BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > Navigation, iDrive, Audio, Video, Bluetooth, Phone, Cameras, Electronics > Andream MMI Box - Wireless CarPlay & Android Auto
proTUNING Freaks
      12-07-2019, 08:12 AM   #1
Firefly1337
Firefly1337's Avatar
Drives: F20 M135i LCI
This thread is intended to consolidate all available information on the chinese 'Andream' MMI Box.
Table of contents
  • FAQ & General information - down below
  • Pictures - 2nd post
  • Software updates - 3rd post
  • Research (Manufacturer, PCB, ...) - 4th post
FAQ
  • What is it?
    It is a small Multi Media Interface (MMI) box that will retrofit the following features to your BMW:
    • Apple CarPlay (wired and wireless)
    • Android Auto (wired and wireless)
    • Apple AirPlay
    • Screen Mirroring (wired) with Autolink
    • Displaying 3rd party aftermarket camera video signals
    • Basic USB playback from e.g. a thumb drive
    The box uses the OEM mic and supports Siri and Google Assistant either via voice keyword ('Hey Siri' / 'Okay Google') or by long-pressing the steering wheel voice button.
  • How does it work?
    The MMI box essentially acts as an intermediary between your original headunit and display. While the box is inactive, the original video signal is passed through unchanged and your car works as before.
    After activating the MMI box, the box's video signal is shown on the display instead.
    You can easily switch back and forth between the box and your original headunit. Using the MMI box is optional and should be seen as an add-on and not as a replacement.
  • Is my car supported?
    All cars roughly from 2013-2016 with 'NBT', 'NBT EVO' (ID4), 'ENTRY' and 'ENTRYNAV' headunits are supported.
    Important: 'NBT EVO' (ID5/ID6) is not supported.
    Update: There's also a version for CIC now. Make sure to buy the correct one depending on your head unit.
    The official list from Andream is as follows: (...for NBT)
    Code:
    1 Series F20/F21 (2011-2017) requires a screen
    2 Series F23 Convertible (2013-2016) Original NBT System
    2 Series F22/F45 MPV (2013-2016) original NBT system
    3 Series F30/F31/F34 (2013-2016)
    4 Series F32/F33/F36 (2013-2016) original NBT system
    5 Series F10/F11 (2013-2016) original NBT system
    5 Series F07 GT (2013-2017) original NBT system
    7 Series F01 F02 (2013-2015) original NBT system
    X1 F48 (2016-2017) original NBT system
    X3 F25 (2014-2016)
    X4 F26 (2014-2016) original NBT system
    X5/X6 F15 (2014-2016) original NBT system
    MINI  F56   2013 -2016   6.5"
    MINI  F56   2013 -2016   8.8"
  • What does it cost?
    Prices vary depending from where and when you buy, but usually around 200$ - 240$.
  • Are there alternatives?
    There is an identical unit from Korean company IndiWork here for 315$. Their model number is 'SCB-NBT' but the software is identical, so the units truly are the same.
    The same unit with slightly different software (some graphics are changed) is sold by Carlinkit.
    There is a similar but different unit from JoyeAuto here that even supports CIC for ~415$.
    It has wireless CarPlay and wired Android Auto support but it is unknown if AA also works wireless.
    Note that this unit cannot use the car's microphone and requires an external mic (might result in poor audio, depends on the mic).
    Link to thread: https://f30.bimmerpost.com/forums/sh....php?t=1622013
    BimmerTech is selling their MMI Prime box for 649$.
    While the price tag is high-end, the unit is actually identical to the ones sold by Andream, IndiWork and Carlinkit. The software of all of them can be used interchangeably on all units with no difference in features, only a few main menu graphics/icons are changed (Update: No longer the case, refer to the Downloads post below).
    Link to thread: https://f30.bimmerpost.com/forums/sh....php?t=1615794
    Unique-AD UK is selling a unit that claims to support both wireless CarPlay and Android Auto for ~610$. Only works for NBT or similar HUs and not with CIC.
    It has a 3.5mm microphone input so it's highly likely that it requires an external mic and does not use the OEM mic.
    Link to thread: https://f30.bimmerpost.com/forums/sh....php?t=1597999
  • Does it use internal AUX for sound?
    Yes, the box (not the phone!) uses the AUX Front-in (this is not the armrest input) from the original headunit. There really is no other way to get sound in and that's why all units on the market use that exact method.
    The sound quality itself is definitely comparable to OEM. But bear in mind that this also depends on your car's setup (speakers) and that audio in general is perceived highly subjectively.
    Good to know: The box includes an 8-band equalizer to adjust the sound.
    Again: You do not need to plug in your phone to AUX. The box itself is connected via AUX internally over the quadlock cable. The sound from the phone is transferred either wireless or wired e.g. via CarPlay or Android Auto.
Installation
Check out the installation guide by x5m254: https://mega.nz/file/xERhkQjR#fRSRjX...8dPq7K04zUzLrA
Installation is the same for all aftermarket units like this (e.g. the 10.25" android 9 displays).
The basic idea:
  1. Disconnect the big 'Quadlock'-cable from the original headunit
  2. Connect the box's Y-harness to that cable. The new quadlock goes into the headunit, the small power cable into the MMI box itself
  3. Disconnect the LVDS cable from your original display and plug it in the box's 'LVDS in' connector
  4. Connect the 2nd LVDS cable to 'LVDS out' and plug that into the display instead
Important for step 2: If your original quadlock has a green 2-pin optical cable, you need to transfer that over to the new quadlock plug or you might run into the following issues:
  • No sound
  • iDrive clock stops working
  • No trip info / usage stats
Note: If your quadlock does not have this cable, don't worry. In that case you don't have to do anything.
Quadlock and 2-pin cable:
Video guides
From YT 'BMW DIY Guy' for BimmerTech's MMI v1: link
From YT 'Grind My Gears' for BimmerTech's MMI Prime: link
Official BimmerTech Prime installation video: link
Configuration
The main configuration is done on the box itself using 'dip switches':
Official instructions from Andream:
Explanation:
Code:
1 Display track overlay on 3rd party cameras (unconfirmed), ON=disabled
2 360° camera, ON=disabled
3/4/5 depends on your car, for 6.5" or 8.8"/10.25"
6 unknown
7 OFF = 3rd party camera, ON = OEM camera (does not seem to have any effect)
8 OFF = OEM mic, ON = 3rd party mic (always choose off, there is no 3.5mm in anyway)
Everything else is configured on a software level after installation.
Appreciate 14
      12-07-2019, 08:13 AM   #2
Firefly1337
Pictures
The unit itself (main menu, settings, etc), CarPlay and Android Auto.
MMI box
Apple CarPlay
Android Auto
Note: Widescreen only available with community made custom firmware, see here.
The official firmware looks like this:
Screen Mirroring
For Android phones with an app called Autolink.
Appreciate 13
      12-07-2019, 08:13 AM   #3
Firefly1337
Software Updates
For models / vendors:
  • Andream (EW-BMCP-NBT01A & EW-BMCP-NBT02B)
  • IndiWork.co.kr (SCB-NBT)
  • Carlinkit
  • RoadTop
  • Bimmertech's MMI Prime
Update instructions
ISPBOOOT.BIN contains the software and upgrade.bin the MCU firmware.
Note that after upgrading the MCU it will still show the old version number. After another reboot it will show the updated version.
  1. Format a USB flash drive with FAT32
  2. Unzip the archive, then copy the upgrade file 'ISPBOOOT.BIN' / 'GEMINI_PACK.BIN' (for Software) or 'upgrade.bin' (for MCU) into the root directory of the USB flash drive
  3. Insert the USB flash drive into the MMI's USB port
  4. Start the car and switch to the MMI
  5. Navigate to 'Setup' -> 'Software Update' -> 'System Update' or 'MCU Update' (newer versions will require a PIN, see below)
  6. Confirm the popup
  7. The upgrade takes ~1-2min. Do not power off the unit (i.e. don't turn off the car)
  8. The unit will automatically switch to iDrive. You can switch back to see the update progress
Force Flash Update
In case your unit does not boot up anymore or you have other issues updating there is a way to force flash an update.
  1. Put the ISPBOOOT.BIN file on a usb flash drive (FAT32) and plug it into the box
  2. The MMI box needs to be fully powered off (best to remove the power cable)
  3. Press and hold the 'Back' button on your iDrive controller. Do not let go!
  4. If you removed the power cable, plug it back in while still pressing the 'Back' button.
  5. Turn on the ignition of your car. Keep pressing the 'Back' button.
  6. The display should switch to a black screen and show the update screen shortly afterwards. You can let go of the 'Back' button now.
Official firmware
These are the official firmwares provided by the Chinese sellers. For custom versions made by me please scroll down to the end of this post.
Warning: Please read the info on cross compatibility below before downloading anything. Do not flash updates from other vendors that are marked as 'not cross compatible'!!
Warning 2: Do not flash versions for NBT on CIC or the other way around!
Warning 3: Do not flash directly to the latest version in case you still run on a very old firmware!
ISPBOOOT.BIN vs GEMINI_PACK.BIN
There are two revisions of the MMI boxes that use slightly different firmware. The earlier units use the ISPBOOOT.BIN file while the later units (henceforth called 'B version') use GEMINI_PACK.BIN. They are not compatible with each other.
Available software and download links:
Andream [NBT] [ISPBOOOT.BIN] (should work with IndiWork as well)
Model: EW-BMCP-NBT01A
Note: Andream is shipping units with '.lc.b' versions that can be upgraded to '.gpe.b' versions (there is no difference between versions). Do not confuse this with '.lt.b' versions, these are RoadTop and not compatible!!
Andream B-Version [NBT] [GEMINI_PACK.BIN]
Model: EW-BMCP-NBT02B
Andream [CIC] [ISPBOOOT.BIN]
Andream B-Version [CIC] [GEMINI_PACK.BIN]
RoadTop [NBT] [ISPBOOOT.BIN]
RoadTop B-Version [NBT] [GEMINI_PACK.BIN]
  • BR110 (PIN: 8032) (Not cross compatible)
  • BR112 (PIN: 8032) (Not cross compatible)
  • NEW BR115 (PIN: 8032) (Not cross compatible)
RoadTop [CIC] [ISPBOOOT.BIN]
Carlinkit [NBT] [ISPBOOOT.BIN]
  • MCU 20.1.4 (md5 hash is identical to Bimmertech's MCU '10.1.4.11')
  • MCU 20.06.02 (Compatible with Andream & RoadTop)
Bimmertech [NBT] [ISPBOOOT.BIN]
Cross compatibility of updates
Andream, Bimmertech, Carlinkit and IndiWork all offer the same product from the below mentioned company Sunplus.
So far all software updates can be flashed interchangeably, even the MCU. The only downside is that the main menu shows 'Invalid update' if a foreign update was flashed - but that's only visual and does not affect the functionality (bear in mind that this might change at any time!).
cossie1 made a very good overview of the different looks and features here.
Update: Since Carlinkit v9.2.2.yl.b / Andream v2.1.0.3.gpe.b / Bimmertech v2.0.2.4.mmi.b this is no longer possible! Furthermore, the software update menu now requires a vendor specific PIN code to prevent cross flashing.
Changelog (Official) for Andream
Unfortunately there aren't any other changelogs. Read this thread and check for user experience.
v2.0.2.7.gpe.b (20.1.7)
  1. Optimize the connection speed of wireless carplay
  2. NBT BMW adds switch headlight carplay will automatically change to dark and white mode
  3. NBT supports test code (fourth digit)
  4. NBT BMW acc off will disconnect the carplay connection
  5. Solve NBT large screen BMW upgrade or restart will appear 'No Signal'
  6. Added NBT BMW P gear to D gear into front view (set lead time)
v2.0.2.6.gpe.b (19.12.14)
  1. Optimize carplay to play music freeze
  2. Settings- Added open echo debugging function for audio
  3. Added channel selection in the settings, the default Chinese version is 149 channels, the default English is 36 channels, the channel does not change with the language (2.4GWiFi channel is 6 channels)
  4. Fixed the reversing interface with Chinese when setting English or other languages
  5. Added menu and back keys to long press the function switch button switch in the settings (need to cooperate with the latest mcu19.12.12)
Custom Firmware
Universal [NBT] [ISPBOOOT.BIN]
Note: This update will work on any A-Unit no matter the seller (does not work on B-version!)
Note2: A word regarding MCU updates: With this update you can only flash the MCU updates by Bimmertech. Flashing the default MCU from Andream/Carlinkit etc is only possible on their firmware. Currently there is no need to do anything (no new features etc), so you can leave everything as is. Also note that Bimmertech transforms the first digits of the MCU version from '20' to '10'.
  • v2.0.B0.mod (for BMW) (no PIN) (Cross compatible) (based on: v2.0.2.7t0.mmi.b)
  • v2.0.M0.mod (for MINI) (no PIN) (Cross compatible) (based on: v2.0.2.7t0.mmi.b)
Universal [CIC] [ISPBOOOT.BIN]
Note: You will not be able (yet) to flash any CIC MCU-Updates on this version. Make sure to flash them beforehand if you are not running the latest version and want to update.
  • v2.0.B1.mod (for BMW) (no PIN) (Cross compatible) (based on: v2.0.2.7t0.mmi.b)
  • v1.0.A0.mod (PIN: 2863) (Not cross compatible) (based on: v2.1.0.6.gpe.b)
  • v1.0.C0.mod (PIN: 4091) (Not cross compatible) (based on: v9.2.5.yl.b)
Changelog (Custom)
v2.0.B0.mod and v2.0.M0.mod
Announcement post and following discussion: https://f30.bimmerpost.com/forums/sh...2#post26519212
  • Android Auto Widescreen Fix
  • Android Auto DPI Fix
  • Autolink Mirroring Screen Size Fix
  • Renamed MMI to BMW-MMI/MINI-MMI for Carplay and AA
  • Replaced MMI icon with BMW/MINI icon
  • Replaced car image on integrated PDC/camera screen
  • Changed icons to Blue when highlighted
  • Removed update / key checks
  • BMW/MINI Boot Logo
  • Custom Flash/update screen
v1.0.A0.mod and v1.0.C0.mod
Announcement post and following discussion: https://f30.bimmerpost.com/forums/sh...4#post26427924
  • Custom boot logo (BMW icon)
  • Replaced Z4 car image on integrated PDC/camera screen
  • Black flash/update screen
Appreciate 27
      12-07-2019, 08:14 AM   #4
Firefly1337
Research
Product name: Sunplus SPHE8388
The SoC is very likely the Sunplus SP7201 (technical documentation).
Sunplus released their framework on Github: https://github.com/sunplus-plus1/SP7021_4.19
Here's the script that is used to generate the ISPBOOOT.BIN file: https://github.com/sunplus-plus1/isp...ster/tools/isp
The extraction function in there doesn't work for our unit unfortunately because the signature is different:
Code:
const u08 file_header_signature[] = "Pentagram_ISP_image";
Our unit has the internal codename 'Gemini'.
Warning: Do NOT use that script without further modification. It will not work and/or brick your unit!
The MCU's CPU is 'STM32F105RB' by ST (technical documentation).
Internals (PCB)
Front
Back
Appreciate 10
      12-07-2019, 08:22 AM   #5
theblues
Drives: MY14 328xi - Sportline
Well done post.
To add, JoyeAuto uses an external mic
There is a similar unit from JoyeAuto here that also supports CIC for ~415$.
While the price tag is high-end, it looks identical to the other units but does not support wireless Android Auto (only wired). CarPlay works wireless.
      12-07-2019, 08:28 AM   #6
Firefly1337
Thanks, I added the info.
I figured it might be time to open a separate thread, but it's a work in progress
x-m4n137.50
ichooo3.50
      12-07-2019, 09:26 AM   #7
fantanas
Drives: F33 435d
Very good write up!!! I ordered mine last night and this will be very useful!
      12-07-2019, 10:11 AM   #8
cossie1
Drives: 2015 F82 M4
Good thinking, great idea.
Let me know when yours is shipped please (mine is still processing).
      12-07-2019, 10:13 AM   #9
cossie1
Drives: 2015 F82 M4
Explanation:
Code:
2 360° camera
6 unknown
By track overlay (no.1) do you mean the grid lines in the reverse camera on / off ?
      12-07-2019, 10:36 AM   #10
fantanas
Drives: F33 435d
Will do. I ordered from CZ. Hopefully it won't take long. When did you order yours?
      12-07-2019, 10:46 AM   #11
cossie1
Drives: 2015 F82 M4
Last Sunday also from CZ
      12-07-2019, 11:53 AM   #12
fantanas
Drives: F33 435d
And it is still not shipped? You are getting me worried
      12-07-2019, 12:14 PM   #13
cossie1
Drives: 2015 F82 M4
No the seller replied to me yesterday to say that the items had arrived in CZ but have been stopped by customs so they need a few more days before they can ship it.
But when I ordered they were showing 97 in stock in CZ, I guess the stock levels are not live and take into account any in transit to there warehouse.
      12-07-2019, 01:38 PM   #14
touchmynappa
Drives: BMW 125i
Would be great if any of you that installed the Andream CarPlay box on a car with HU_NBT_EVO (ID4) can test if you can code the head unit with bimmercode or e-sys or any other coding software, while the CarPlay box is installed. HU_NBT_EVO (ID4) should be in model year 2016 of any of these: F20/F21/F22/F30/F31/F34/F80/F32/F33/F36/F06/F12/F13/G11/G12/G13.
      12-07-2019, 03:18 PM   #15
terrymcg
Drives: 2015 M4
I will try tomorrow.
      12-07-2019, 03:38 PM   #16
mclark2112
mclark2112's Avatar
20
Drives: 2015 BMW 335xi
I ordered mine last Monday. It shipped, but the US Post Office hasn't started tracking it. Last I saw was it was handed off to the airline on Thursday.
Can't wait to get this in.
I have an iPhone, so I will try to get some good shots for the thread as soon as it is in.
2011 335i, totaled by a deer.
2015 335xi now.
      12-07-2019, 03:49 PM   #17
beardsandbeers
Drives: 2015 428i Gran Coupe
Great timing, I also ordered one of these ~2 weeks ago, looking forward to evaluating with iPhone.
      12-07-2019, 04:41 PM   #18
touchmynappa
Drives: BMW 125i
Will be interesting to hear about the results! From what I could see from e-sys was that it complained about HU_ENTRYNAV, which perhaps indicates that the Andream intercepts traffic and reports itself as HU_ENTRYNAV instead of HU_NBT or whatever the correct I'd would be for a 2016 model year head unit.
It seems like they prepared for 2016 HU_NBT_EVO (ID4) 8.8" with dip switch 1-2-4 set to ON in the dip switch picture in op:s original post, but never implemented it.
      12-07-2019, 07:49 PM   #19
CarFan
Drives: 2013 X5 3.5 Premium
FAQ
  • What is it?
    • Apple AirPlay
    • Screen Mirroring (wired) with 'Autolink' (MirrorLink?)
  • How does it work?
    Code:
    X3 F25 (2014-2016)
    Prices vary depending from where and when you buy, but usually around 240$.
Installation
Configuration
Attachment 2194414
Attachment 2194415
Explanation:
Code:
1 Display track overlay/grid lines on 3rd party cameras (unconfirmed)
2 360° camera
6 unknown
Which Andream model will work with a 2013 X5 e70?
      12-07-2019, 08:29 PM   #20
ooshnoo
ooshnoo's Avatar
Drives: 2014 428i
2018 GMC Acadia  [0.00]
2014 BMW 428i  [5.00]
What is it's audio interface? Does it use AUX like all the other units?
___________________
2014 F32 428i 8AT M-Sport
      12-08-2019, 12:01 AM   #21
mlev
mlev's Avatar
Drives: 2014 335i M-Sport
Cross posting since I totally missed this thread, here's been my experience so far with this unit.
Got my box installed yesterday and today. I only use CarPlay and have an iPhone X so no experience with AA. Everything within CarPlay seems to work pretty well. No complaints after about an hour of usage.
So I've got a '14 NBT HU /w nav, HK & Sirius.
It wasn't possible to fit everything behind or under my head unit. After trying, I ended up having to remove my glove box to fit the unit between the right pocket of the head unit. Quite a bit of T20 undrilling & you need to drop the bottom passenger airbag. Followed Kies video for that. Even the wiring harness barely fit back there, definitely was a tight fit for me.
Ran into an issue where I had no radio signal or sound. I realized that I had to transfer over the two green fiber optic cables from my original harness. If you run into this, make sure they are re-inserted back into the new harness in the right direction (messed this up the first time).
Overall, the install ended up being more of a pain than I anticipated and took me quite a while to get everything squared away and reassembled. Mostly due to the glove box part I wasn't expecting.
Sound quality seems good on my HK system with wireless using Spotify CarPlay on my phone. You can notice some slightly degraded quality with very high volume, but there's an equalizer and volume settings you can play around with. I was worried about sound quality of music, but am pleasantly surprised that it's still good even though the headunit system is set to "aux". I will continue to listen to music in CarPlay Spotify rather than OEM Bluetooth.
Regarding the mic, I called my gf and she told me I sounded perfectly fine on my end (unit uses OEM mic).
Saying "Hey Siri" allows me to do whatever through the unit without touching anything. I think there's a button shortcut for this too? But not sure what that is.
Used Waze and had no issues - worked exactly as expected in full screen.
I have heads up display. So when sound is playing via CarPlay, you can control the CarPlay menu using the steering wheel controls. However the heads up display populates a message saying "action not available in AUX mode" or something, while you scroll from your steering wheel. That's really the only "non OEM" drawback.
Also updated my box before I set it up - successfully flashed from v2.0.2.4 (which it came with) to the latest v2.0.2.5
Definitely worth the upgrade, very happy so far.
Glad I waited for a solution that checked all the boxes for me: wireless, 8.8" full screen support, and uses OEM mic. Bonus that Andream seems to be actively working on firmware updates and includes Android Auto just as a luxury.
x-m4n137.50
      12-08-2019, 02:12 AM   #22
chhappy7
chhappy7's Avatar
124
Drives: 2015 328i RWD
2015 328i  [0.00]
What was your dip switch set up?
2015 328i - M3 style front bumper/fender/side skirt, M Sport rear bumper/diffuser, M Performance brakes, BBS SR, ceramic iDrive, LCI radio trim, 6WB, carbon fiber lip, X5M razor key
andream, android, android auto, apple, carplay, mmi, retrofit
