BMW 5-Series (G30) Forum DIY Discussions / Guides / Instructions Subwoofer Amp install trigger problems
      12-01-2018, 07:02 PM   #1
LetsrollM550
LetsrollM550's Avatar
Drives: M550i
Anyone know where to run a trigger wire for install of a Alpine MRV-M500 with a audio control LC2i? Everything is hooked up, and they won't power on with the subwoofer/speaker level inputs, if I run a wire over to rear cig lighter amps power on and work but won't go to sleep mode. I need help!
      12-06-2018, 03:14 AM   #2
prince1566
prince1566's Avatar
Drives: 2018 530i M Sport
I think it takes about 10mins after the car is locked for everything to go to sleep.
      12-27-2018, 01:46 PM   #3
bigdaveindubai
Drives: 2018 540i
If you set the alarm will it power down?
      12-27-2018, 05:04 PM   #4
LetsrollM550
Drives: M550i
It's all worked out power down time is anywhere from 8 to 12 minutes. Locking didn't turn it off immediately, still had to go to sleep. Used a go pro to confirm, did it 4 times.
      05-15-2019, 07:23 AM   #5
netnick
Drives: BWM G30
Hi! The correct solution is PIN #13 on Quardlock connector of headunit.
      03-04-2020, 10:00 PM   #6
instalher
25cent millionaire
instalher's Avatar
Drives: 2020 m4 comp vert
2020 bmw  [0.00]
  [9.00]
  [0.00]
  [9.50]
2018 bmw 230i xdrive  [8.50]
run a 1amp fused wire to the front pass kick panel,,, go to fuse box z44, look at it and use fuse 59. its switched power
5post
