BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > F30 DIYs and Coding Discussions > Need help coding out front pdc
Studio RSR
      08-13-2019, 11:25 AM   #1
jaypayne05
Drives: 435i Gran Coupe M Package
Ok I'm new to this coding thing, my pdc front sensors keep malfunctioning and I want to just turn them off and keep my back ones working. I'm just tired of replacing them and clicking to turn off the warnings. It's a 2015 435 grand coupe. I have sides and back up camera also I would like to keep the cameras on. How do I code this out.
435i M Package, VRSF FMIC, VRSF CP, MHD stage 2+, stock cat
      08-14-2019, 11:26 AM   #2
atzebmw
Drives: Tesla Model 3
Change the "508" in your VO to "507" and code the REM and HU with it.
      08-14-2019, 11:45 AM   #3
jaypayne05
So I use BimmerCode for my coding. So I have to go in to the rear electronic module and replace 508 with 507 and also the head unit. What is VO? I'm not too familiar with that
      08-14-2019, 12:42 PM   #4
atzebmw
Ah OK.
VO is the vehicle order which you can't edit with Bimmercode.
No, if you use Bimmercode then go another way.
Try to change the following values if you find them:
in REM:
PdcParkMasterVar 3203 > A_HYSTERESE = wert_02 to wert_01
PdcParkMasterVar 3203 > D_SCHWELLE_1 = wert_02 to wert_01
PdcParkMasterVar 3203 > D_SCHWELLE_2 = wert_02 to wert_01
PdcParkMasterVar 3203 > V_SCHWELLE_1 = wert_02 to wert_01
PdcParkMasterVar 3203 > V_SCHWELLE_2 = wert_02 to wert_01
PdcVarCoding 3200 > PDC_VARIANT = wert_02 to wert_01
in HU
EXBOX 3001 > PDC_SENSOR_VORN = 4_sensoren to kein_Sensor
      08-14-2019, 08:15 PM   #5
jaypayne05
Ah OK.
in REM:
in HU
Ok thanks I will try that and report back
      08-14-2019, 08:52 PM   #6
jaypayne05
Ah OK.
in REM:
in HU
So I did it and it worked perfectly. Thank you very much.
atzebmw588.00
      10-27-2019, 04:07 PM   #7
Littlebear
Drives: ...the Mods crazy.
Hello BMW Experts!
Last time I had Esys working, I coded out the PDC chimes, front & rear. Unfortunately, I also lost the front PDC camera.
Now that I have Esys working again, I would like to code my front PDC camera back on. Can anyone give me the coding lines, pls?
TIA! Murf
      10-28-2019, 03:55 AM   #8
atzebmw
Originally Posted by Littlebear View Post
Hello BMW Experts!
TIA! Murf
What do you mean with Front PDC camera?
There's no front camera available for F3x.
      10-28-2019, 05:58 AM   #9
Littlebear
Well blow me down!
What does the front PCD do, just beep?
No camera in my center rear view mirror?
Murf
      10-29-2019, 04:06 AM   #10
atzebmw
Well blow me down!
Murf
Yes, the front PDC only makes beep.
If you have a camera in the center rear view mirror, it is only for Speed ​​Limit Info or Lane Departure Warning.
Maybe you have cameras in the exterior mirrors.
They are for surround view.
      10-30-2019, 12:07 PM   #11
Saroo
Drives: BMW 335D
I tried to follow this changed the vo file codes it in into modules hu and rem also went into files and the instruction for bimercode (using e sys) still front sensors are not coded out and throwing up error code any ideas?
      10-31-2019, 06:01 PM   #12
jaypayne05
Use BimmerCode and follow the instructions above
      10-31-2019, 06:05 PM   #13
jaypayne05
Use this it works
Ah OK.
in REM:
in HU
      09-30-2020, 12:45 PM   #14
Pogne
France
Drives: G31 530d xDrive Luxury
Ah OK.
in REM:
in HU
Thank you very much, just made the changes within Bimmercode and my front PDC retrofit is now complete.
atzebmw588.00
      04-16-2021, 04:15 PM   #15
Axis527
Former WRX Geek
Drives: 2014 335xi Sport Line
Ah OK.
in REM:
in HU
I just wanted to say thank you to a true hero lol. My front right pdc has been acting up for a few months, and after replacing the sensor and whole front harness I was about to give up. Code reads “8032e8 front outside right ultrasonic sensor: line interruption.” Shop warned me that diagnosis could run up to $1k depending on the issue, and since I don’t care about pdc at all I’m not paying that much to trace the problem. I asked if I could code out the warning, and the only way they found was to code out pdc which also eliminates my camera. So I turned to the forum, and lo and behold, this worked perfectly. It eliminated front pdc, kept the rear sensors and cameras working. Exactly what I needed. Thanks again.
atzebmw588.00
      07-17-2021, 10:20 PM   #16
Bruceking07
Drives: BMW 328ix
I can also confirm that this code works for the front. Now does anyone know how to code out the rear PDC with bimmercode?
      07-20-2021, 03:56 PM   #17
atzebmw
REM_01 > EcuHwConfiguration 3000 > HW_OPTION_BODY_PDC = nicht_aktiv
REM_01 > PdcParkMasterVar 3203 > A_HYSTERESE = wert_01
REM_01 > PdcParkMasterVar 3203 > D_SCHWELLE_1 = wert_03
REM_01 > PdcParkMasterVar 3203 > D_SCHWELLE_2 = wert_03
REM_01 > PdcParkMasterVar 3203 > V_SCHWELLE_1 = wert_03
REM_01 > PdcParkMasterVar 3203 > V_SCHWELLE_2 = wert_01
REM_01 > PdcVarCoding 3200 > PDC = wert_01
REM_01 > PdcVarCoding 3200 > PDC_VARIANT = wert_04
HU_NBT > EXBOX 3001 > MACRO_PDC = nicht_aktiv
HU_NBT > EXBOX 3001 > PDC_SENSOR_HINTEN = kein_sensor
      07-29-2021, 02:42 PM   #18
Ikoll
Drives: 2017 330i F31 m-sport
Trying to code front pdc with bimmercode but I do not have wert_01 as a alternative?
" PdcParkMasterVar 3203 > A_HYSTERESE = wert_02 to wert_01 "
I have wert_02 and aktiv as alternative.
aktiv has value 0x01
Tried to make a custom value with 0x00 but still no pdc. Rear pdc and button works great.
Any ideas?
      07-29-2021, 02:49 PM   #19
atzebmw
Any ideas?
Then choose aktiv.
      07-29-2021, 03:36 PM   #20
Ikoll
Then choose aktiv.
I did. Nothing.
Do you know what value wert_01 should have?
      07-29-2021, 03:44 PM   #21
atzebmw
I did. Nothing.
You retrofitted the front PDC?
Then you have to set all values to WERT_02.
Because the first question here was to code out the front PDC.
So here again all values for the Front PDC retrofit.
REM_01 > EcuHwConfiguration 3000 > HW_OPTION_BODY_PDC = aktiv
REM_01 > PdcParkMasterVar 3203 > A_HYSTERESE = wert_02
REM_01 > PdcParkMasterVar 3203 > D_SCHWELLE_1 = wert_02
REM_01 > PdcParkMasterVar 3203 > D_SCHWELLE_2 = wert_02
REM_01 > PdcParkMasterVar 3203 > V_SCHWELLE_1 = wert_02
REM_01 > PdcParkMasterVar 3203 > V_SCHWELLE_2 = wert_02
REM_01 > PdcVarCoding 3200 > PDC = wert_02
REM_01 > PdcVarCoding 3200 > PDC_VARIANT = wert_02
ICMQL > Daten 3000 > IcmKod_B_S508A = aktiv
HU_NBT > EXBOX 3001 > MACRO_PDC = aktiv
HU_NBT > EXBOX 3001 > PDC_SENSOR_HINTEN = 4_sensoren
HU_NBT > EXBOX 3001 > PDC_SENSOR_VORN = 4_sensoren
      07-29-2021, 03:55 PM   #22
shiftdnb
Drives: 2017 F31 328dx
I have cameras on my front bumper on the sides just ahead of the wheels.
