizes on the front and rubbed with one and not the other
2010 e90 335i LCI - xHP - Mishimoto - BMS - CPe - Turbosmart - MHD - Eibach - Koni - VMR - LUX
      10-26-2018, 10:50 AM   #5
b92
b92's Avatar
Idk where the hell I got some of my numbers from, but there's only a 0.55" difference in diameter between 235/35/19 and 355/30/20. We know the following to be true:
235/35/19 (rub-free) diameter is 25.5", approximate width 9.25"
245/35/19 (rubbing) diameter is 25.75", approximate width 9.65"
255/30/20 would have a diameter of 26.02" with approximate width of 10.04". Both dimensions are larger than the 245/35/19 which rubs, so we know the conclusion there.
245/30/20 is very similar in size to 245/35/19, which can be fitted if the proper areas are modified; IIRC there's a bolt on the radiator vent (driver's side) that needs to be shaved down. For whatever reason, I have not heard the oil cooler vent (passenger side) causing rubbing issues, however I would recommend doing some research there.
Safest bet would be 235/30/20, which is only slightly larger than the 'safe' 235/35/19. Another option would be 255/25/20, but this is a pretty small sidewall protecting your rim. Diameter is less than the 235/35/19, but I'm not sure how the larger width plays out since I have no experience testing this limit, the widest I've gone in front is a 235.
And yeah, please keep me posted on the 313s! I've been back & forth on so many wheel options for next year but I decided I would pull the trigger on 313Ms (not the 313 'BMW Performance) if I could find a good deal. I think the finish on the 313Ms complement Space Grey very well.
Reply
e90post
