05-30-2020, 03:57 PM | #155 | ||
Rep 5,392
Do you have pretty solid maximum flow numbers for the Turbos themselves that fit in that stock housing? PT told me that EWG & PT Stage1 are pretty close to each other. PWG EWG PT Stage1 PT Stage2 Not sure what other turbos may use the stock housing? |
05-30-2020, 06:16 PM | #156 |
Rep 1,230
have a MST Inlet V2 without the adapter if anyone needs
N55 GENERAL
David Shoup Tuned Fully Built By Miami Engines/Project Motorworks Precision 6266 On Steroids |
05-30-2020, 10:29 PM | #157 |
Rep 928
I'm gonna be installing the Vader piece onto my factory inlet pipe should look like factory for emissions test too.
2015 335i 6sp manual with MPK and sport pack
GPlus intercooler and CP. Stage 1. CG precision dp. Staggered 19?s. 275/35/19, 245/40/19 ps4s. |
05-31-2020, 01:26 AM | #159 |
1296
Rep 3,533
i hate that i started this post
05-31-2020, 09:45 AM | #161 | |
Rep 4,146
I’ll try to get some logs here soon for the sake of comparison. |
05-31-2020, 11:20 AM | #162 | |
Rep 7,606
We could calculate the difference in potential flow based on the ID of the various inlets at the point where they meet to the turbo, but I dont think that tells the whole story. For example see picture below where the actual turbo has a big "lip" where the ID of the airflow decreases significantly right at the compressor wheel entrace, regardless of which inlet you choose. View post on imgur.com |
05-31-2020, 11:23 AM | #163 | ||
Rep 7,606
MST is available from Kies and from XPH i believe. Might be other vendors but MST themselves do not sell directly to USA. Quote:
Very interested to see a log with Dinan intake. 2/2 people i have seen with logs with dinan intake BOTH have the erratic MAF readings and significantly lower MAF values than with stock intake, both suggesting the dinan shape/size/filter combo affect MAF readings. Would be very interesting to see if yours is the same. (This included using stock inlet and aftermarket - no impact). For Ozy, the car ran much better removing dinan and going back to stock intake with MPPK bottom. |
05-31-2020, 11:42 AM | #164 | |
Rep 4,146
05-31-2020, 08:14 PM | #165 | |||
Rep 870
05-31-2020, 08:28 PM | #166 |
F36 GC
143
Rep 259
05-31-2020, 08:34 PM | #167 |
Rep 870
06-03-2020, 12:41 PM | #169 | |
Rep 4,146
06-03-2020, 01:13 PM | #170 | |
Rep 7,606
The MAF readings with dinan are here - https://www.bootmod3.net/log?id=5ed1...90c65530e92597 These actually arent TOO erratic, but you will see they peak at 37 or so whereas stock intake peaked at 45 (all else being equal), despite the dinan showing more power and almost certainly flowing more air up top. So the MAF is just not metering all the air with the dinan (due to factors i mentioned above). In addition to the erratic/low readings, this seems to make the car not idle or drive as well under normal driving conditions. |
06-03-2020, 01:41 PM | #171 | |
Rep 4,146
06-15-2020, 11:56 PM | #172 |
Rep 7,606
Just bumping this thread incase anyone searches. The results of all the testing are pretty much summed up in the recent posts in the MST thread.
https://f30.bimmerpost.com/forums/sh...2#post26317052 |
07-03-2020, 01:04 PM | #173 |
Rep 7,606
Inlet shows quantitative and tangible improvements on stock turbo
A week or so ago I installed the MST inlet and then did the MPPK airbox mod (one at a time, pics below). I think the benefits of the inlet were already summed up previously, but to echo and confirm for anyone on the fence, going from stock inlet to MST v2 was a clear and tangible increase in throttle response in all driving modes. You could consider it a reduction in “turbo lag” if you want to call it that. Turbo definitely spools faster and the time from pedal input to boost is reduced. Helps in both acceleration from a dig and just leaning into throttle in higher gears. There was also a little more air ‘suction’ noise if that makes sense, even with 100% stock intake at this point.
I subsequently did the MPPK airbox mod (the proper way not just drilling holes) and that didn’t make as much of a seat-of-the-pants difference as the MST inlet, but it does feel/seem like the engine is breathing better, a little more ‘whoosh’ from the DV. In addition to looking at the logs themselves on datazap, I did a little digging and data postprocessing for 8 logs: 3 with stock inlet, stock intake and airbox (AFE pro dry s drop in): https://datazap.me/u/thejeremyman9/t...og=0&data=4-21 3 with MST inlet, stock intake and airbox (AFE pro dry s drop in): https://datazap.me/u/thejeremyman9/3...og=0&data=4-21 2 with MST inlet, stock intake and MPPK custom airbox mod (AFE pro dry s drop in): https://datazap.me/u/thejeremyman9/2...og=0&data=4-21 I was basically looking for some evidence in the datalogs that what I was doing made a difference (essentially to support what I was feeling in the car). I know most people reported changes in WGDC (lower) and MAF (higher) after inlet install on stock turbo, but its almost impossible to see looking at the actual datalogs uploaded. So I decided to go back to basics and how I used to look at logs for my 3000gt and put them in excel. The key thing this allows is for you to plot the same parameter from different logs on the same graph with the same scale. I think there is clear evidence that the inlet and the MPPK both decrease WGDC for the same boost level. I did not see an increase in MAF, which I assume is because I am running MHD and I am literally right at load target in the upper RPM where MAF peaks. Other people have reported increased MAF on BM3, which makes sense given that it is a boost-based tune with a boost target high enough that you don’t reach it in the mid-upper RPM range, so you still have that room to gain with the inlet if that makes sense. If you have a custom tune, I imagine you can take advantage of the inlet even more. I haven’t yet looked at other parameters, such as boost vs time, but I did also notice in my 1-4th gear logs from a dig that I can now completely reach boost target in 2nd gear when before I wouldn’t be able to fully reach it in the short time I am in the gear. Bottom line, the inlet makes a difference on stock turbo. It’s not a earth shattering increase in performance, but it’s definitely tangible in the car, and I personally would do it over an intake (I plan to keep stock intake with MPPK mod I have done) without hesitation. Images below are from the MST install and the MPPK airbox mod, I did it the proper way to mimic MPPK instead of just drilling holes. View post on imgur.com Attached is the graph of WGDC. |
07-03-2020, 01:43 PM | #174 |
Rep 5,457
Drives: F30
@thejeremyman9
Is there a DIY that you followed for the MPPK air box mod? Ive been meaning to do this for a while but would like something to follow along with rather than just winging it. |
07-03-2020, 03:01 PM | #175 | |
Rep 7,606
Oh and the other thing is the snow "bucket" mod. I bascially cut it so that all of the "bucket" part of it is removed, but the actual flap on the spring is retained to cover the hole and function as normal. You can see in the pictures how I did that and well. It's actually blocking right where the air would flow if you dont cut it like I did, especially when the only way for the air to come in is from the front (pre mppk mod). All the threads on it show people just drilling holes which is ghetto IMO, and could maybe introduce some turbulence |
sspade2464.50 |
07-03-2020, 08:35 PM | #176 |
Rep 1,115
I have the same cut out done to mine, but I also added a scoop behind the grille that directs more air through the factory duct. My M235i never came with that hinged box in the bottom of the intake.
Good work on the comparison, I could see the difference on my logs, I think it's a good mod to squeeze out whatever is left in the factory turbo or lower WGDC. |
