02-26-2019, 11:13 AM | #1 |
Rep 67
P10D9 Code Thrown
I want to start off by saying first that I have already searched the forum and google, but this issue seems different than others because Im only getting the one code (P10D9). I just picked this 2011 335ix up on 2/17/2019, and under hard acceleration, like almost redlining in 3rd gear, my engine light has come on and at the same time, my display reads engine malfuction and I loose power. This has happened twice, and when I turn the car off and back on, it resets and seems okay. There are no mods to this car that I am aware of. The exhaust seems to be louder than stock would be but it looks stock. I dont see a jb4 or anything but it could be well hidden I guess. Any help or similar experience would be appreciated.
02-26-2019, 11:45 AM | #2 |
Rep 1,105
2011 335i, doesn't that have the N54 motor?
If so, you might be better off posting in that forum
02-26-2019, 12:42 PM | #4 |
Rep 1,105
Oh ok....
Was your car affected by the HPFP recall?
02-26-2019, 08:21 PM | #5 |
Rep 488
Fault Code Description
The diagnosis monitors the change in signal from the rail pressure sensor. Malfunction monitoring conditions The fault is detected whenever the voltage of the rail pressure sensor changes by less than 0 V. General Conditions Voltage precondition - Vehicle voltage between 9V and 16V Temperature condition - None Time condition - None Other preconditions - Engine ON - Rail pressure greater than 4 MPa Terminal status - Terminal 15 Service Plan ‐ Check wiring harness between DME and rail pressure sensor - Renew rail pressure sensor
2013 ActiveHybrid 3 (335ih) N55 PWG Meisterschaft GT catback Wagner tuning catless DP and Stage 2 Evo Comp Intercooler ER chargepipes CTS intake io2V3 O2 simulator Pure Stage 2 turbo with high-flow inlet and DV upgrade Fuel-It Stage 2 LPFP JB4 ISO firmware Fuel-It DIY PI Kit bootmod3
Dohc12015.00 |
02-26-2019, 08:30 PM | #6 |
Rep 488
Dohc12015.00 |
02-26-2019, 08:31 PM | #7 |
Rep 488
Page 9 has a picture of it's location in the engine bay:
http://www.burgertuning.com/instructions/n55_stage1.pdf
Dohc12015.00 |
02-26-2019, 08:36 PM | #8 |
Rep 488
I don't think it is, that was N54s. The late E90s came with N55s like his. However, it is subject to the blower motor wiring recall, so OP, get that checked out ASAP before your car burns down just sitting in your driveway doing nothing.
https://www.nhtsa.gov/vehicle/2011/B...DR/4WD#recalls
Dohc12015.00 bloodline12996.50 |
02-26-2019, 08:58 PM | #9 | |
Rep 67
Also, thanks for the info. I'm going to check the wiring and replace the sensor this weekend. My car is scheduled for the recalls. I think there are 7 total.
@proper_tuner
02-26-2019, 09:25 PM | #10 |
Rep 488
Check that link I posted above. You can search again by VIN to be 100% certain. I'm 99.9% about the blower motor recall, and please please please make sure it's addressed. Your car can literally go up in flames just sitting in your driveway or a parking lot (or with you in it driving). It has happened to multiple people.
bloodline12996.50 Dohc12015.00 |
02-26-2019, 10:21 PM | #11 | |
Rep 67
@proper_tuner
bloodline12996.50 |
