05-02-2019, 11:13 AM | #1 |
Rep 163
Style 763m Reps
Set of 4, never used as the offset was too aggressive for my taste. Gunmetal Gray 72.6mm Center Bore Front: 19x8.5 ET37 Rear: 19x9.5 ET35 Local pick up or buyer pays shipping. more pics upon request. $750.00 Last edited by PeaceWalker87; 05-02-2019 at 11:16 AM.. Reason: include price |
05-03-2019, 01:37 AM | #2 |
Rep 227
Where did you buy these?
bayarea_f307.50 |
05-03-2019, 08:30 AM | #3 |
Rep 163
05-08-2019, 11:43 AM | #7 | |
Rep 163
I've seen people run a square ET35 set up, but with minimal or no lowering and it sits flush with the car. |
05-08-2019, 06:59 PM | #8 | ||
Rep 824
05-09-2019, 07:55 AM | #9 | |
Rep 163
Here's an example of someone running a 9x9.5 ET35 on the rear, it would seem like there is minimal to almost no drop thou. https://f30.bimmerpost.com/forums/sh....php?t=1330334 |
05-17-2019, 09:52 AM | #14 |
Rep 483
I know this is not an ideal solution but hear me out...
Your fronts are not all that aggressive and your rears are pretty aggressive. The problem is that if someone wants aggressive the fronts don't work and if they want less aggressive the rears don't work. What if you bought another set that was more aggressive fronts, like 32-35mm offset and less aggressive rears, like 40+ offset and then swapped between the sets to have one aggressive set and one less aggressive set. That way you can also keep the less aggressive set for yourself and you'll also have a set that aggressive but more sell-able than you have now because it will match front and rear aggressiveness. Even if you don't keep one of the sets you'll have two sellable sets rather than a hard to sell mix and match. |
05-17-2019, 10:10 AM | #15 | |
Rep 758
MG F30 M-Sport 6mt FBO w/ MHD stage 2 plus (PWG), ST XA Coilovers, 19" VMR V804.
05-21-2019, 09:01 AM | #16 | |
Rep 163
That idea was actually thrown around by my friends, unfortunately I don't really have enough funds to buy another set. I barely had the money to buy a set that would fit (ET40 front & ET45 rear) that's why I really need to get rid of these. |
05-21-2019, 12:26 PM | #17 |
Rep 1,597
The fronts are fine. The rears aren't that aggressive compared to my rear 437m. You could run 265 35 R19 to bring in the poke some.
05-21-2019, 03:31 PM | #18 |
Rep 163
yea, it was an option, but given that im slammed, I didn't really want to run such a negative camber, or fender roll. plus I wanted more tire. I ended up goin with 285s on the rear.
05-22-2019, 11:28 AM | #20 |
Rep 707
this is 9.5+35 in the rear with a 265/40 tire. no lowering and it is perfect flush fitment
PeaceWalker8719.00 |
05-22-2019, 12:13 PM | #21 |
Rep 353
05-22-2019, 12:18 PM | #22 |
Rep 707
these are not the same as ops
fronts are 8.5+30, rears are 9.5 +35 |
PeaceWalker8719.00 sshahnavaz0.00 |
