BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > 2012-2019 BMW 3 and 4-Series Forums > Regional Forums > UK > 437M wheels on an F31 help re tyre size
      06-13-2019, 09:05 AM   #1
UnidoTom
Drives: G21 M340i
Hi
Have many people had joy fitting OEM 437M wheels to an xdrive F31?
I was hoping to just use my current tyres but by the sounds of it, they will be a bit of a stretch 225/40 and 255/35
What would be the best tyre size to go with and will these wheels work alongside ACS springs?
My knowledge is very poor so any help is much appreciated!
Cheers
      06-13-2019, 11:23 PM   #2
G50
G50's Avatar
Drives: G31, E92 M3
There are people in the US that have put the standard f30 tyres on 437m's, but it's not recommended as it is a bit of a stretch. When I was looking for wheels for my xdrive F31, I really wanted 437m, but in the end decided not to risk it and got 442m.
Then a few months later I swapped to an sDrive F31 for other reasons, but decided to get the 437's I'd always wanted.
Best sizes for fitment are M2 sizes, 265/35/19 and 245/35/19, but they wouldn't be recommended with xDrive.
danb19793613.50
      06-14-2019, 02:20 AM   #3
DaveH28
Drives: f31 335d estoril blue
Originally Posted by tom87uk View Post
Hi
Cheers
I've done it.. works fine and no problems.. have ACS springs too.
I got a lot of help off guys on here and took the plunge.
I've gone 235/40/19 at front and 265/35/19 at back.
Personally I wouldn't stretch the tyres, at the sizes I've gone everything is in the manufacturers guidelines..
APJ245.00
      06-14-2019, 03:31 AM   #4
Watsey
Drives: F31 330D sDrive M Sport
It partly depends on whether you like the look of rims poking out beyond the wheel arches.
They do poke - I went to see a set of 437s, fitted the rears, and measured the rear rims with a spirit level across the tyre beads, and a steel tape : 15mm poke on each side. Personally I think it looks naff, but it's purely subjective.
As has been said, you'd need to select the correct tyre sizes for x-drive. www.tiresize.com has a useful calculator.
      06-14-2019, 04:45 AM   #5
DaveH28
I agree they do poke..
Personally I like the aggressive cartoon look it gives... but can see how it's not to everyone's taste.
Doesn't look right without the side blades on or the lower suspension
      06-14-2019, 05:01 AM   #6
bill_f31
Drives: BMW F31 M Sport
225/40 & 255/35 for me.
sDrive and AC Schnitzer springs fitted.
Totally love them and so does everyone else,judging by the comments I get on my Instagram account.
DaveH28297.00
Rathian158.00
Lorcan3561.00
      06-14-2019, 09:35 AM   #7
jackstrath
Scotland
690
Drives: 16' F31 340i & 03' Focus RS
yeh im 225/40 & 255/35
a by Jack Strathdee, on Flickr
Fronts are a little more stretched that id like tbh, im yet to lower mine but do have coil overs to go on.
FYI different tyres look and fit differently, check your tyre make to see if they can be legally fitted to a 9j & 10j rim.
DaveH28297.00
      06-15-2019, 03:58 PM   #8
UnidoTom
Drives: G21 M340i
Cheers guys. I was going to go 225/40, 255/35 but then I read somewhere that with the stretch people have been experiencing pressure loss in the winter??
I will probably just give it a whirl as I already have them tyres and take it from there.
      06-17-2019, 01:21 PM   #9
R99
Drives: 2016 330d F31 Touring
xDrive - 235/40/19 & 265/35/19
sDrive - 245/35/19 & 265/35/19
I fitted them to mine ages ago (sDrive) everyone told me they wouldn't fit (they do) and now there are loads of people running them without issue.
They don't poke very much once the car is lowered - but with stock ride height they dont look the best in terms of fitment.
The tread block are very much under the arches, and I've never had any rubbing, even with the car fully loaded and on undulating country roads.
I've just refurbed mine satin black last week:
      09-01-2019, 06:37 PM   #10
docaam
Drives: F31 335d xi
Hey guys, I got M2 437m wheels for my 335D X drive, Im little concerned if can use the tires which these came with 245 35 19 & 265 35 19, should I change front to 235 40 19?
      09-02-2019, 01:23 PM   #11
R99
Yes.
docaam6.00
      09-02-2019, 01:33 PM   #12
too hot
too hot's Avatar
Scotland
113
Drives: None
I am running 437’s on my car and have been for a while.The car is lowered on ACS springs.
My tyres are 235/40/19 and 265/35/19 haven’t had any problems with rubbing
RS4
      09-02-2019, 03:04 PM   #13
docaam
Drives: F31 335d xi
Originally Posted by R99 View Post
Yes.
Thanks
      09-02-2019, 03:42 PM   #14
Hugrov
Drives: F36 LCI
This might help regarding tyre sizing with X-Drive. Personally I'd go 235/40 front and 265/35 rear to stay within 1% for the X-Drive.
      09-02-2019, 04:02 PM   #15
mcintoshf30
Drives: 2014 F30 335xi
I'm running 255's up front and 275's on the rear with xDrive, no issues so far.
      09-03-2019, 01:44 AM   #16
Clanger
Drives: F31 330d M-Sport
I’ve just bought a set of 437M alloys with 245/35 and 265/35 Michelin pilot sport tyres, also no problems with rubbing etc.
What tyre pressures are you guys running on these?
Cheers,
Gav
      09-03-2019, 06:02 PM   #17
G50
G50's Avatar
Drives: G31, E92 M3
I'm running 36psi all round with those tyre sizes. Not saying that's best though, buy has worked well for me over the last 6 month
      09-04-2019, 01:52 AM   #18
Clanger
Thanks mate 👍
      03-04-2025, 05:43 PM   #19
jmurino
Drives: 328d x drive
Looking for help with tire size, I’m debating picking up a set if 437m wheels this weekend for my f31. The tires on the wheels right now are 275/35 rear and 255/35 front. What size tires would I need to pick up to safely run 437m wheels. To add the car is lowered on kw coilovers.
      03-05-2025, 02:40 AM   #20
Read above ^^^
Post No.9
Alscoob2979.00
