12-19-2019, 01:20 PM | #1 |
Rep 1,282
Do these look good?
I have no idea to read logs. But I assume their is a boost leak because the boost pre-throttle and target are way off.
http://www.bootmod3.net/log?id=5dfa2250c090c613428e17c2 http://www.bootmod3.net/log?id=5dfa21f0c090c613428e17be http://www.bootmod3.net/log?id=5dfa21aec090c613428e17bd
SOLD! X5 35i sdrive- JB4 SOLD! 435i- Cary Jordan E30 Tune~ Dinan Turbo~ BM3 trans tune~ XDI-35~ 3.5 T-map sensor~ VRSF HD FMIC~ VRSF Chargepipe~ VRSF Catless Downpipe~ CTS Intake~ FTP boost pipe~ FTP intake inlet~ FTP oil catch can~ Turbosmart dual bov~ |
12-19-2019, 02:00 PM | #2 | |
Rep 1,105
Yeah boost seems way off, especially for a custom E30 mix. Who is doing the custom tune?
khj24221.00 |
12-19-2019, 02:00 PM | #3 |
Rep 1,282
Cary Jordan. what should be the difference between pre-throttle and target?
12-19-2019, 02:10 PM | #4 | |
Rep 1,105
What has Cary suggested regarding the logs? How many revisions have you gone through so far? I just had my XDI-35 installed and will be reaching out to Cary for a custom tune but im loving my PS2 and new HPFP. Even just using the MHD PS2 OTS map feels so much better!!!!! Need to make a trip to "mexico" so i can do some logging ASAP
oma3710194.50 |
12-19-2019, 02:13 PM | #5 | |
Rep 1,282
12-19-2019, 04:30 PM | #6 |
1288
Rep 3,502
Leak for sure. No big deal but obviously the logs are useless until you get that fixed. Love jordans targets.. its no wonder he makes good power.
oma3710194.50 |
12-19-2019, 06:48 PM | #7 |
Rep 1,282
Can't find leak
SOLD! X5 35i sdrive- JB4 SOLD! 435i- Cary Jordan E30 Tune~ Dinan Turbo~ BM3 trans tune~ XDI-35~ 3.5 T-map sensor~ VRSF HD FMIC~ VRSF Chargepipe~ VRSF Catless Downpipe~ CTS Intake~ FTP boost pipe~ FTP intake inlet~ FTP oil catch can~ Turbosmart dual bov~ Last edited by oma3710; 12-20-2019 at 07:46 AM.. |
12-19-2019, 07:43 PM | #8 |
Rep 1,282
None of the pipes were pulled apart. I did find one of the clamps loose on the charge pipe. Not sure if that could have caused it. Everything else was tight.
12-19-2019, 08:27 PM | #9 | |
Rep 7,555
If you cant find the leak, check out the boost leak thread where i posted some pictures/info on how to build a tester. In addition to checking the coupler clamps, check the bungs (teflon taped and tight), and most importantly the IC connections. Did you install the TIC as well or just CP? If there is any play whatsoever on the TIC-IC or IC-CP connection, there is going to be a leak. Check out the Oring thread for info on how you can address that if you have a loose fitting CP. CP-TB should also be solid. Not sure if you have 8AT, but also check the Oring on that vacuum line to the CP or the plug for that if you are 6MT. |
oma3710194.50 |
12-20-2019, 04:42 AM | #10 |
Rep 282
cant you make datazap files ? so everyone can read them
its not because something isnt on target you have a leak right away . as long your wastegate isnt fully closed
M140i DP , OPF delete , MHD stg2 93oct , xhp stg3
12-20-2019, 07:47 AM | #11 |
Rep 1,282
I am thinking it could be the intake manifold. I just took it off to install the xdi35 hpfp. Below are the first logs.
http://www.bootmod3.net/log?id=5df95485c090c65f03d024dc http://www.bootmod3.net/log?id=5df954e9c090c65f03d024df http://www.bootmod3.net/log?id=5df95585c090c6129053e989
12-20-2019, 08:16 AM | #12 | |
Rep 1,105
12-20-2019, 08:17 AM | #13 | ||
Rep 1,282
12-20-2019, 08:23 AM | #14 | |
1288
Rep 3,502
12-20-2019, 08:25 AM | #15 | ||
Rep 1,282
12-20-2019, 09:21 AM | #16 |
1288
Rep 3,502
Yep, check your orings and re-seat the couplers etc.
01-03-2020, 02:09 PM | #17 |
Rep 1,282
I have checked all the piping and didnt find any leaks. I re-adjusted the boot pipe, intercooler and charge pipe to make sure I am getting a good seal. I am still waiting to hear back from Cary. I guess due to the holidays hes been out of the office. Worst case scenario I am going to have to pay a local shop $90 to do a boost leak test.
01-04-2020, 01:06 AM | #18 |
Rep 1,282
http://www.bootmod3.net/log?id=5e101149c090c64d6f750ae0
http://www.bootmod3.net/log?id=5e101176c090c64d6f750ae1
01-04-2020, 12:41 PM | #19 | |
Rep 7,555
Are you running stock Orings on the VRSF CP? If there is any play at all on the IC-CP connection you may need to go to a bigger Oring. |
01-04-2020, 12:43 PM | #20 | ||
Rep 1,282
01-04-2020, 01:03 PM | #21 | |||
Rep 5,377
Both the Charge Pipe and the TIC Pipe carry boosted air and both connect to the intercooler. Also the Inlet Pipe carries unboosted air from the air filter pipe to the turbo inlet. There are identical o-rings that ride inside the grooves of the Charge Pipe and of the TIC Pipe where they each connect to the intercooler. Look closely and you will see that these are actually flat AND directional. If you have them installed in the wrong direction, then that will cause a leak. Please see attached diagram. I always recommend replacing these o-rings whenever those connections are touched, which isn't often, just because if they ever fail it's an expensive hassle to troubleshoot a leak. There are different o-rings at the other ends of these pipes that are worth replacing for the same reason. Hope this helps! |
01-04-2020, 01:06 PM | #22 |
Rep 1,282
I didn't have a boost leak until I replaced the tic (boost) pipe.
