BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > 2012-2019 BMW 3 and 4-Series Forums > General F30 Sedan / F32 Coupe / F36 Gran Coupe Forum > Connected drive module where is it?
proTUNING Freaks
      08-11-2019, 09:03 AM   #1
Creedozz
Drives: F30 LCI
Hi everyone! Connected drive was suspended by the government in Turkey because the system uses not registered sim card and government doesnt allow to use non-turkish gsm operator. Redicilous!
So, i wonder if i change the sim card in the module, will it work? Where is the module? Thanks
      08-11-2019, 10:42 AM   #2
Enabled
Drives: 328xd Wagon, M2 Competition
It is called the TCB or ATM, depending on what your car is equipped with.
They have an eSIM that is not very easy to replace. Hot air station and careful soldering. I would say this is a bit hard even for the enthusiast.
Here I have replaced my eSIM from my old TCB module to another. This changes the ICC-ID (SIM ID) of the module.
If the ICC ID (and IMEI) of the module is different than what BMW has stored in their database, then ConnectedDrive will not work. So what you are looking to do, will not work.
-2019 M2 Competition MT, Alpine White. Self-tuned 560hp
-2016 Mini Cooper S, MT. Many plans.
Others:
-E36 328is. 2000 Z3 Roady. 2003 VW Jetta TDI Manual. Estoril Z3M Coupe.
      08-11-2019, 10:46 AM   #3
Enabled
Also the TCB (3g system) or ATM (4g system) module is located in the boot (trunk).
Others:
      08-11-2019, 10:50 AM   #4
Creedozz
Drives: F30 LCI
Thanks for the info dude. How can i access the module? Im new in this forum i need to learn so much thing i know 😊 if it is an e-sim it is not exist yet in turkey as i know. Could i change it with a traditoinal micro sim?
      08-11-2019, 10:54 AM   #5
Enabled
eSIM does exist everywhere. It is just a soldered SIM. It is probably possible to convert to nano SIM if you have the expertise.
BUT...
If you change SIM ID (ICC ID) then Connected Drive services stop working.
Others:
      08-11-2019, 10:56 AM   #6
Creedozz
Drives: F30 LCI
Is there a way to create a new id for nano sim
      08-11-2019, 11:00 AM   #7
Enabled
Not really. These are unique numbers.
So you either get your Turkish GSM provider to give you a SIM with your exact ICC ID (very hard), or you get BMW to change their servers to have a new ICC ID for your car (nearly impossible).
Others:
      08-11-2019, 11:02 AM   #8
Creedozz
Drives: F30 LCI
Ok then i give up. Thanks for info apreciated
      08-20-2024, 12:49 AM   #9
acediac
Australia
46
Drives: 1M, F30 330i
Thanks so much for identifying the eSIM chip. If I transfer my original eSIM chip from to a donor ATM board, and code my VIN onto the ATM module, will that be sufficient to restore all my services? Are there any other chips I need to transfer from the original ATM board that provide other IDs that are stored in BMW's databases to identify my car?
As a background, I have a water damaged ATM and have replaced it with second hand one. GPS works, but obviously not Connected Services.
      09-03-2024, 05:58 AM   #10
Fitf8
Fitf8's Avatar
Drives: BMW X1 F48
Enabled - any response please, will be very much appreciated! Thanks
As background, I tried removing the eSIM from donor atm but no luck. Hard as rock even with hot station kit. The black backing just broke off, leaving the pins in place.
