| 10-22-2018, 05:51 PM | #1 |
Rep 26
When cold outside i.e. less than 40 degrees F the car is unable to produce hot air. The climate control is set to 84, center dial is set to red, vehicle does not overheat, coolant was flushed 10,000 miles ago by Bmw dealer.
I used to get heat in the car within 2-3 minutes even when the engine oil temperature was at 160 (far left), however this doesn't happen anymore. I wonder if I have a partially stuck open thermostat? If the car is driven later in the afternoon the car is able to produce hot air and this issue doesn't occur. Any ideas? |
| 10-22-2018, 08:46 PM | #2 |
Rep 18,331
99% likely it's the thermostat. Suggest you list what you actually drive, it's a lot easier for those who have the same model and engine to give you the benefit of their experiences if they know what you have.
| 10-22-2018, 08:53 PM | #3 | |
Rep 26
2014 335i-m sport auto with 65,000 miles. |
| 10-22-2018, 09:00 PM | #4 |
Rep 4,981
With the car "warmed up", when you gas it on idle, do you get any heat? When my thermostat failed, it would not give heat unless I stepped on the accelerator.
| 10-22-2018, 09:28 PM | #5 |
Rep 18,331
| 10-23-2018, 04:55 AM | #6 |
Rep 26
| 10-23-2018, 06:28 AM | #7 |
¯\_(ツ)_/¯
537
Rep 1,000
If there's no heat at all it could be your blend door motor/actuator
| 10-23-2018, 07:27 AM | #8 |
Rep 18,331
That's a possibility, but not likely. A search of that problem shows that when it happens it's usually with only one of the vents, not all of them. Besides, the OP said that he gets heat later in the afternoon, when the outside air is warmer, and I suspect the sun shining on the car all day has had an effect as well, in essence pre-warming the engine and coolant.
| 10-23-2018, 08:02 AM | #9 |
Rep 26
| 10-23-2018, 05:56 PM | #11 |
Rep 26
| 10-23-2018, 06:36 PM | #12 |
![]() ![]() 186
Rep 335
Looks like the thermostat is about $130, then add coolant and labor and that figure sounds pretty close. Maybe a bit high.
Does your car actually get to operating temperature? Or does it run cold/fluctuate a lot? https://www.ecstuning.com/b-genuine-...t/11537598865/
2017 F80 M3 - Mineral White/Amaro Brown
2003 E46 M3 - Jet Black/Cinnamon |
| 10-23-2018, 06:43 PM | #13 | |
Rep 26
I haven't found a solid DIY for the f30 335i if you guys have any suggestions let me know. |
| 10-23-2018, 09:39 PM | #14 |
Rep 18,331
It will eventually get to operating temperature, or close to it, depending on the outdoor temperature. Catch-22 is the the colder it is and thus the faster you want to get heat the slower it is to warm, if it does at all. There are youtube videos how to change a thermostat. OEM will be really expensive, I'd go aftermarket. Even then figure about $100, as it's electrically controlled, and is nothing at all like $15 spring operated thermostats.
| 10-23-2018, 10:32 PM | #15 | |
![]() ![]() 186
Rep 335
DIY Here: Also looks like Borg Warner is the OEM supplier to BMW. FCP has it for $73 vs $130 for OE BMW... https://www.fcpeuro.com/products/bmw...ly-11537601158
| 10-24-2018, 05:29 AM | #16 |
![]() ![]() 3416
Rep 6,121
The engine doesn't need to be at operating temp for the heat to work as the heater uses a separate heater element and does not require coolant to be warm to work.
| 10-24-2018, 06:07 AM | #17 |
Rep 26
That is what I thought however I don't get any heat from the separate heater element. Does the thermostat control the separate heating element?
| 10-24-2018, 07:48 AM | #18 |
Rep 18,331
Some models have electrically assisted heating, primarily diesels, as it takes them longer to warm the coolant. The parts listing for a 328d shows it, that for a 335i does not. The listed part #64119230594 shows up in many diesel models, but no gas models.
| 10-24-2018, 08:33 AM | #19 | |
![]() ![]() 3416
Rep 6,121
| 10-24-2018, 09:26 AM | #20 |
Rep 18,331
The 340i parts list doesn't show electric heat assist, the LCI 328D does. My heat comes up a lot faster than my oil temperature too, usually within five minutes at 30F. The system probably allows flow of coolant through the heater core before it allows it through the radiator, for faster heating of the car interior, but I haven't come across anything definitive on that point.
| 10-24-2018, 09:43 AM | #21 | |
Rep 26
| Bookmarks |
