| 07-25-2019, 02:47 AM | #1 |
Rep 170
Drives: F31 M Sport, 6MT, Alpine White
DIY: Ambient Light Retrofit (F30/31)
Hello, I have made a video about my recent mod, the Ambient Light retrofit.
In US Ambient Light is standard because it's part of the Light Package. (Also standard) In EU Light Package is option, so a lot of EU BMW's doesn't have Ambient Light, so I decided to make a video about it. Everything is OEM, except the Ambient door trim panels, because, 4 Ambient Lights in the BMW are around 240€ + taxes, which is a lot + they are really dim. You can fix it if you buy 3D printed transparent panels, but that is 60€ on eBay sold by "InteriorModz". After a little bit of research, I found on AliExpress all 4 trim panels for 75€ shipped + they are glossy black (to match the rest of the trim in my car) so I gave it a shot, and it turns out to work very well (with some minor modification) |
| 07-25-2019, 05:27 AM | #3 |
Rep 170
| 07-28-2019, 11:18 AM | #5 |
Rep 170
| 07-28-2019, 05:27 PM | #6 | |
Rep 7
| 07-29-2019, 04:36 PM | #7 |
Rep 170
| 08-07-2019, 06:47 AM | #9 |
Rep 170
| 02-10-2020, 01:54 PM | #12 | |
Rep 170
You have to look at your FEM and see do you have PINS where at A173*9B connector. Also, you have to check when model is your FEM, on the provided photo you can see that I have ZB10_HIGH_E, your is probably ZB6_MID_BIX or even lower. If it's ZB4, you probably wouldn't be able to retrofit Light Package option i.e Light Package. View post on imgur.com |
| 02-15-2020, 01:55 PM | #15 |
![]() 3
Rep 48
I have retrofitting footwell light with LED DOME. I l take Pin7 and now when I open the doors the footwell lighting now. It’s possible to take the some positive and retrofitting trim panel?
| 02-16-2020, 05:12 AM | #16 |
![]() 3
Rep 48
![]() Last edited by sylver65; 02-17-2020 at 02:49 AM.. |
sukhparm.775.50 |
| 02-22-2020, 07:00 AM | #17 | |
Rep 170
Pin 50 and 51 in the FEM A173*9B and Ground wire. |
| 03-01-2020, 02:58 PM | #19 |
Rep 20
This is a great video, very inormative and easy to follow. Well done Ace!
My F31 (MY2017) does not have ambient lighting, but I would be keen to light up around the central console housing the A/C and audio controls and also retrofit the the LED to light up the cupholders. Would you have any recommendations for setting this up at all? |
| 03-03-2020, 02:43 PM | #20 | |
Rep 170
So you want to retrofit LCI radio trim and cup hold light. It is possible, unfortunately I don't have a video about it, bcs my car already came with cup holder light, but I can give you some notes on how to do it. You need to add 3 wires to the FEM, connector A173*9B Pin 1: Ground (Connect it anywhere in the car to any brown wire) Pin 2: Ambient Light (Red Light) - Connect to FEM: A173*9B = Pin 51 Pin 3: Ambient Light (White Light) - Connect to FEM: A173*9B = Pin 50 You will use this cable for the cup holder and for the radio trim you need to make "Y" cable, there's a lot of videos on YT on how to retrofit LCI radio trim and how to make Y cable. After this installation, you need to code 563 and 7AC option |
| 06-20-2020, 02:01 PM | #22 | |
![]() 3
Rep 48
hello, I tried, but from the pins of the * 9b there seems to be no signal |
| Bookmarks |
