08-28-2019, 02:23 PM | #1 |
New Lifetime Replacement Policy
818
Rep 11,738
NEW NEW NEW! Turner Rear Sway Bar Upgrades!
The Turner Motorsport Rear Sway bar upgrade kit is a great way to reduce body roll and under-steer. The factory sway bar on the F3X chassis is very small and thin from the factory!
Made from hollow 22.5mm DOM tubing, and blue powder coated for corrosion resistance. This sway bar is paired with 80A Durometer custom polyurethane greaseable bushings, with a grooved bushing inside diameter for improved grease retention. Black anodized 6061-T6 billet brackets with check valve grease port hold it all together. The NEW Turner Rear Sway Bar Upgrade! F22 - 228i, M235i, M240i F23 - 228i, M235i, M240i F30 - 328i, 335i, 340i F32/33/36 - 428i, 435i, 440i |
