08-17-2019, 05:42 PM | #1 |
Rep 186
Maintenance at 60k miles?
So my car is coming up to 60k miles. It's a late 2015 418d with a manual gearbox and the newer B47 engine.
I'd like to make sure the car is well maintained going into higher mileage and being out of warranty. I'm currently at 55k and it had the final service (engine oil and filter) with it's service pack at 50k. When it hits 60k I think I'll have the following done Engine oil and filter Gearbox oil Differential oil Full coolant flush Is it worth having all these fluids changed, some say it is a must but some say not to bother. I'll probably get it done anyway. Can't hurt to spend the £200 odd it will cost to prevent a larger problem down the road. Are there any other fluids worth changing whilst the car is in the shop? I'm going to have engine oil and filter changed every 7.5/10k. iDrive says every 19-20k but I think I'll do roughly half that. |
08-21-2019, 09:38 PM | #3 |
Rep 59
^this.
2013 EB 335i Xdrive, Msport package, BM3 Stage 1 93 octane, VRSF Chargepipe
08-24-2019, 06:24 AM | #4 |
¯\_(ツ)_/¯
951
Rep 1,763
Yes absolutely change all of those fluids. Other than that everything SHOULD be sound. Expect to change shocks/struts around 90,000km
TaranF32129.50 |
08-24-2019, 05:25 PM | #5 | |
Rep 186
I have the adaptive m sport suspension and have heard of shocks/struts needing replacing at around 160,000km. My car is at around 90,000km/55,000 miles and the suspension is still smooth. I'll keep it in mind though! |
08-24-2019, 09:20 PM | #6 | |
¯\_(ツ)_/¯
951
Rep 1,763
09-08-2019, 10:13 PM | #7 |
Rep 25
I'm approaching 60k miles as well. I ordered the ZF fluid/filter replacement kit and am going to take a go at replacing the fluid soon. I suppose I may as well do the diff fluid while I'm under the car.
Anything else besides coolant that should be done while I'm under there? Engine oil was already changed only 1-2k miles ago. If not, anything I should at least check out? Corrosion, common wear items, etc.? |
09-14-2019, 08:10 AM | #8 | |
Rep 10,399
Water pump or thermostat failure (replace hoses down there as well). OFHG failure.
"Drive more, worry less. "
09-20-2019, 03:49 PM | #10 |
Rep 175
Hey, don’t want to thread jack, but I just got back from a local mechanic and he did:
Oil/filter change Coolant flush Differential flush Auto trans flush It was $650 out of the door....is that in the ballpark or a little high? Labor was around $325... |
09-21-2019, 10:43 AM | #11 |
Rep 186
Doesn't sound bad, I know the auto trans flush is very expensive. People pay like £300 for it here in the UK
09-21-2019, 11:00 PM | #12 |
Rep 10,399
Good deal.
