12-16-2019, 02:31 PM | #1 |
Rep 7,606
Max tire size for stock 19'' wheels (RWD, stock M-sport suspension)?
I have been digging through several pages of threads in this section of the forum but did not see this specific questions answered. If it has been, sorry for the new thread and please point me to the correct one.
Basically, i want to know the max tire size i can run on stock 19'' rims with stock M-sport suspension I have a 2015 335i RWD with stock M-sport suspension and stock 19''. Stock specs are: 19x8" ET36 225/40/R19 front = 26.1 '' 19x8.5" ET47 255/35/R19 rear = 26'' I saw a couple threads where people stated they have ran up to a 255/35r19 on all four corners on stock 19s, implying this would work on the front. Can anyone confirm that? I think that's even a bit wider than i would go up front. For the rear, I haven't found much info on how wide/big people are going in the rear with stock 19s. Any info on this? Considering: 265/35 = 26.3'' 275/30 = 25.6'' 275/35 = 26.6'' Thoughts and personal experiences with larger-than-stock tires on stock 19'' wheels? |
12-16-2019, 03:44 PM | #2 |
Rep 4,327
the max recommended widths on 19x8 and 8.5 are 245 and 255 respectively. going wider than spec will reduce turn-in sharpness and be sloppier in transition. if you just want more grip for straight line acceleration i suppose it'd work but i'd rather get the best properly sized tires you can afford.
the comparison pics of the car below(not mine) has kept the rear at 255/35/19 and changed the front from 225/40/19 to 245/35/19. 245/35/19 up front will improve handling by reducing understeer with just a slight loss in turn-in sharpness. it is the only tire size change on the oem wheels i'd recommend. Last edited by alohasurftoad; 12-16-2019 at 03:51 PM.. |
sewhelan934.50 |
12-16-2019, 06:32 PM | #3 | |
Rep 7,606
One other question: On Costco (havent checked other websites yet), they are showing two different load index tires as recommended for rear. Both of these are different than front. This is for PS4S. One also has a "Z" in the tire size. I looked this up and my understanding is that its basically an optional label for the speed rating. Both tires are Y rated, but one lists the Z in the tire size. Prices are slightly different. For example: Rear: 255/35R19/XL - Load index 96 255/35ZR19 - Load index 92 Front: 225/40ZR19/XL - Load index 93 225/40R19/XL - Load index 93 Front's with and without the Z label are the same load index, rear's are not. Everything else is exactly the same on these tires, including Y speed rating, treadwear, etc. All 4 of these are different item numbers and prices vary between them (albeit slightly). I'm sure the load index is not a big concern for a 3-series but I havent seen costco list these different nearly identical options for other cars/tires i have looked at. Any experience with this? EDIT: I am seeing the same thing on Big O Tires, but even more options, with and without the Z, etc. And some list mileage warranty as 20k instead of 30k? https://www.bigotires.com/tires/by-v...e%3A2553519%29 Last edited by thejeremyman9; 12-17-2019 at 01:22 PM.. |
ErkanTR16598.00 |
12-17-2019, 10:42 AM | #4 |
Rep 4,327
compared to the 225, you'll be able to have a higher speed through "canyon carves" with the extra grip that 245 gives you up front.
regarding the different load index, I checked TireRack and believe the higher load indexed tires may be Star BMW spec for the M-cars. I am not sure of this, though. Last edited by alohasurftoad; 12-17-2019 at 11:56 AM.. |
12-17-2019, 01:28 PM | #5 | |
Rep 7,606
I did some some research and i figured out that the tire sizes with a Z have a speed rating of (Y) instead of Y. Basically: "But what about that "Z" rating mentioned earlier? "Z" means that the tire has been tested over 149 mph, but doesn't indicate how far over. The "Y" rating basically puts the cap at 186 mph. Except here, the designation is in parentheses, indicating that the tire has been tested above 186 mph. However, again it doesn't indicate how far over 186 mph that testing was done." So the (Y) means the tire has been tested over 186mph, compared with a cap of 186mph for Y. Regarding the XL, generally this is a higher load index (tire can handle more weight when inflated to a higher pressure) and stiffer sidewall tire. However, for the fronts, they are both load index 93, so i am not sure if the XL is actually making a difference; perhaps the sidewall on the XL is stiffer. |
12-17-2019, 01:55 PM | #6 |
Rep 4,327
i have a 245/255 18" setup on my car. although i don't have any canyon to carve (here on oahu) i can tell you it's way better. where 225's start scrubbing in a fast corner the 245 stays on the line longer and the trajectory of the car seems more balanced. while 245 is less understeer than a 225, it'll still be understeer at the limit.
i hear ya, tho. stay with what you're comfy with. more understeer is definitely safer albeit a bit slower. |
12-17-2019, 03:27 PM | #7 |
Rep 882
I concur with Aloha. I switched to the 35-series 245/255 combo (PS4S) on my staggered 19” 442Ms. I also have X-Drive, so it’s good for the 1% diff too. Much better feel/grip (less push/understeer) up front. I too thought the OEM 225 up front was okay, but the 245 is so much better, you can easily feel it cornering.
You almost always want the higher load rating tire for a 3/4-series. BMW Star rating is also a plus IMO (the 255/35-19 can have it, it’s not available on the 245/35-19). I suspect BMW put 225 up front to aid gas mileage...
alohasurftoad3078.00 |
12-17-2019, 03:57 PM | #8 | |
Rep 7,606
I have the OEM 19'' 442 also, in orbit gray. Also, based on what i see on Costco's website, the 245/35ZR19/XL are actually cheaper than the 225/40 by about 20$ each... they are also the XL, load index 93, and speed rating (Y). Seems like the best decision for me. I will probably continue to over-research it as i do everything, lol. Plus, i missed Costco's Michelin promotion for December, so i may be waiting until the next time they do that (hopefully Jan since they usually alternate Michelin and Bridgestone promotions) unless i find a good deal elsewhere. |
01-02-2020, 05:55 PM | #9 |
Rep 7,606
Tires ordered from Costco
FYI incase anyone else searches this thread:
Below are attachments for the tires i went with from Costco including the prices. This was with a $150 off promotion on a set. Of note is that there are 3 options for the exact same size tire on the rear and 2 options for the front. For the rear, the two alternatives are a Star BMW certified option which is "R" instead of "ZR" and Y instead of (Y) [Y being a lower speed rating] and a ZR (Y) that is not XL and only a 92 load index. The option i went with was combination of highest speed rating and highest load index, for the cheapest price. For the front, the option i did not go with was the exact same spec as the one i ordered but it was MO1 Mercedes certified option, and it was more expensive for the same exact tire. |
Omgturbo1.00 |
01-10-2020, 09:08 AM | #10 |
Rep 878
I placed an order for the same rear tyres from Costco, also went with the non BMW/Mercedes option as not only was it cheaper but it had a better fuel efficiency rating, C versus E.
01-10-2020, 12:03 PM | #11 | |
Rep 7,606
Did you already have PS4S on front and just needed new rears? |
01-10-2020, 03:03 PM | #12 |
Rep 878
Yes already have 4S on the front. Mine aren’t due in until the 22nd, decided to get them swapped out as the Conti 5 tyres have let the back end slide out a few times when it’s slightly damp. Brown trouser moments for sure.
02-02-2020, 04:39 PM | #13 |
Rep 7,606
Bumping this because i just got my PS4S installed. Some pictures are below with before/after. I went from stock sized RFT to the sizes noted in my post above. As expected, the PS4S are bettery in every way. Cornering, straight line grip, noise, comfort, etc, all improved.
Before pictures album: View post on imgur.com After pictures album: View post on imgur.com |
02-02-2020, 10:28 PM | #14 |
Rep 68
Does anybody know why the BMW dealerships (in the DFW area) won't sell or install the Michellin Pilot Sport 4S tires. They are still pushing the Pilot Super Sports. No matter how many times I tell them that the PS4S has replaced and is a better tire than the older PSS they will not budge.
02-03-2020, 12:20 AM | #15 | |
Rep 7,606
mholder23.50 |
08-18-2020, 04:19 PM | #16 | |
Rep 7
2015 335i M-Sport RWD 6MT, MPE, ER CP, BM3-S1, Dinan Springs
08-18-2020, 06:08 PM | #17 | |
Rep 7,606
MPS4S are great in the wet. Miles ahead of the bridgestone summer s001 RFTs that come stock (in both wet and dry). All around the MPS4S are my #1 summer tire choice, as were the MPSS before them; just dont get them if you need to drive in freezing temperatures. But dry/wet roads they are fantastic. I highly recommend both the change in tire size front to 245/35/19 and the PS4S as the summer tire of choice. |
09-19-2020, 02:24 PM | #19 |
Rep 128
Thank you all for this thread. Was very informative, and insightful. I too am due replacement. Actually past due (my SA was very concerned while showing me all the balding on my fronts yesterday as I was having my oil changed)
I too would like to go up on size on the fronts with PS4S'es. But I was leaning more towards on 235s (vs 245). Didn't want to have too big a change from stock and wanted to be a bit more conservative. I'm having a hard time deciding between 235/35 vs 235/40. Any recommendations as to which one would be a better pick? And why? Much appreciated.
Past:
'15 F80 DCT MW/Blk '11 E92 335is DCT AW/Brwn '09 E92 335i 8AT Blk/Blk M Pckg |
09-20-2020, 02:14 AM | #20 | |
Rep 4,327
235/40/19(26.4"), larger sidewall, better ride and impact protection with slightly less sharp turn-in. front wheel gap will be reduced 0.2" and front height will increase 0.2". the reverse diameter stagger will cause slight reverse rake though likely unnoticeable unless pointed out. 245/35/19 is the the best size for the oem 19x8 front wheel as shown in the posts above. |
John.K38.50 |
09-20-2020, 10:39 AM | #21 | |
Rep 128
alohasurftoad thank you for this. I had picked up on the height issue for 235/35 would cause yes. But not on the reverse diameter stagger that would come with 235/40. From a diameter & height perspective (which i think is really important to keep as close to stock as possible, as the suspension & front axle geometry would have been designed for that), yes 245/35 seems to be the optimal configuration.
Past:
09-21-2020, 03:41 PM | #22 | |
Rep 7,606
John.K38.50 |
