08-18-2008, 04:33 PM | #1 |
Rep 658
Removing Residue from Windshield
My car was in the body shop to be repainted after a cab drove into me. When I picked it up from the body shop there was a weird residue on the windshield and a bit on the trunk. It feels kind of rough and is mostly see though. I've left a message for them to find out what it is and how to remove it but I was hoping someone here might be able to tell me what it could be and how to remove it. Its a pain in the ass to drop the car off fo rthem to do it as they open after i go in to work and close before I'm done.
08-18-2008, 04:44 PM | #2 | |
Moderator
94
Rep 1,920
For the glass, you can buy a water spot remover from any hardware store, home depot, etc.. Some are liquids and are similar in consistency to "soft scrub". Some are powders that you use on a wet cloth. I found they both work great....I think something like this is your best bet, but do NOT use it on any painted surface, it will scratch the clear coat! Keep it on the glass and it will look brand new. It will require a bit of elbow grease though! For the trunk, I would wash first, then clay bar, then wax. The clay bar will take out the overspray and any other contaminants. Claybars can leave slight scratches in the clearcoat, so you may have to go to a swirl remover compound before your final wax. You could also just try a swirl remover first to see if it will remove the overspray...then wax. Depends how bad it is.
Tim <--- apparently likes "3" cars
2014 E63S -- The Rocket 2014 F30 328i -- Kids car 2008 E90 M3 -- Sold 2004 GT3 -- Sold 1997 M3/4 -- Sold 1995 M3 -- Sold |
08-18-2008, 09:33 PM | #3 | |
Rep 658
I'll give that a try, thanks for the tips. It seems odd to me that they would have got the spray where they did. the cab damaged the passenger side doors and the residue is on the driver side of the windshield and trunk |
