05-11-2020, 04:33 PM | #1 |
Rep 2,341
Drives: E63 645Ci
Android 9 / 10 / 11 / 12 / 13 HU theming and customisation
This thread focuses on customisation of Android units discussed in Android 9, Android 10 and Android 11 / 12 / 13.
That means all the tools and methods listed in this thread will only work Android units running KSW firmware (that is Snapdragon 450/625/662/665/680). If you want to chat with people you can also join the Automotive Android Headunit Discord channel. Tools and guides KswRedirect is a suite of apps to redirect default shortcuts. The following tiles can be redirected to any other: browser, dvr, file explorer, phonelink. More info here and all-in-on package can be found here. KswOverlay for Android 8.1, 9, 10. This tool lets you compile main launcher overlay themed to your liking, more info here. For details on how to create your own theme and compile overlay apk please check this video guide. Overlay guide that helps to identify individual images and strings. Reworked overlay package for Android 10, 11 and 12 by smahel. This is updated installer prepared for all common overlays like BT, EQ, Launcher, Media, Music, Phone, Video. Thanks to smahel 's findings and work on the project, these no longer crash on A11 and A12 systems. You still have to populated that with your own resources (images and texts), this is just a core tool. System overlay for Android 10 devices to get rid off the "Phone is starting..." message. System overlay for Android 11/12/13 (not suitable for A10!) devices to get rid off the "Phone is starting..." message. Updated version by smahel. Splash image tool allows you to create your own boot image - that method works only for Android 9 and 10 devices. How to guide can be found here. BMW Accessories Configurator. If your car doesn't support ConnectedDrive and was built anytime between 2000-2010, you can use this tool to select your platform, paint job, wheels, details, interior etc and make your own graphics based on that. Guide to create your own GUI Video tutorial on how to create a custom boot animation and BMW stock animations. UI problems caused by boot animation being too large. Scrcpy for those of you how want to tinker with head unit on your desk, this is the app that allows you to display and control any Android device on your PC or Mac. For SD625 units it only works over WiFi but on older units it might work with USB A male to USB A male cable. A guide how to use it can be found here. TL;DR Here is what you need to install a theme: 1. A laptop or PC (Windows/Mac/Linux - doesn't matter). Your Android head unit and laptop/PC are on the same local network and can talk to each other. 2. KswOverlay project. 3. Java's JDK and JRE (linked in point 2). 4. A theme - if you decide to create a personalised car tile with your own car here are further requirements: 4a. Picture of your car. 4b. Photo editing tool like Photoshop or Gimp. Now we have that sorted out, here is simplified procedure how to install: 1. Create your personalised "car tile"... or not. 2. Copy theme files to \KswOverlay-master\resources. 3. Compile your apk. 4. Make sure your laptop or PC are on the same local network as your Android HU. 5. Find out what is the IP address of Android unit. 6. Install overlay (script included). 7. Enable overlay with adb command. 8. You are done. Once overlay is installed and running, you can always compile new apk with different graphics, copy it to a USB drive in simply install it on your Android unit - no need for laptop/PC again. When new version of Android OS comes out and you decide to install it, then you have to repeat this procedure to upload and enable overlays (themes) again. Understanding Android boot up sequence and preparing files for your animation: Android boot up is split into two parts: first you would be presented with a splash image – a static image that is shown before the animation starts. Then there is the animation itself. Preparing splash.img (Android 9 and 10 only) file: 1. If you want to have a smooth transition between splash image and boot animation you would typically use the first frame (image) of your boot animation and convert it to splash.img. This is not necessary as you can use any image you want. 2. If you don’t want to use the first image of your boot animation, it is important that your splash image is the same resolution as your screen. 3. Use splash image tool to convert your image to splash.img Android 11 uses imagefv.elf files for boot logos and we do not have the tool to create these. Android 12 and 13 use imagefv.bmp and everyone can make it using Ms Pain under Windows 11 (previous versions don't work for some reason). Understanding and preparing bootanmiation.zip file: Here I won't cover how to actually make your own animation (this is explained in a video linked above) but rather explain how to prepare files for installation. Just remember that it doesn't matter if images are jpg or png, what matters is that the size of complete animation doesn't exceed 20MB. 1. Boot animation file consists of 2 elements: folder(s) ( part0 part1 … partn ) where images are contained and description file ( desc.txt ) telling Android how to play animation. 2. Each folder contain a set of images that are being played out. A typical animation consists of 2 folders part0 and part1. In this case part0 would contain the main animation (set of images) and part1 only 1 image acting as a final step before the booting sequence is complete. 3. For all of this to play out you need a description file. There are 2 elements to the description file: declaration of resolution and frame rate at which animation is to be played out, and information on how to play each folder. Here is an example: 1920 720 25 c 1 0 part0 p 75 0 part1 1920 720 25 is declaration of screen width x height x fps Then there is declaration of: type of playback , how many times , delay , path - c stands for play in full - p stands for play but once boot sequence is complete, interrupt (finish) playback - first number stands for how many times this sequence is to be played - second number is the delay between playback starts - and finally the last part is the path of files to be played. So taking apart this example we have the following: Animation is 1920x720p at 25fps Play in full part0 images only once (1) with 0 delay Then play 75 times (assuming only 1 image is located the folder - 75 frames / 25 fps = 3 sec) part1 but stop it as soon as boot sequence is complete 4. Once all folders and desc.txt files are ready, use the 7zip program to put your files in a zipped folder. It is important that you select compression level store, meaning files are contained in the zip file and not compressed at all. 5. Create an OEM folder in the root of your USB stick. 6. Move bootanimation.zip and boot logo (splash.img, imagefv.elf or imagefv.bmp) files to the OEM folder. 7. Plug in a USB stick to your HU and wait for a confirmation message. 8. Done. Hope this is clear as mud now Last edited by RedErik; 02-16-2024 at 05:01 AM.. |
Kri1080.50 akirax30.50 kenza75016.00 Mjam133.50 Pondaire37.00 BMW DIY Guy2997.00 fidan_flipov0.00 roma324.50 LittleSamurai4.50 Luper5258.50 moskito9912.00 |
05-11-2020, 04:34 PM | #2 |
Rep 2,341
Drives: E63 645Ci
Themes
IMPORTANT NOTE Some of us here are able to provide customised themes for you guys. If you decide to approach any of the designers here, please bear in mind that this is all possible thanks to nicholaschum hard work and no one should profit from that. Artist should be compensated for their work but if you are being charged more than 10€ / £10 / 10$ for a "copy/paste" job (one design sold multiple times) you should be refunded what you've paid extra. Individually made themes do not fall into that bracket - please apply common sense. ID7 theme (KswPLauncher) by myself Updated: 24.05.2020 Example of a custom design ID7 Media Player (KswPMedia) theme by myself Updated: 18.05.2020 ID6 GS theme (KswPLauncher) by kri Last edited by RedErik; 07-22-2021 at 03:36 AM.. |
05-11-2020, 04:38 PM | #3 |
Rep 2,341
Drives: E63 645Ci
Community made Apps
Drive keyboard was developed to help with keyboard inputs on automotive Android headunits. It supports rotary controller found in many modern cars allowing for character input without the need for touching the screen or in a conventional way with QWERTY style keyboard and touch inputs. FlowUX Synesthesia custom launcher by nicholaschum Car Radio - The ultimate radio experience. Built to seamlessly match your car. Developed by Jellepepe. ID7 Launcher - Modern and highly customisable launcher developed by Jellepepe. KSW-ToolKit 2 - A powerful customisation tool for all KSW units developed by Frankly30 (Snaggle). Custom iDrive launcher CIC/NBT style. KswX Dashboard - Standalone custom dashboard app. It is not a replacement for the existing dashboard - this is a standalone app that you have to launch from your app drawer. IMPORTANT Development of this app has stopped. If you have any issues, this won't get fixed. If you wish to contribute to the project, here is the source. daschacka Original coding Frankly30 Self adb implementation and some tweaks RedErik Custom graphics Original post Last edited by RedErik; 02-20-2024 at 05:17 AM.. |
05-11-2020, 04:41 PM | #4 |
Rep 2,341
Drives: E63 645Ci
Boot animations and splash images
Universal boot animations along with splash images for 1280x480 and 1920x720 units. Boot logos: Android 9 and 10 use splash.img and the tool is linked in the first post. Android 11 uses imagefv.elf unfortunately due to the nature of these files we do not have the tool to create them. Android 12 and 13 use imagefv.bmp and everyone can make it using Ms Pain under Windows 11 (previous versions don't work for some reason). How to install on SD425/450/625/662/665: 1. Create an OEM folder in the root directory of your SD card/USB stick 2. Copy both bootanimation.zip and boot logo (splash.img, imagefv.elf or imagefv.bmp) to the OEM folder 3. Plug in to your Android unit 4. Wait for confirmation of successful installation 5. Reboot and enjoy How to remove boot animation from SD425/450/625/662/665 unit: 1. Create OEM folder in the root directory of your SD card/USB stick 2. Create an empty bootanimation_clear.zip file and move it to the OEM folder 3. Plug in to your Android unit and wait Thanks to VincentZ4 for providing installation instructions for PX6 units and 3bl for providing additional steps in case you encounter any isses. How to install on PX6: Splash image / Boot logo - Create 1280x480 image - Save image as logo.bmp - Create OEM folder on your USB drive - Copy logo.bmp to the OEM folder - Turn the device off - Wait 15 sec - Plug the USB in - Let the system start - Reboot Bootanimation.zip On PX6, you will need to run ADB on your PC/laptopt There are 4 steps to follow: STEP 1: create bootanimation.zip bootanimation.zip is a set of files as described here: https://android.googlesource.com/pla...tion/FORMAT.md One thing to know, in the desc.txt, the last txt line is empty : -- beginning of file -- 1280 480 25 p 1 0 part0 p 0 0 part1 -- end of file -- Step 2: enable ADB WiFi - connect the HU and computer to the same WiFi network - go to Developer Settings: -> enable USB debug. - install Terminal Emulator on your HU - run HU Terminal Emulator and enter following commands: Code:
setprop persist.adb.tcp.port 5555 setprop sys.rkadb.root 1 reboot Code:
ifconfig wlan0 Then continue on your PC: Code:
adb connect xxx.xxx.x.x:5555 Code:
adb root adb disable-verity adb reboot Then continue on your PC: Code:
adb root adb remount Move USB stick to your Android unit Then continue on your PC: Code:
adb shell cp /storage/usb_storage/bootanimation.zip /system/media adb shell cp /storage/usb_storage/bootanimation.zip /data/local adb shell chmod 644 /system/media/bootanimation.zip adb shell chmod 644 /data/local/bootanimation.zip adb shell chmod 755 /system/media adb reboot You may need to reconnect after each "adb root" command. You should see the animation now ! NBT boot animation - demo video NBT EVO boot animation - demo video NBT M boot animation - demo video Universal 1 boot animation - demo video Splash image thanks to mbonus Universal 2 boot animation - demo video Ask me for custom made boot animation with your exact car and welcome text - see my work on YouTube Last edited by RedErik; 11-16-2023 at 10:04 AM.. |
haibn921.50 Alpina_Guy4.50 rap17ka7a0.00 fe7565519.50 speedbirdblack14.50 wlad-20010.00 tequilaa0.00 pama82020.00 LittleSamurai4.50 Kolianovskyi87.00 |
05-11-2020, 05:10 PM | #5 | |||
Rep 2,341
Drives: E63 645Ci
Tasker projects
Thanks to VincentZ4 for detailed documentation of KSW API, commands and events for Tasker. Quote:
05-11-2020, 05:55 PM | #6 |
Rep 237
since we're talking about themes, here is my M splashboot image
Just rename attached .pdf to .img |
05-13-2020, 10:39 PM | #7 |
Rep 1,048
Hello guy`s,
I created a All-In-One Package for KSWRedirect to do the setup more easily. The Download can be found on Github-KswAIO , just click on "clone or download" and extract the package. You Just need to enter your devices IP Adress (without 5555) and select the number of the app you want to replace When replacing ES-Explorer it will also install DocumentsUI to not end without any filebrowser on the Headunit. For now this only will work with Snapdragon Headunits. Kri Last edited by Kri; 05-13-2020 at 10:50 PM.. |
05-13-2020, 10:49 PM | #8 |
Rep 1,048
I also created a Installer for KSW-Overlay.
The Installer is within the Github-KSW-Overlay repository and called kswoverlay-installer_windows.bat. As doing adb commands on very fast machines or when wireless network connection may cause troubles alot of waiting times have been added. Also there is no need to manually resume the script anymore, it will do the reboots for you and waits until is online again. You also need to only enter the IP-Adress without 5555. This will work for Snapdragon and PX6 Headunits. Kri Last edited by Kri; 09-07-2020 at 08:48 AM.. |
05-14-2020, 04:55 AM | #9 |
Rep 117
First of all: nice topic and thnx for the good work!!
I found this topic from following the Android 10 HU topic. I want to change the car picture on my ID7-theme. I managed to get a picture of my car from the Car Configurator tool, but now I am facing difficulties in putting this picture in. Within ID7, the car and background are 1 picture (without layer). Can someone help to put the picture of my car onto the ID7 standard background (black with some red ++). Tried a lot of hours in GIMP/Photoshop but I can not get a nice picture with transparent background out of the E61-image Attached: 1. picture of my car from the Configurator (E61; saphire black; M-pack; M135 Wheels). 2. edited picture by myself (removed the licence plate) 3. picture of the current ID7-car (took from KSW drawable-mdpi-v4 folder) I have a CCC SD625 unit by the way. Last edited by kenza750; 05-14-2020 at 04:59 AM.. Reason: add attachment |
05-14-2020, 05:56 AM | #10 | |
Rep 2,341
Drives: E63 645Ci
This is as far as I can help you with that. If you want a different background you have to make it yourself. |
05-14-2020, 06:16 AM | #11 |
Rep 117
Wauw, RedErik, excellent. How did you manage that??
I managed to get the original backgound (with the red ++) by copying the top part downwards so I will try to use that one to match the rest of the backgrounds of standard ID7. Many thanks again!! |
05-14-2020, 06:23 AM | #13 | |
Rep 1,048
Use the original car file of kswplauncher (not a screenshot of it) and modify this. EDIT: was wrong, backround is with car image at ID7. Kri Last edited by Kri; 05-14-2020 at 06:47 AM.. |
05-14-2020, 06:28 AM | #14 | |
Rep 117
The original file of the car is with background as far as I can see. (see screenshot of the files) |
05-14-2020, 06:29 AM | #15 |
Rep 2,341
Drives: E63 645Ci
05-14-2020, 06:44 AM | #16 |
Rep 1,048
05-14-2020, 06:48 AM | #17 |
Rep 2,341
Drives: E63 645Ci
05-15-2020, 05:46 AM | #19 |
Rep 2,341
Drives: E63 645Ci
05-15-2020, 07:04 AM | #20 |
Rep 399
It's a separate app, but I have a vague memory of a DAB Tile in earlier launcher versions. Many of us have for a long time used the DVD Tile to launch DAB. Now with theme capabilities we can also update the image, and with DAB being so common, I was hoping a DAB image could be included with the themes.
05-15-2020, 07:50 AM | #21 | |
Rep 2,341
Drives: E63 645Ci
05-15-2020, 09:03 AM | #22 | |
Rep 1,048
At ID7 you can only change the function of the small "Music" icon. If you want to have an DAB+ Tile working you need to use other GUI`s like ID5, ID6, Common_UI_GS or Common_UI_GS_UG To have a better overview you can find images of the default GUI`s here. Kri |
