03-08-2020, 03:46 PM | #1 |
Built Motor F30 340i
403
Rep 257
Blew Up B58
So last night I was doing a pull and car misfired and went into limp mode, friend radio'd to me that the car was billowing smoke. Pulled over and found a ton of oil all over the engine bay, in the intake system, etc. Cyl 5 is completely dead and it switches off fuel injection right after it starts, no matter if I clear the codes. We already swapped coil and plug and the problem persists on Cyl 5 which leads me to believe it has low compression, possibly a cracked piston.
Mods: - Pure 800 - DE Stage 2 HPFP - VRSF 4.5" Catless DP - Remus Axleback - Williams Performance Intake Pipe - AFE Drop In Filter - XHP Stage 3 - Custom E50 Tune By Wedge View post on imgur.com
03-08-2020, 04:25 PM | #3 |
403
Rep 257
I have a mod list in my original post.
03-08-2020, 05:29 PM | #6 |
Rep 163
Off-topic, but do you have a sound clip of your exhaust with the catless dp and remus axleback? I was looking at that setup. Really sorry to hear about the engine though, that really sucks.
03-08-2020, 06:10 PM | #8 |
Rep 151
Oh my.. Looks like a cracked ringland and that is at least. Oil is there due to extreme amount of blow by gasses entering the intake pipe from the upper PCV hose.
Kirill @ OdinTuned
03-08-2020, 06:28 PM | #9 |
Rep 585
Not good. You were pushing it very hard. Will you look to get a low mileage used engine?
Tesla Model 3 Performance 0 - 60mph 3.1s
M140i LCI Mineral Grey Dorch Stage 2 HPFP, CG Precision DS-1, XHP, MHD Stage 2 HPFP E30 @ E42 100 - 200 6.96s Quarter mile 10.93@127mph |
03-08-2020, 07:12 PM | #10 |
Rep 1,369
Oh man, this sucks. I’m sorry for your loss.
2017 M240i/ ZF8 Pure Drivetrain Solutions Stage 1 & torque converter/xHP/ DAW Ultra Flow/ DS2/ Nostrum injectors/ E40 Doug Newton tuned/ ER DP/ Remus axle back/ BMS intake/ FTP CP/ M Perf LSD
TBONE196915.00 |
03-08-2020, 08:42 PM | #12 |
Rep 2,601
Drives: G81 M3 Touring, GR Supra GTS
Is this the one that overboosted to nearly 40psi?
03-08-2020, 11:27 PM | #14 |
2JZ-GTE
3042
Rep 3,995
Sorry. Injector gone bad and then...... RIP ?
03-09-2020, 12:18 AM | #15 |
Rep 1,454
Really sorry this happened to you. Now we know what the power limit is on the stock pistons, roughly. Hope you find a good used engine for cheap!
03-09-2020, 12:19 AM | #16 |
Rep 3,189
If it actually is only a ring it probably wouldn't be too bad of a rebuild. Get a scope in there to check the walls. I'm guessing the meth backfire that popped your intake manifold probably damaged a ring, then pushing it made it fully crack.
03-09-2020, 05:07 AM | #17 |
Rep 191
Drives: '17 340i X-Drive M Sport EBII
03-09-2020, 08:14 AM | #18 |
Cheapskate
4450
Rep 4,993
I know your priority is swapping it, but I'd be very curious to see a teardown in the future. Good luck man.
03-09-2020, 11:19 AM | #19 |
Rep 190,805
+1
03-09-2020, 01:27 PM | #20 | |
Rep 412
I wanted to take a stage 3 on my B58 but not sure anymore...I do not think that 600hp is the limit of the pistons though. If we could see some data. I was convincing my self to order the new VTT turbo that has just been relaesed but not doing that before that I get more exemples of stage 3 with stock engine on B58...For now, it will be DP and E30 mix...
BMW M5 ZCP and M4 ZCP. BMW 540i G30 stage 2 with KW street confort, Wagner DP, Remus catback, M sport brakes 395mm front and 385mm rear. MHD tune.
03-09-2020, 03:41 PM | #21 | |
Rep 1,454
03-09-2020, 06:53 PM | #22 |
403
Rep 257
Here are the logs.
Log of it shatting itself: https://datazap.me/u/richmichael97/s...59-60-61-62-69 Log on same revision where it was fine: https://datazap.me/u/sbrach/1125?log...59-60-61-62-69
eluded3041.50 |
