BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > N55 Turbo Engine / Drivetrain / Exhaust Modifications > HPFP New Option
      06-15-2019, 06:31 PM   #265
Munchi435i
Munchi435i's Avatar
Drives: 2014 Alpine White 435i M-sport
Originally Posted by Bmw doubles View Post
I guess the the idea for lpfp is too increase volume when using e85 and cram more into the hpfp. I think you're right in that cramming more 91-93 oct is not necessary for a stock hpfp. I believe that a lpfp upgrade is primarily for the purpose of an e85 application.
So,if an hpfp upgrade is installed, and you damn well if someone can run e85 they will, the lpfp immediately then becomes the bottleneck. So I'm saying I think they go together.
If you are going the route of a e85 mix then yes both the HPFP and LPFP are a necessary upgrade. But if you are going straight pump gas then no, only a HPFP will do the trick. Obviously once you start upgrading your fueling system it would only make sense to upgrade the LPFP since the cost is so much lower compared to the current price of a HPFP.
I have access to e85 but have no desire to run a e85 mix, mostly due to the tedious process of having to test ethanol content on a monthly basis. So for me running a straight 93 octane tune with a upgraded HPFP is highly desirable and if my LPFP needs replacing in the future I will do so.
      06-15-2019, 07:07 PM   #266
Marlinman
Drives: 2013 335i xDrive
you can get away with smaller percentage mixes of e85 without upgrading the LPFP.
      06-15-2019, 07:58 PM   #267
Bmw doubles
Dream crusher
Bmw doubles's Avatar
Drives: Fast
2011 535  [0.00]
Every time I do my pump crashes at wot when getting into the 3 digits.
535i MIssion Performance, PS2, Helix HPFP Kit, Wagner FMIC, Spec 3 clutch, Steel SMF, Wolf Racing CP, UUC SSK, GFB dv, SprintBooster, Custom Dynomax Exhaust, M5 Sways, Eibach OE Springs, Koni Sports Adjustable, Custom Short Ram CAI
IG: @bmwdoubles
      06-15-2019, 09:16 PM   #268
Marlinman
**throws money into pit** LOL I hear ya
what tune are you running?
      06-16-2019, 12:28 AM   #269
Bmw doubles
Dream crusher
Drives: Fast
2011 535  [0.00]
Mission Performance
IG: @bmwdoubles
      06-24-2019, 11:06 AM   #270
luchocamp
Drives: 13 335i xdrive M Sport
Originally Posted by JaredG_F30 View Post
Where are you guys buying these b58 HPFPs from? I can't find anything under $800.
I saw this one now
https://www.ebay.com/itm/15354119259...84.m1555.l2649
10.64 @129mph, LUCHOJB4,SPEEDTECH ST3, BMS BEF MHD, XHP, E40
drag track online set up contact on Instagram @luchocampusano cut 0.3 ~ 0.5sec without more HP or weight reduction.
      06-24-2019, 11:16 AM   #271
52172
52172's Avatar
Drives: 2015 Bronze Metallic 335i
Iím just to waiting for vis or twisted tuning to release theirs. The B58 is just a slight improvement.
      06-25-2019, 03:07 AM   #272
Amack
Australia
80
Drives: EB 2016 M235i
End of the year unfortunately
      06-26-2019, 10:00 PM   #273
52172
52172's Avatar
Where's the dude whose supposedly maxing out a B58 pump on the ewg n55?
2015 335i 6sp manual with MPK and sport pack
GPlus intercooler and CP. Stage 1. CG precision dp. Staggered 19?s. 275/35/19, 245/40/19 ps4s.
      06-26-2019, 10:22 PM   #274
T_H_O_M_A_S
Drives: M135xi
contact mr jozo crepulja ( avatar with red shirt and white dog ) on fb , he or his friend maxed out the stock turbo on an m2 with n55 engine and emix fuel running a b58 pump
M135xi , fbo , PS2 , MHD/wedge , HDP6 , Xhp AT
      06-26-2019, 10:48 PM   #275
52172
52172's Avatar
✅ thanks message sent.
      06-27-2019, 08:47 AM   #276
Amack
Australia
80
Spool performance have written back to me regarding the hpfp. They rekn they are 3 weeks away from release with a price tag of 1500 roughly.
      06-27-2019, 09:14 AM   #277
52172
52172's Avatar
Nice a third company developing one! Sounds like the first to bring it to market. 1500 is better than 2k. Iím very interested. Do they have a link to it?
      06-27-2019, 08:03 PM   #278
Amack
Australia
80
Nah this info was just chatting with them via there fb page.
It's great for another pump to enter the market however at only slightly less in price I wonder do you still go the xdi pump. It's proven to be a very good solution
      07-18-2019, 09:10 AM   #279
52172
52172's Avatar
Should be getting close to releasing it. Anyone else max out the b58 pump on the n55?
      08-14-2019, 09:11 AM   #280
T_H_O_M_A_S
Drives: M135xi
has anyone used this part before ? : bmw 13518631642
it the latest revision of bosch pump being used in latest bmw models ( new Z4 and supra aswell ) on all gasoline engines . it should have at least 15 percent extra
      08-14-2019, 09:41 AM   #281
52172
52172's Avatar
No, but I hear it's quite a bit better than the last b58 pump. I think it's the b58m?
      08-14-2019, 09:44 AM   #282
adrien78
France
36
Drives: BMW F30 335i
Couldn't find more than this informations attached.
      08-14-2019, 09:58 AM   #283
adrien78
France
36
It seems to be the same mounting plate than the B58 pump, so will need to be drilled too.
      08-14-2019, 01:38 PM   #284
Insane435
Insane435's Avatar
Drives: 435ix M Sport EWG
I wonder how it compares to xdi? Looks like it can be bought new for $1,055 (cheapest I found). Even if its not as good as the xdi, its less than half the price. If it allows the n55 to operate better, this would be interesting.
2014 EBII 435ix - Armytrix Catback, Evolution Racewerks Downpipe - Chargepipe - Intercooler, Bootmod3, NGK 97506's, AFE Dry Filter, KW V1, Forgestar F14 19s, Potenza S-04's, M Performance Brakes, M Power Pads
2011 BSM 328ix
IG: @f32_rmacher
      08-14-2019, 04:13 PM   #285
my335i403
Drives: 2014 335i
This is exciting, i am going to order my ps2 this week, so I planned on doing it two stages... turbo, then later hpfp... would love to do it all at once and be done with my build, besides brakes and coilovers.
Options coming soon I hope... or someone tries the part thomas is referring to above ...
just cant see paying 2200 for xdi pump
      08-14-2019, 05:42 PM   #286
T_H_O_M_A_S
Drives: M135xi
the only snag other than modifying the flange would be the connector ,
since its rotated like 135į CW compared to the older one , the connector might collide with the intake manifold
