03-14-2019, 03:36 PM | #1 |
Rep 29
Aftermarket Headlight options? (Advice please!)
Hi all!
I have halogens in my 2015 f30 and am absolutely ready to upgrade to something with decent quality lighting and ideally angel eyes. Was hoping to get some insight on which option to choose: Depos (most obvious option), though I prefer the LCI look. Ebay lights (similar cost to depos but have the updated LCI look, though I think the turn signal is a little ricey). This is my favorite option right now but I'm not sure it's worth it given rice factor and they aren't as common/well-reviewed as depos More ebay lights These are the cheapest option by far but I haven't heard the best reviews (and the leds look dotty which seems ricey to me). I like that this has the dual projector though. Alibaba lights (hella risky?) This is the ideal look I'm going for but I don't want to risk buying through Alibaba with no reviews. In all cases I'm planning on upgrading with a HID kit (or at least LEDs). Anyone have recommendations on this with regards to aftermarket lights? What would you recommend? I've seen a few of the install videos/threads on here and am planning on installing myself (though I don't want to take the wheels off since I don't have a jack/jack stands). Is this an awful idea? Thanks everyone!! |
03-14-2019, 08:18 PM | #2 |
Rep 417
It really depends on what you like.
From what I know, Depo makes pretty good stuff and it is plug and play, although the harness is a little longer (from what I have seen on Kies Motorsport). I would not opt for the Alibaba ones. My friend had some on his gti, the fitment was bad, some bulbs were welded in, and light were pretty scattered despite being projector. It lasted about 3 years and they were done. I have oem projector on my F32, the only thing I did was to change the signal bulb from orange traditional ones to silver LED. They are still orange, but you don't see it during the day. |
03-15-2019, 12:01 PM | #3 |
Rep 54
F30diva,
Check these out: https://www.protuninglab.com/20122014f30.html At one time I had Depos from USR and then I wanted to see if I could get the lenses replaced. That was a bad move on my part. Anyway, I needed new lights so I ended up getting these: https://www.protuninglab.com/20bmwf303seh.html I have grown to like them. I was running HIDs on them but then I found a really good set of LEDs - https://www.amazon.com/NINEO-Headlig.../dp/B01MFABBZW After some trial and error, this set up is working well for me. If you are still not sure, try and run the LED in your OEM headlamps. Use this as a guide - https://f30.bimmerpost.com/forums/sh....php?t=1349409 - https://f30.bimmerpost.com/forums/sh...&highlight=LED I hope this helps. |
03-15-2019, 12:26 PM | #4 |
Rep 29
Thanks!!
Photographerlife Were you unable to replace the lenses with the depos? Something I may want to do is mod them further (ie with Bavgruppe vision rings or something similar). What trial and error did you go through to get the setup working? Just coding out errors and fixing flickering with resistors? Thanks so much!! |
03-15-2019, 04:47 PM | #5 |
Rep 54
I took it to a guy in SoCal to get it retrofitted with clear lenses. He tried but failed and said it was really difficult to open them. Once he opened one of the headlights, he couldn't properly put it back together. However, retrofitting headlights is what he does as a business and I have seen his other work.
For the headlights I have now, I started with halogen bulbs. Tried a few - silverstar, ultravision, PIAA - to name a few. Then gave Morimotos a shot. MM worked well for sometime but I guess the canbus was fried and the setup started acting up. So I tried the MM LEDs. The problem with those was that they were a little too big compared to the H7 bulb size. The beam pattern was worse than halogens. Then I went back to HIDs. Had them professionally installed which worked for a short while and then this set started to turn on and off intermittently. So, I did some research and found these LEDs. So far they have been doing a good job. I just have to adjust the angles a little bit but other than that they are good. |
03-16-2019, 04:57 PM | #6 | |
Rep 357
03-17-2019, 08:41 PM | #7 |
Rep 54
Hey!!
So, depending on what headlights you pick you have the option to add HIDs to it. Send me the headlights you are looking at. I would be able to tell you better if I can see what you are looking at. |
03-19-2019, 11:12 AM | #8 | |
Rep 357
or https://www.protuninglab.com/hid-pro...12-drl-bk.html They look the same.. not sure of the difference, but I'd love to be educated! Also if anyone has these headlights on their car please post it! |
03-21-2019, 03:36 PM | #9 | |
Rep 54
I would suggest getting the one that comes with halogen (the cheaper of the two listed) bulbs and then put LEDs in them. |
03-21-2019, 04:11 PM | #10 | |
Rep 357
03-27-2019, 11:43 PM | #11 |
Rep 54
I have not had any issues with them. I did code out the warm/cold monitoring so that saves me the annoying warnings.
03-28-2019, 03:46 PM | #12 | |
Rep 2,036
03-28-2019, 04:24 PM | #13 |
Rep 2,709
I feel like we could easily get a 20 person group buy within a week or 2 for headlights and significantly lower the cost.
ya?no? |
04-23-2019, 07:58 PM | #16 |
Rep 1
2016 F30 Headlights
I actually have a similar question for my 2016 328i. I currently have the Halogen headlight and would like to change to the LED ring ones. I am pretty new to this so any help would work!
Could I buy some OEM LED headlights (not the XEON) and just plug them in? If so, could anyone give me the part# for ones that would work on my model, I would really appreciate it! I have looked to get some from USR but they only offer 2012-2015 model, however I have seen some on eBay that state 2012 - 2016. Would that mean that even a 2015 headlight would fit my 2016? I have seen some on eBay and CarID that state would fit but I am not a fan of the lego blinkers: https://www.carid.com/2016-bmw-3-ser...parentsubmodel[]=MODEL|328i I would prefer a look closer to the factory LED headlight! |
angel eyes, depo, diy, f30, headlight, upgrade angel eye |
