| 03-27-2019, 02:45 PM | #1 |
![]() 7
Rep 53
F30 320d noise after engine switch off.
Hi folks,
Never noticed this particular noise before after the engine is switched off. It seems to last for about 10 seconds. Is this normal? Seems to be from around the injector area under the engine cover towards the front. Car in question is a 2012 F30 320d automatic Last edited by jonnyni; 03-27-2019 at 04:03 PM.. |
| 03-27-2019, 03:14 PM | #2 |
![]() 1088
Rep 2,272
Drives: F30 335d
Doesn't sound normal to me. Never had that noise on my e91 with the same engine.
| 03-27-2019, 04:02 PM | #3 |
![]() 7
Rep 53
| 03-27-2019, 04:22 PM | #5 |
![]() 7
Rep 53
it cant be herd while the engine is running and sounds like its from the front of the engine around the injectors so I would assume its not the chain. Its under warranty so will get it checked asap.
| 03-27-2019, 05:04 PM | #6 |
![]() 1088
Rep 2,272
Drives: F30 335d
JoeyMcMahon10154.50 |
| 03-27-2019, 05:16 PM | #7 |
Rep 1,048
Drives: F31 320D Xdrive Msport+
Sounds like a solenoid having a fit to me.
[url=https://www.deutschespeed.com/threads/the-bimmerpost-refugee-thread.561/]Click here for the Bimmerpost UK Refugees - Censorship Sucks![/url]
| 03-27-2019, 06:47 PM | #9 |
Rep 9,090
My 30D makes exactly the same noise after the engine has been turned off. Lasts 3-5 seconds.
I have no idea what it is, but the engine is running well so I'm not bothered about it. Could be a solenoid cycling; fuel rail or injectors going through a pressure relief phase; hydraulic rockers ?
| 03-28-2019, 02:19 AM | #10 |
![]() 7
Rep 53
I wouldn't say short trips really. Use normal diesel mostly. Not sure what it is, will book it in with bmw and see what they say. Can only be herd when engine is switched off and the drive of the car is unaffected so far.
| 03-28-2019, 08:46 AM | #12 |
![]() 7
Rep 53
| Bookmarks |
