| 03-02-2020, 12:52 PM | #1 |
Rep 110
Wiring underbody lights to come on when unlocked and off when locked
Hey guys, I know this isn't the best idea, but I've decided to install some underbody lights under my F30 on all 4 sides. I'm looking at either LEDGlow or OPT7 Aura lights (I installed OPT7 for my interior footwell lights).
Here is the dilemma: I want to wire the lights so that when you unlock the car they come on, and when you lock the car they turn off. I looked into some options and some people have wired them to the dome lights or foot well lights, other people have wired them to the parking lights. The thing with these options are I'm not sure if they are constant or switched power, so I wouldn't want the lights running when the car is off. I wired my interior lights to the cigarette lighter which turns off after 5 minutes of shutting the car off, but they aren't ideal for the underbody lights as it will catch too much attention. The puddle lights on the F30 door handles seem like an option, but mine come on when reversing so not the best option either. Anybody know of a fuse or wire I could tap into for this way? |
| 03-02-2020, 01:25 PM | #2 |
BMW CCA Member
515
Rep 808
Thinking parking lights also, plus it's a little easier to get to overall.
I was thinking of a similar idea as yours but going an LED demon eyes approach for the blank high beam spot on our head lights. |
| 03-02-2020, 01:26 PM | #3 |
![]() 4758
Rep 3,914
You can wire them the same way I wired my light carpet/angel wings provided that line supplies enough power (I don't know how much the kit you posted draws).
| 03-02-2020, 03:17 PM | #4 |
Rep 18,322
The radio power supply turns off immediately when the car is locked. Tap it on the input side, not the output side, so the lights don't add to the load on the radio fuse.
| 03-02-2020, 04:13 PM | #5 | |||
Rep 110
Seems like this would be difficult to accomplish if I only want it to run for 10-15seconds when unlocked then automatically turn off. |
| 03-02-2020, 04:58 PM | #6 |
![]() 4758
Rep 3,914
The door handles are 12V. The question is how many amps does the kit you want pull, and is that within the safe threshold of 22awg (0.35mm^2) wire? If it is, then you can wire your kit up like I did mine and have it turn on when the welcome/parking lights come on/car unlocked, and turn off when locked/driving.
| 03-02-2020, 05:31 PM | #7 | |
Rep 110
exE36M3515.00 |
| 03-02-2020, 09:25 PM | #8 |
Rep 18,322
I thought that's what you wanted. If it isn't wire them into a lighting circuit that already does what you want. LEDs draw practically no current, so that shouldn't be a problem. If it is add a 12v relay, separately powered, with the trigger wired to an existing lighting circuit.
| 03-02-2020, 09:48 PM | #9 | |
Rep 110
I’m thinking to run the lights to the fog lights as I rarely use the fog lights and it would be easy to tap into as well. I have it coded so that when the car is unlocked, the fog lights come on as welcome lights, and turn off when hitting locked. In this case, both the fog lights and underglow lights would come on when pressing the fog light button I’m assuming, correct me if I’m wrong. Only concern is whether or not tapping into the fogs will supply 12v power for the underglows. |
| 03-03-2020, 10:14 PM | #11 |
Rep 110
| 03-03-2020, 10:16 PM | #12 |
Rep 110
Thank you all for the help, really appreciate it as I’m not very much fluent with electrical and mechanical areas of the car. Will update once I get my lights.
| Bookmarks |
