BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > Wheels and Tires -- Sponsored by The Tire Rack > Does Tirerack have solution for F30 spare?
European Auto Source (EAS)
      01-18-2019, 11:28 PM   #1
ashishnedungadi
Drives: 2017 340i xDrive M Sport
I have switched over to non runflats on my 2017 340i xDrive and need a spare tire solution. I have all the other pieces - air compressor, tire repair kit, jack, etc. I thought I'd go with a full size, but that might be too big and heavy. Does TireRack have a solution for a "donut" spare for the F30?
I need a tire that is 145/70 18, which is 26" diameter. Is there a wheel that can be used with this tire to fit the F30's?
Looking for recommendations. Thanks!
      01-19-2019, 02:53 AM   #2
cpxchewy
Monkey
68
Drives: 2020 M2C, 2014 320i
Bimmerzone has donut spares for F30. I have one for my F22 and it took up the perfect amount of space I was willing to sacrifice in the trunk.
1QuikWS61238.50
      01-21-2019, 03:17 PM   #3
1QuikWS6
No 55mph
1QuikWS6's Avatar
Drives: F32 435ix MSport ->M6
^^ This ^^
Bimmerzone is the only vendor I have found that carries Compact Spare for my 435 WITH the OEM MPerformance Brakes (370mm front/345mm rear) rotors/calipers
Many of the others carry versions that will fit the rear MPerf 2 piston calipers/345 rotors, but they wont fit the fronts with MPerf 4 piston calipers/370 rotors
http://www.bimmerzone.com/BMW_Perfor...T-F30-KIT.html
Additional Information:
Fitment
Specification Diameter Difference
145/70-18 (Spare Tire) 26.0in N/A
225/50-17 25.9in -0.5%
225/45-18 26.0in 0.0%
255/40-18 26.0in -0.0%
225/40-19 26.1in -1.3%
255/35-19 26.0in -0.0%
This is a completely bolt on solution for OEM brake setups. However this WILL NOT fit aftermarket Big Brake Kits or Carbon Ceramic Brakes.
F32 435ix//Mineral Gray Metallic//M Sport-Prem-Tech-Driver Assist-Lighting-Cold Weather-Dyn Handling Pkgs//M4 Black Leather Int w/M4 Alum Blade Trim//HK Sound+Musicar Stg3//763M Wheels//M4 Euro LCI Tails//M4 Mirrors w/CF Covers//AWCarbon CF F/R Spoiler-LED Sills-CF Shift Knob/Surround/IND M4 Alcantara Armrest//PURE S2 Turbo//AA FMIC+DP//ER CP+TIC//3.5bar TMAP/DV+//AWE Tuning Exhaust w/CF Tips//Dinan CF Intake//BM3 Cary Jordan Tune//MPerf Diff
      02-01-2019, 10:16 PM   #4
Golo2016
Golo2016's Avatar
31
Drives: BMW 340i
So the spare tire 17 inch from other years also would fit and clear the calipers of non MSport brakes on a 2016 340? I'm looking to resolve this issue since I also ditched the run-flats. I'm about to put a full-size wheel, but I'm concerned with the space it's gonna take.
