04-25-2019, 08:47 AM | #1 |
Rep 67
Overheating a B48 320i LCI
Just a simple question,, a hose part# 17128616536 disintegrated and I lost all water , a low coolant level popped up and after 5min or so another one with "drive moderately to let engine cool down" popped,, so I switched to eco pro to lower the engine load ,, continued for another 10 min or so, and the engines oil was normal on the dash,, let it cool and after an hour started the engine and topped the fluid but found out that all the coolant fell on the ground , due to this tube broken,,
Went to the shop and they changed the tube and made A pressure test with no water leaks found,, and I drove the car and it's fine,, the mechanic told me to come back after a week he will make another compression test to make sure there is no other water leaks , and said there is no damages done to the engine,, However I'm concerned if some damage could have sustained by engine, how would I know if any thing happened to the engine PS: I have driven the car for approximately 10 to 15 minutes without any water whatsoever, Last edited by GOLDENDUSt86; 04-25-2019 at 10:18 AM.. Reason: Photo upload |
04-25-2019, 10:53 AM | #2 | |
Rep 3,680
04-25-2019, 01:06 PM | #3 |
Rep 67
Thanks for the quick response 😊,, hope so,, actually the car is running fine with no issues, I'll go to the shop to make another water pressure test and I'll let u know if there is another updates
04-25-2019, 01:27 PM | #4 |
Rep 3,680
No problem
07-27-2022, 02:58 AM | #7 |
Rep 320
I had this exact same fault while on holiday 350 miles from home. I managed to buy the part locally and fix it. Bleed the system and the car seems like it's running fine. But I'm now shit scared to drive it back home
07-31-2022, 04:09 PM | #8 | |
Rep 67
08-01-2022, 03:49 AM | #9 |
Rep 2,806
Drives: F33 430 and F39 M35i
Drive it home. This happened to me in 2020 on my ‘18. I fixed it myself and drove it with no issues for another 8 months before I traded it in. Of course now BMW is covering repairs. Lol
08-02-2022, 03:09 AM | #10 |
Rep 320
Yeah I made it back home without issues. Hopefully it stays OK as I'm going to keep this car for another few years.
GOLDENDUSt8622.50 |
08-05-2022, 02:13 AM | #11 |
Rep 584
This pipe should be a recall item ASAP
[/B]2017 330e M Performance, MG Flasher Stage 2, RM Motors DP, xHP Stage 3, Armaspeed CIA
GOLDENDUSt8622.50 |
08-10-2022, 02:01 AM | #12 |
Rep 2,806
I believe it is a recall now?
GOLDENDUSt8622.50 |
