Login
08-13-2019, 09:24 AM | #1 |
![]() ![]() ![]() ![]() 272
Rep 482
B58 full teardown video
![]() Featured on BIMMERPOST.com |
08-13-2019, 01:09 PM | #4 |
![]() 13141
Rep 141,463
Posts ![]() |
STIMULUS SALE - UP TO 70%OFF XPH CARBON ** 10% OFF VARGAS TURBO
Phone 725-221-5267 || website www.x-ph.com ![]() |
08-13-2019, 02:59 PM | #6 |
![]() 11
Rep 46
On other cars, integrating the exhaust manifold has somewhat hindered performance of the aftermarket bolt on turbo. That integrated manifold sets the ceiling of performance. Where as the standard exhaust manifold can be redesigned to flow more.
M3 Adjuster7855.50 |
08-13-2019, 03:12 PM | #8 | |
E4 Mafia
![]() 78
Rep 194
I'm glad to finally confirm it though. been wondering.
Squad - E30 325i MT | E36/5 318ti MT | F22 M235i MT | F30 335i MT
KIA - E30 325i AT | E46 325i MT |
08-13-2019, 03:40 PM | #9 |
![]() 7856
Rep 11,814
wow that is some serious engine porn. Sure looks easy breaking down a motor that hasn't even been run in much....
I definitely learned a lot about the changing design of things like the exhaust manifold and also the radiator inside the intake as well as the way that the variable valve timing works to activate the intake cam. these days with turbo cars... it seems manufacturers are making these sorts of design changes to limit aftermarket modifications from damaging the stock motor. Another example is factory charge pipes made of plastic or rubber that will fail before they hold high boost.. |
08-13-2019, 04:03 PM | #10 |
![]() ![]() ![]() 2646
Rep 6,352
B58 represents a measurable improvement over N55. Having driven both, B58 is by far the preferred choice for me.
Great video! |
08-13-2019, 04:44 PM | #12 | |
![]() 163
Rep 253
(Image of a product for VWs for reference) ![]() |
kern4173239.50 |
08-13-2019, 05:13 PM | #13 |
![]() ![]() 2250
Rep 5,655
I thought this has valvetronic so the throttle body is at WOT at all times. I couldn't find my earlier post it is in a different thread, they should be merged.
B58 teardown video ~ any idea how close this is to the b58 found in the 2016-2019 340 https://f30.bimmerpost.com/forums/sh....php?t=1643084 |
08-13-2019, 05:22 PM | #14 |
![]() ![]() 1383
Rep 2,241
Yes, but that still doesn't change the limitations from the presumably smaller and unmodifiable(new word) ports in the head.
08-13-2019, 05:27 PM | #15 | |
![]() ![]() 825
Rep 1,338
08-13-2019, 05:27 PM | #16 |
![]() ![]() ![]() 5862
Rep 5,318
This teardown gave me a chubby.
08-13-2019, 05:30 PM | #17 | |
![]() 163
Rep 253
Also, 700hp 4 cylinder VWs don't seem to have an issue with this. |
08-13-2019, 05:52 PM | #18 |
![]() ![]() 1923
Rep 2,483
What is the power ceiling with the integrated manifold though? I bet it's way higher than most tuners target. Very high power builds might be able to just swap in a head from another B58 (B58B30M0) with a custom manifold.
08-13-2019, 05:59 PM | #20 |
![]() ![]() 1383
Rep 2,241
I didn't say what the limits were, but it is a limitation compared to a standard head/manifold setup. You are all right though, because it will probably support plenty of HP for most people using this engine.
