08-26-2019, 02:06 PM | #1 |
Rep 5,799
Need Winter Tire & Size Advice Please?
Starting to think ahead to what winter tire and size to get just a few months from now. Stock tires were runflats in 225/45-18. This past Spring installed summer goflats : Michelin Pilot Sport 4S in 245/40-18. The MPS4S are incredible. Wish there was something like that for bad weather. When the outside temperature gets down in the 40's I'll need to switch to some sort of all-season, winter or snow tire.
I'm in NJ where it has been averaging roughly 25 inches of snow a season which is about what NYC gets but less than the 40-50 inches they get in Boston. NJ winters often mean dealing with icy roads as much or more than snow covered roads. To deal with winter ice and snow like I described in NJ would you recommend an all-season, winter or snow tire. Any particular tire models? I recall some TireRack advice where they recommended going down a wheel size to have more sidewall in winter. 18" wheels are it for me because M Performance brakes can't go less than 18's. Probably the biggest sidewall I could get would be by going with 245/45-18. For snow and ice is it better to have a thinner tire like a 225/45-18 or a wider tire like a 245/45-18? Any advice is appreciated! Thanks. |
08-26-2019, 02:59 PM | #2 |
sucka for a longroof
29
Rep 70
Narrow tires help cut through the snow while a wider tire tends to make you float on the snow. I would go with the stock 225/45-18. I run dedicated snows too - worth it even for a couple of days that i might be driving in the snow and slush.
08-26-2019, 03:03 PM | #3 |
Rep 2,850
Drives: F33 430 and F39 M35i
Grab a set of 18s and stick with 225/45/18 for winter.
08-26-2019, 03:37 PM | #4 |
Rep 4,506
i'd go the happy medium 235/45/18. bridgestone blizzak ws90 or nokian hakkapeliitta
here's thx@ wdeerfield with 235/45/18 on 18x8.5 square https://f30.bimmerpost.com/forums/sh...&postcount=110 https://f30.bimmerpost.com/forums/sh...81&postcount=7 https://f30.bimmerpost.com/forums/sh...06&postcount=8 Last edited by alohasurftoad; 08-27-2019 at 12:11 AM.. |
Machinebuilder277.50 wdeerfield2796.00 |
08-26-2019, 04:11 PM | #5 |
Rep 219
08-27-2019, 02:38 AM | #6 |
Rep 864
so here in Australia we dont get the crazy snow falls that overseas do. However we are legally required to carry snow chains in our alpine areas and very rarely have to put them on
I have a set of snow chains for my 255/35/19 stock m sport tires for the rears. While they "fit" and i have tried them on They are pretty close to the guards and the plastic wheel arches. I also noticed with all the gear in the car the car drops a little and I question it So here is my thoughts. The stock 18in rims would work right? However would the front 19inch rims running the 225s work on the back. I can get 2 second hand ones from the wreckers. that way i have marching rims and only need to change 2 tires when I go to the snow. would that give me extra clearance around the arches and guards? |
08-27-2019, 07:11 AM | #7 | |
A family of bimmers
2796
Rep 7,754
I went up to the 235/45/18 to have a little better sidewall than a slightly stretched 225. This size provided a meaty sidewall with more rim protection and has not really limited my driving on dry roads during the winter. Granted a narrow tire will do better with lane changes where there is sluth between the lanes but the 235 manages fine for me and i daily this car and on weekends drive to vermont to ski, often on snow covered roads in hopefully "bad" weather. blizzak or the hakkapeliitta will be much better than my iceguards by yokohama. I went with this to give them a shot and the price was attractive at $130 a tire in this size.
alohasurftoad3306.00 |
08-27-2019, 10:25 AM | #8 |
Rep 10,613
Adding a bit more to an already helpful list of suggestions.
I had very good experience with Pirelli Sottozero winter tires. During the winter, run flat tires may save you from changing the tire in slush and ice after an unexpected encounter with a snow covered pot hole. |
08-29-2019, 11:58 AM | #9 |
Modder of everything I own
147
Rep 491
I did stock size Blizzaks (225/45/18) on my stock wheels. Not bad at all! Summer I'm running the Michelin Pilot Super Sport - 255/35ZR19/XL Square set up.
I seriously thought about getting all seasons as well since there are not many days I have to drive in deeper snow but I'm glad I went with the Blizzaks. I was worried about low sidewall stiffness, which was really apparent with my 540i, but the handling is much better on my 335xi.
2013 BMW 335xi F30 N55 PWG/VRSF DP/ER CP/Injen CAI/AA FMIC/JB4 map 7/Fuel= E50 w/ E85:93oct/Stock LPFP & HPFP/CATuned coilovers/Megan Racing Rear Swaybar/Powerflex Rear Subframe Bushing Inserts/Dual aFe Power Mach Force Mufflers/Resonator Delete/MHD & BMS Race BEF
johnung4941.00 |
