11-05-2018, 05:28 PM | #1 |
Rep 128
Shifter stiffness
Hey guys, I've had my F30 335i for about 2 years now, and lately I've been noticing something weird with the shifter on my car. I know in the colder weather the shifter gets a little stiff but since the end of the summer the shifter on the car is incredibly stiff. Honestly feels like it needs to be greased or tighten up. Any way to get to the shifter linkage, or is there something else I need to look into. Only drive the car on the weekends. Any help would be greatly appreciated
2013 F30 335IX M Sport 6MT JB4, BMS intake, ER Chargepipe, ER Turbo to Intercooler Chargepipe, ER FMIC, MPE
11-05-2018, 05:54 PM | #2 |
Respect My Authoritah
368
Rep 875
When was the last time the fluid was changed? Is this only from first to second or through all gears?
2014 335xi M-Sport 6MT: Estoril Blue II, MHD Stage 2+ , Dinan Exhaust, Dinan CAI, ER Catted DP, ER Chargepipe, AA FMIC.
11-05-2018, 06:15 PM | #3 | |
Rep 128
11-05-2018, 06:16 PM | #4 | ||
Rep 128
11-05-2018, 06:45 PM | #5 |
368
Rep 875
The side to side issue doesn't sound like a fluid issue, although I would recommend you change it. I used Redline MTL and love it, although it's not BMW approved. Lots of forum posts suggested it, so I went with it and it made everything smoother.
Just guessing... You either need to replace the transmissions detent pins, or the plastic cup that the shifter moves in. It's more likely the detent pins, unless you also feel slack in the shift.
11-05-2018, 09:12 PM | #6 | ||
Rep 128
11-05-2018, 09:31 PM | #7 |
Rep 1,115
I have a similar thing going on with mine. I had the fluid changed this summer and they put in BG syncroshift. After that it was really tough going into first when cold, but would operate normal or close to it when warm. I changed the fluid out a second time a few weeks later for the BMW OE fluid.
It fixed the issue a bit, but anything over 0mph when cold doesn't want to go into first. I never force it into first while moving, but in stop and go traffic its a pain trying to get it into first from second while at walking speed. Been half wondering if the clutch isn't going, but it doesn't slip at all and I haven't been rough on it, starting to worry the syncros are shot. |
11-06-2018, 07:51 AM | #8 | |
368
Rep 875
11-06-2018, 07:52 AM | #9 |
368
Rep 875
Unfortunately, they're in the transmission and very hard to get to. They can be replaced without removing the transmission, but it's a job.
11-06-2018, 05:55 PM | #10 | |
Rep 128
11-06-2018, 07:15 PM | #11 | ||
368
Rep 875
Here's where I got mine: https://www.summitracing.com/parts/r...iABEgJaDPD_BwE
07-29-2019, 02:51 PM | #13 |
Rep 65
Bump! Anyone that experienced this and any feed back on how to fix it without taking it to the stealership would be awesome!
F30 335i Glacier Silver 6MT
07-30-2019, 08:11 AM | #14 |
Resident Pedant
506
Rep 792
Easiest thing to do is to rebuild the shifter assembly, which will get rid of a lot of slop and is much less involved than doing the pins inside the transmission.
Even for an advanced home mechanic the transmission pins are dicey, IMO
'15 F30 335i 8AT Estoril II/Black (12.218 @ 114.94mph)
MHD Stage 2+ 93 / XHP Stage 3 / M-Goodies / K&N Filter / ER CP / CSF IC / NGK 97506 / ER DP / Michelin A/S 3+ |
12-10-2020, 11:25 PM | #15 |
Rep 63
Same stiffness issue here.....left-to-right stiffness
Ok...my car has the same problem
Everyone who is on here saying to change your fluid just needs to go home or first thoroughly read the initial description of the problem. The problem we are having is when we move the shifter from side-to-side. It has NOTHING to do with forward/aft movement of the shift lever. From what I have researched, it is a shifter detent issue. Unfortunately, the fix does not seem to be cheap or easy. The problem is that the shift detents live up in the top of the gearbox. They do not get lubricated by the tranny fluid. This was/is a common problem on The e46 manual transmissions (gearbox) also. It was a big enough issue that Shifter Detent Rebuild kits were made for those cars. There are several YOUTUBE videos on BMW SHIFTER DETENTS.....YOUTUBE search it. I can only speculate as to why the same type of kits have not come along for our cars, but it probably is because these car have not been around as long, and ALSO only a very small percentage of the Fxx cars came with manual transmissions (gearbox). Its a supply-vs-demand thing. Most CHUMPS got the AUTO. I have looked into getting the detent parts for the 6 speed, no parts are available. ZF does not sell parts for this gearbox. ItÂ’s a complete assembly if you want to do anything with it. The best solution I have found is getting a NEW gearbox for $3300, and they give you $1300 back for the core. $2000 and you have a fresh gearbox. Now....after watching some of those YOUTUBE videos, I have considered pulling the gearbox and seeing if I can remove and clean/lubricate the detents before I order a new gearbox. No matter what, the gearbox has to come out. I have a spare car - Toyota Corolla - which will NEVER die. So its an option I might consider. We got screwed on this one, unfortunately. I hope this helps |
12-14-2020, 10:04 PM | #16 |
Rep 3,681
12-09-2023, 07:02 PM | #17 |
Rep 241
Did anyone ever solve this? I have the same issue, when i shift out of either 1st, 2nd, 5th or 6th, shifter doesn't self center. It just stays off to the left or right (between 1st and 2nd or 5th and 6th) until i manually push it back to the middle.
12-11-2023, 10:08 AM | #18 |
Rep 13
I had this issue when I first picked up my car (used, 71k miles). After driving it for a few thousand miles, the problem resolved itself. Does your car sit without being used for any periods of time?
Other solutions I have seen have to do with detents in the transmission, which require removal in order to replace. This is a carry-over issue from the 5 speed ZF gearboxes. Google "E46 5th gear lean" for related information. |
12-11-2023, 05:45 PM | #19 |
Rep 241
Nah, i drive it daily. Interesting enough, inpulled up the shift boot and i think the issue is actually slop in the linkage. I ordered all the components to rebuild the shift linkage all the way to the trans and will install over the holidays and if that does ir
