09-07-2019, 08:56 PM | #1 |
Rep 5,463
Drives: F30
Will this wheel fit on F30 ?
Forgive the ignorance...
Looking at a set of steel wheels for occasional winter use. What size winter tire would fit this wheel? The size is: 16X6.5 The bolt pattern is: 5X120 |
09-08-2019, 06:40 AM | #3 |
Rep 495
Drives: BMW 330e F30 M-sport
195/55R16 or 205/55R16 would fit on this wheel. As mentioned above, this won't fit if you have M-sport brakes. Not even all 17" wheels will fit. If you have regular brakes it will be fine, but 16" is pretty small for this car.
Thorbjorn
16 BMW F30 330e M-sport Bootmod3 Stage2 / BMS Intake / RM Motors high flow catted downpipe & custom exhaust / BBS CH 19" / H&R Sport springs |
sspade2481.00 |
09-08-2019, 06:55 AM | #4 |
Rep 13
6,5j on F30 is definitely too narrow. Standard F30 16" dimensions are 7jx16 ET31 with 205/60 r16 tyres or 7,5jx16 ET37 with 225/55 r16 tyres
You can probably stick with 6,5j but some smaller ET or with some distance plates and for sure 205/60 r16 not 55 r16, it will result with a big gap between fender and tyre... What is the ET of your wheels? |
sspade2481.00 |
09-08-2019, 08:25 AM | #5 | |
Rep 495
Thorbjorn
sspade2481.00 |
09-08-2019, 08:16 PM | #6 |
Rep 5,463
Drives: F30
Thanks fellas... I can get a new set of these for $250 delivered. Going to see if I can find a set of 17 take offs for the same before I pull the trigger. No upgraded brakes on my 328i at this point. Looks definitely aren't a concern... just trying to get up to Tahoe safely. Last year got a bit hairy at times.
Whatever I end up with will literally be going on Friday after work and coming off before work on Monday. Pure safety measure since I don't have xDrive. Haven't been able to locate a proven set of low profile chains to use with my lowered suspension and am scared to scratch my wheel arches with any old set. If anyone has recommendations on this front, please share. |
09-09-2019, 04:28 AM | #7 | |
Rep 1,827
2013 F30 335i RWD ZF Melbourne Red
~Remus Sport Axleback~VRSF Chargepipe~VRSF Catless Downpipe~GPlus FMIC~HR Sport Springs~Active Autowerke OBD Flash Tune Stage 2~ |
09-10-2019, 12:30 PM | #8 | ||
Rep 5,463
Drives: F30
