03-20-2019, 01:17 PM | #1 |
Rep 891
Timing Chain - Preventative Replacement Costs
Hey All,
With all the talk about the TC failures on our car I wanted to get a thread out to have people report what they were quoted to preemtively replace the chaindrive components. I am just getting over 75k at the moment and plan on replacing the chain within the next year. I assume I am not the only one on here who at least contemplated getting this done, it would be super useful for us all to have an average cost so we have a good idea of what to budget. From my recollection people have been paying between 2 and 3 grand for the job, wondering if that is accurate. Appreciate the input.
328i RWD | MW on CRed Slick Top | 6MT | BM3 | MPE | GPlus FMIC | CSF Radiator | Millway Street Camber Plates & Monoballs | KW V2 6k/18k Swift Springs | F80 LCA/TS | SPL Bump Steer Kit | APEX SM-10 | R-S4 | DS2500 | RBF600 | SS Lines | Past: E36 328is & E38 740i |
03-20-2019, 02:35 PM | #2 |
Rep 3,680
I'm at the same exact mileage, interested to hear people's responses.
03-20-2019, 03:31 PM | #4 |
Rep 40
I'm currently at 79k, stage 2 FBO for the past year, no issues. I do my oil changes every 3000-3500 miles, since I hear some talk that changing your oil often helps the problem. No leaks either, I feel like I'm at risk, I check the tension of the chain every month to feel if there's any slack too. Sub'd.
03-21-2019, 02:20 AM | #5 |
Rep 159
Interesting thread. Sub'd.
ejsanto Don't you ever feel a slack on your TC? I do on mine and I thought it's normal due to how tensioner is designed. There have been also some talk that depending which position crank shaft (or camshaft) stops when engine is shut off it's possible that TC gets some slack. It was something like camshaft allows some negative rotation if stopped in the "right" spot which causes TC to loosen up. That will be taken care immediately when starting the engine. FWIW, when I bought the car it was 1,5 year old and mileage was 48000. Oil were changed every 18000 miles. I have changed them every 9000 miles since then i.e. halved the interval. Now I have 91000 miles on clock and no problems yet *knocks on wood*. However, I do see some scoring marks (shiny patches on chain links) on my TC but I'm not sure if they means anything or not. At least my dealer was not worried about them |
03-21-2019, 08:00 AM | #6 | |
Rep 3,680
03-21-2019, 08:40 AM | #7 |
Rep 345
Great, another problem i have to worry about on my F30 335. Although this car may be fun to drive, quality wise its a piece of shit. Never heard of having to replace a timing chain; belt yes, chain no. Even the damn oil filter housing gasket leaks and needs a time consuming repair. What next, the sheetmetal going to fall off. I have 76k miles and this certainly my first and last BMW.
03-21-2019, 09:40 AM | #8 | |
Rep 891
Also, the oil filter housing gasket is a 30 minute DIY... Sorry to see you go!
328i RWD | MW on CRed Slick Top | 6MT | BM3 | MPE | GPlus FMIC | CSF Radiator | Millway Street Camber Plates & Monoballs | KW V2 6k/18k Swift Springs | F80 LCA/TS | SPL Bump Steer Kit | APEX SM-10 | R-S4 | DS2500 | RBF600 | SS Lines | Past: E36 328is & E38 740i Last edited by MacklinUSOB; 03-21-2019 at 09:46 AM.. |
03-21-2019, 04:06 PM | #10 | |
Rep 40
sspade2468.50 |
03-21-2019, 08:13 PM | #11 | ||
Rep 345
03-22-2019, 12:58 AM | #12 | ||
Rep 159
03-22-2019, 11:36 AM | #13 | |
Rep 3,680
03-22-2019, 12:47 PM | #14 |
Rep 414
Is this concern only related to N20/N26s built before 2016? I read BMW “fixed” the timing chain flaw starting 2016 but I’m wondering how to tell if my 2016 N26 has the redesigned chain or not? Is there a way to tell?
03-24-2019, 01:33 AM | #17 |
Rep 2
My concern is how do we know they 'fixed' anything? redesigning a part and obsoleting the old one is a great way to calm down the rumour mill. It is still an extremely rare failure but gets a lot of attention. The tensioner is stronger revised part and in other cars it has been a known point of failure. It is probably a good idea to replace it especially if you hear the slop noise in the engine.
03-27-2019, 05:11 AM | #18 |
Rep 661
Drives: 2014-320Xi / 2017-330Xi
As far as I know, the problem chain guides are orange, while the better ones are white plastic. You can see a corner of your time chain guides by opening the oil cover and looking the gap with a flashlight.
03-27-2019, 07:32 AM | #19 |
Rep 3,680
This theory was disproven when someone dug up a video of an N20 being assembled in 2012 with white chain guides. They all turn orange/brown from oil saturation over time. It's my understanding that you can't tell anything by color.
CandyRedRC46242.00 |
03-27-2019, 09:54 AM | #20 | |
Rep 5,458
Drives: F30
rjd_F302000.50 |
03-27-2019, 10:06 AM | #21 |
Rep 5,458
Drives: F30
Also-
Are we sure the guides were revised? I just checked and only the chain is showing as revised... the guides PN did not change... |
03-27-2019, 12:33 PM | #22 |
Rep 785
SUB
Was at the dealer for an oil change and asked them to check my timing chain. They reported back no issues or slack to be concerned with. I have 1.5 years left on my warranty. I was trying to get out of it and jump into a 2018 m240i in a stick that a sales rep was getting out of.... You would not BELIEVE what they wanted to offer for my car. Its crazy. Dont know if these timing chain concerns have killed the value of these cars but no way am I getting rid of this car for such a low quote. I mean, I LOVE my car. Exterior and interior are perfect, exactly what i want (m-sport black with red interior). I just would rather have a) a motor that doesnt sound like a TDI and b) a stick. But looks like if i dont want to burn a pile of money, i need to hold on to this car long term. Modding more when warranty is up. But yes, I do want to get the updated timing chain installed to avoid that headache down the line. |
