02-01-2019, 08:16 PM | #1 |
Rep 34
7506 LED bulbs that actually work?
So far I've bought 3 different types of LED white bulbs that I wanted to use for reverse lights and brake lights.
1 set shows bulbs not working, Next set was not canbus compliant, and the third set hyperflashes. I just want something that works, that isn't junk!! |
02-01-2019, 08:33 PM | #2 |
Rep 351
did you code your car to work with LED?
if you didn't that may be why you are having difficulties with all these LED bulbs you need to code your car to work with LED I am in NJ if you come down i can help you for free =) |
02-01-2019, 08:50 PM | #3 | |
Rep 34
I'm upstate so that's quite a drive. If I get down that way, I'll hit you up for sure. Thank you! |
02-02-2019, 12:08 AM | #5 | |
Rep 351
and pay for the bimmercode app, will cost about $50 but that'll take care of your problem instantly PLUS you can do a few cool things with it |
Medic-NY25.00 |
02-08-2019, 11:31 PM | #6 | ||
Rep 34
02-09-2019, 09:54 AM | #7 |
Rep 16,852
The first thing you'll want to code off is that stupid legal disclaimer that comes up on your iDrive screen every time you start the car. Having done that you'll want to kick yourself for not coding it out years ago.
BMW DIY Guy3474.00 |
02-10-2019, 05:20 AM | #8 |
Rep 68
02-10-2019, 11:15 AM | #9 | |||
Rep 5,467
Drives: F30
Also a WiFi obd donlge (Vgate iCar 3). Get it, trust us. |
02-10-2019, 11:16 AM | #10 | |
Rep 5,467
Drives: F30
Lots of worthwhile coding can be done with BimmerCode. |
04-01-2019, 04:30 PM | #11 |
Rep 433
Can you code off the chime that annoys you to put on your seat belt?
I would never think of driving without a belt. But in the last few days while my window tint sets, I've found myself having to climb out of my seat to wave my access card in front of the sensor so I can drive into my apartment complex. The only way to do that is to undo the belt, naturally, and since the gate does not stay open long, I have to put the car in gear right away and slide through the gate. Meanwhile, "bong . . . bong . . . bong . . ." Can you silence that by coding, I wonder? |
04-01-2019, 05:24 PM | #12 | |
Rep 68
Remember, you can also use the search function in the forum for specifics |
04-03-2019, 04:31 PM | #13 |
Rep 3,223
Drives: 2019 M2 Competition
Any opinion on what are the best LEDs for this? There are the german name sounding ones for like $80 a pair.. tons on Amazon for much less, let alone the morass of Ebay.
Any suggestions for what is best and actually work BETTER? I have heard stories of LEDs being far less bright.
Check out my BMW DIY Channel on YouTube! E, F and G series projects from Active Autowerke, Bimmertech, Kies Motorsports, AvinUSA, Karbonius Composites and more!
** YouTube BMW DIY Guy ** 'Nimona' G87 M2 Build Thread 'Lillith' F87 M2 Competition Build Thread |
04-03-2019, 04:37 PM | #14 |
Rep 440
Drives: 2013 335i xDrive
I'm not completely useless, I can be used as a bad example.
04-03-2019, 04:40 PM | #15 | |
Rep 440
04-03-2019, 05:27 PM | #16 | |||
Rep 16,852
https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1 Quote:
04-07-2019, 01:06 PM | #17 | ||||
Rep 3,223
04-07-2019, 04:52 PM | #18 |
Rep 16,852
I hope you verified what you need for a brake light bulb. Mine does not use 1156/7506, it uses H21W.
https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1 Mine does use 1156/7506 for the rear turn signal. |
04-07-2019, 04:56 PM | #19 |
Rep 3,223
*laugh* well I will double check now.. my other thought is this appear to be (maybe) the same bulbs in the tail of my E53 X5, so worst case I can use them there.
edit: yup they are... will put a pair into the X5 with another set coming, and then the correct ones for my F32 brake lights. Thanks man!
** YouTube BMW DIY Guy ** 'Nimona' G87 M2 Build Thread 'Lillith' F87 M2 Competition Build Thread Last edited by BMW DIY Guy; 04-07-2019 at 05:09 PM.. |
